Topic: 192Khz Lossless Audio LAN streaming (Read 35356 times) previous topic - next topic
Dear HA Community,
My task is to transport "untouched" audio from point to point in LAN.
However I have to use 192Khz 16bit sound resolution, in order to preserve additional information that is encoded in the audio, and that must remain unaffected.
Compression with one of Lossless Audio encoders would be beneficial ( ex. FLAC)
I am trying to do this:
I need help with a few things:
-what kind of container/multiplexer is supported with flac, in order to stream it (I suppose ogg but I cannot find dshow filter)
-could someone tell me how to finish this graph and send RTP stream to IP address.
Is there any other software which I could use for this purpose ? (jack is not an option)
Kind Regards.
Why specifically is jack not an option?
Do you have any latency criteria?
I assume the encoded information in the stream requires bitperfect transfer.
Did you consider the issue of two different clock domains (the incoming spdif stream, the playback soundcard on a different machine)? Jack solves that by adaptive resampling.
In linux you could just pipe the stream to a different machine via netcat for processing. AFAIR netcat is available in cygwin.
Thank you for replying.
I will try to clarify:
-encoded stream should be sent over both Ethernet and wifi connection.
As for NetJack it seems to be a problem working on a broadcast domain without collision detection.
I was thinking that flac might also reduce bandwidth requirements ex. from 6 to 4Mbytes/sec
act as encapsulation for PCM waveform(keeping it "bitperfect"), and by using reliable transport and introducing some buffer on the playout end, it would work.
-Latency is not an issue, but reliability.
On the recieving end there would be a soundcardcard supporting same clockrate, and player application would do buffering and re clocking. (I would have to rethink this)
But that's the idea.
-To simplify it should be bitperfect streaming over wifi for 192Khz. 16bit sound, preferably with lossless compression.
If linux is an option:
Transmitting side:
sox Music/long-192-16.wav -t flac -r 192000 -b 16 - | pv | nc playback-host 5555
Receiving side (on playback-host)
nc --continuous --exec='mbuffer -m 20M -P 5 | sox  -t flac - -t alsa plughw:0' -l -p 5555
Since you are connecting two clock domains you have to make sure enough buffers are employed with enough cached samples at the beginning. Hence the mbuffer command - 20MB buffer, starts writing after 5 % (1MB) of samples buffered (for the case when playback clock is running faster than the incoming SPDIF stream). Of course the latency is large.
On the transmitting side you can read the samples from the SPDIF input and convert to flac both using sox
sox -t alsa plughw:YOUR_SPDIF_DEVICE -b 16 -r 192000 -t flac -r 192000 -b 16 - | pv | nc playback-host 5555
The commands pv on transmitting and mbuffer on the receiving side will nicely report current stream bitrates.
Transmitting side:
Thank you once again,
This certainly works, and I am willing to try it this weekend. Is there any solution for windows ?
Just for curiosity what would be the best way to go for ultra low latency ? (linux or windows)
Regards.
192 kHz and now low latency; I must ask, what is the application?
I am trying to transport encoded information in the sound along with the music. Like watermarking.
IMO low latency = jackd. Low latency is its top focus.
BUT you will have to use the adaptive resampler  zita-ajbridge if merging two clock domains - not bit perfect.
IMO the most reliable option with best results would be to run the SPDIF coax all the way to your playback machine and skip the wireless part.
Are you by any chance working with MPX signals? If so, the sample rate can be lowered to ~ 128 kHz (there won't be any signal above 60 kHz if you don't use SCA channels), and if you really need to reduce bandwidth, you could get away with *slightly* lowering the bit depth (14 bits should still suffice).
Flac can be used to reduce the required bandwidth *on average*, however nothing can be guaranteed and you might at some points even get a (slightly) increased bandwidth - which, especially when combined with the low latency requirement, might be problematic.
Thanks phofman,
your first suggestion is fine.
I really appreciate.
transporting MXP over IP is a nice example, but for my application I need to keep sound resolution.
Thank you all.
I dont know how to ask linux nicely, but this is what i am getting:
a couple of problems here:
$ sox -t alsa plughw:0,1 -b 16 -r 192000 -t flac -r 192000 -b 16 - | pv | nc IP 5555
Input File     : 'plughw:0,1' (alsa)
Channels       : 2
Sample Rate    : 48000
Precision      : 16-bit
Sample Encoding: 16-bit Signed Integer PCM
In:0.00% 00:00:00.00 [00:00:00.00] Out:0     [      |      ]        Clip:0      sox WARN alsa: Input/output error                                              ]
sox FAIL sox: `plughw:0,1' Device or resource busy: Operation not permitted
Done.
   0B 0:00:10 [   0B/s] [<=>
0,1 = Asus Xonar D1 digital audio capture
1. alsa alows me only 48k ?
2. on another linux host under vmware sending works partialy,but only with 48k settings and it breaks after a while... ?
in this case 0,0 = VAC
@UbuntuVM1:~$ sox -t alsa plughw:0,0 -b 16 -r 48000 -t flac -r 48000 -b 16 - | pv | nc IP 5555
Input File     : 'plughw:0,0' (alsa)
Channels       : 2
Sample Rate    : 48000
Precision      : 16-bit
In:0.00% 00:00:00.85 [00:00:00.00] Out:36.9k [      |      ]        Clip:0      In:0.00% 00:00:01.88 [00:00:00.00] Out:86.0k [      |      ]        Clip:0      In:0.00% 00:00:03.07 [00:00:00.00] Out:143k  [      |      ]        Clip:0      In:0.00% 00:00:04.10 [00:00:00.00] Out:193k  [      |      ]        Clip:0      In:0.00% 00:00:05.12 [00:00:00.00] Out:242k  [      |      ]        Clip:0      In:0.00% 00:00:06.14 [00:00:00.00] Out:291k  [      |      ]        Clip:0      In:0.00% 00:00:07.17 [00:00:00.00] Out:340k  [      |      ]        Clip:0      In:0.00% 00:00:08.19 [00:00:00.00] Out:389k  [      |      ]        Clip:0      In:0.00% 00:00:09.22 [00:00:00.00] Out:438k  [      |      ]        Clip:0      In:0.00% 00:00:10.24 [00:00:00.00] Out:487k  [      |      ]        Clip:0      In:0.00% 00:00:11.26 [00:00:00.00] Out:537k  [      |      ]        Clip:0      In:0.00% 00:00:12.46 [00:00:00.00] Out:594k  [      |      ]        Clip:0      In:0.00% 00:00:13.48 [00:00:00.00] Out:643k  [      |      ]        Clip:0      In:0.00% 00:00:14.51 [00:00:00.00] Out:692k  [      |      ]        Clip:0      In:0.00% 00:00:15.53 [00:00:00.00] Out:741k  [      |      ]        Clip:0      In:0.00% 00:00:16.55 [00:00:00.00] Out:791k  [      |      ]        Clip:0      In:0.00% 00:00:17.58 [00:00:00.00] Out:840k  [      |      ]        Clip:0      In:0.00% 00:00:18.60 [00:00:00.00] Out:889k  [      |      ]        Clip:0      In:0.00% 00:00:19.63 [00:00:00.00] Out:938k  [      |      ]        Clip:0      In:0.00% 00:00:20.82 [00:00:00.00] Out:995k  [      |      ]        Clip:0      In:0.00% 00:00:21.76 [00:00:00.00] Out:1.04M [      |      ]        Clip:0      In:0.00% 00:00:22.78 [00:00:00.00] Out:1.09M [      |      ]        Clip:0      In:0.00% 00:00:23.47 [00:00:00.00] Out:1.12M [      |      ]        Clip:0       0B 0:00:22 [   0B/s] [<=>                                                   ]
In:0.00% 00:00:46.85 [00:00:00.00] Out:2.24M [      |      ]        Clip:0    @UbuntuVM1:~$
I am using Ubuntu 13.10 and flac 1.3.1
3. netcat syntax is different. Could you assist on the command line  for the reciever side please?
Kind Regards.
Windows aproach:
VAC->edcast->icecast2
sending works
reciever is foobar2000 and it plays the content something like 4 times slower and eventualy drop the connection and stop playing.
Output device is supporting 192Khz output but it looks like there is a player or encoder limitation... ? Winamp and VLC refuse to work.
Evrything works only with 44Khz.
Any suggestions ?
Regards.
Your sound device is already used by another process, most likely pulseaudio. You can find out which by running
sudo lsof /dev/snd/*
When capturing SPDIF input, you cannot select input samplerate on the soundcard. It is defined by the incoming stream. IMO you are feeding the card with 48k SPDIF.
Let's fix the capturing in non-virtualized environment first.
There are two different netcat packages in your repo -
netcat-traditional and netcat-openbsd, each with a bit different feature set.
quick update:
1. used by pulse audio is true:
:~$ sudo lsof /dev/snd/*
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
      Output information may be incomplete.
COMMAND    PID   USER   FD   TYPE DEVICE SIZE/OFF  NODE NAME
pulseaudi 1379 ./.   17u   CHR 116,10      0t0 10601 /dev/snd/controlC1
pulseaudi 1379 ./.   24u   CHR 116,10      0t0 10601 /dev/snd/controlC1
pulseaudi 1379 ./.   30u   CHR 116,15      0t0 10868 /dev/snd/controlC0
pulseaudi 1379 ./.   34u   CHR 116,15      0t0 10868 /dev/snd/controlC0
2. There is no input connected to the sound card
Ok,
here is capturing "working" on physical machine:
:~$ sox -t alsa plughw:D1,0 -b 16 -r 48000 -t flac -r 48000 -b 16 - | pv | nc 172.16.0.7 5555
Input File     : 'plughw:D1,0' (alsa)
Channels       : 2
Sample Rate    : 48000
Precision      : 16-bit
In:0.00% 00:00:00.34 [00:00:00.00] Out:12.3k [      |      ]        Clip:0       0B 0:00:00 [   0B/s] [<=>                                                   ]
In:0.00% 00:00:00.51 [00:00:00.00] Out:20.5k [      |      ]        Clip:0    dr6 - | pv | nc 172.16.0.7 5555 plughw:D1,0 -b 16 -r 48000 -t flac -r 48000 -b 16
Channels       : 2
Sample Rate    : 48000
Precision      : 16-bit
and it fails after two cycles. What is next ?
Regards.
Does the other, receiving part run? It must be consuming samples, otherwise the transmitting part gets blocked after filling all the buffers in sox/pipes/netcat.
I switch to: /bin/nc.traditional
:~$ nc -h
[v1.10-40]
and now I am just getting this prompt after putting in command:
:~$ nc --continuous --exec='mbuffer -m 1M -P 5 | sox -t flac - -t alsa plughw:0,0 -l -p 5555
and cursor is blinking.
On sending host it happens exactly the same as I previously described. It fails after two cycles.
Regards.
Your exec command in nc is missing the closing singlequote, the shell waits for continuation of the command.
Plus do you have mbuffer installed?
Exactly, your receiving side is not running yet.
Ok,
I am getting this now:
~$ nc --continuous --exec='mbuffer -m 1M -P 5 | sox -t flac - -t alsa plughw:0' -l -p 5555
nc: invalid option -- '-'
nc -h for help
mbuffer is there.
Use package netcat6 instead.
Either uninstall the other netcat packages, or change alternative binary by
update-alternatives --config nc
after putting netcat6 only this is happening:
in @  0.0 kB/s, out @  0.0 kB/s,  0.0 kB total, buffer   3% ful
Buffer is filling now . Is there anything like VAC for linux to try 192Khz with ?
Regards.
Despite of your other skills,  phofman I award you with PhD in Linux
Thank you SOOOO MUCH!
I feel happy now
After I finish testing I will come back.
Kind Regards.
I hope you won't be offended if I correct your English, but I think you meant "In addition to your other skills".
