Topic: TV headphone out to stereo amp (Read 28618 times) previous topic - next topic
My TV (Samsung EH5000) doesn't have line out (line level output) just headphone out. Is it safe to connect headphone out to integrated stereo amp (old NAD C325BEE) and if it's ok what would be the safe volume level set on TV? What are the consequences of probable impedance and signal level mismatches?
Its safe.  You'll probably have to set the volume to 100% to get to line level.
The TV has a SCART socket, the manual doesn't have a pin diagram for it but I'd suggest trying a SCART to 2 phono out as this would give you a line out if your TV has a fully wired SCART socket
I have tried that but it only outputs audio signal when watching terrestrial tv channels. It doesn't output signal from hdmi input or inbuilt media player.
The connector is called RCA. Stop confusing people with talking about "phono out" please!
@papucar: As said, using the headphone output shouldn't be much of a problem. Since the line in has a greater impedance, both parts are safe (the opposite would be bad).
On the other hand, I'm not so sure about saratoga's claim to use 100% of volume... Just try it out, starting from low volume until you're fine.
Else, you'll have to buy other components for your setup, as the TV has Digital (optical) audio out.
I'm doing that with an LG TV and Technics receiver. It doesn't need 100% but it's up around 70. Residual noise is below ambient at 6 inches from the speaker. IOW it works fine.
I use the FiiO D3 for my bedroom TV that is very similar: only optical audio out. Anyway, for about $25 it does the job handily.
I use the headphone out on my Samsung TV too. The frequency response is pretty linear (i checked it), so that's good. The output level is quite usable as well, i usually keep it in the middle. You certainly don't need volume at 100.
Thanks you everyone! I connected TV to amp through headphone out and it seems to work fine.
I looked into fiio D3 but it seems to have weak line out. I would be interested in cheap DAC that is able to output line level signal as my TV doesn't let user choose between internal speakers and headphone out.
Definition.... "An RCA connector, sometimes called a phono connector or cinch connector". Stop being pedantic it's not helping anyone.
Did you menage to find any specs for the headphone out? I asked Samsung support but they didn't know. It's a pity that they don't include line out on their TVs any more.
In addition to FiiO D03k I looked into these devices but I couldn't find line out specs:
http://orei.com/index.php/electronics/audi...-converter.html
http://www.ebay.com/itm/Digital-Optic-Coax...121157118026%26
I am not interested in further discussion. If you feel fine talking about phono connectors, let's be it. The "sometimes" in your sentence is more important than what you seem to think.
Its almost unheard of for consumer electronics to include meaningful specs for headphone ports.  At best you might find some made up power figures or meaningless frequency response number.  Fiio is actually pretty atypical in this respect.
I got my mom a Samsung UN40EH5000 a while back and was disappointed to find the "headphone" jack on the back was actually a fixed-level line out jack. I ended up having to make a remote controlled volume attenuator using an Arduino Uno, which turned out to be rather fun and educational.
My TV is UE40EH5000W (model for continental Europe) and volume of headphone out can be controlled by remote. Models for different markets vary significantly for example UK Model has LAN connection but continental Europe model doesn't have it.
I suppose Samsung could easily modify the firmware to allow switching between line level signal and amplified signal on headphone out as well as switching between headphone out and internal speakers.
This was also quite common for TVs sold in the US regarding their optical out, at least in the past. The optical out worked for the internal tuner, however it was silent for HDMI sources. On some other TVs the optical out provides a dumbed down version of the incoming HDMI signal [for example, a 5.1 Dolby Digital signal is converted to PCM 2.0, which probably wouldn't be a problem regarding how you seem to want to use it with your NAD amp].
Samsung doesn't explain this well in their manuals but instead has a generic FAQ page which warns that this varies from TV to TV, here:
http://www.samsung.com/us/support/SupportO...&fm_seq=804
[Read the last section: "Digital Optical Does Not Work For All Sources"]
In any event, I think using the headphone jack as you now are make the most sense if you need to keep the TV's remote control volume functional. The optical out may or may not work for incoming HDMI signals, but I'd be shocked if it's level was adjustable via remote. You should assume it will be a fixed level.
Samsung support didn't know the answer as well!
I would prefer fixed line level output but headphone out seems to work just fine. I set the volume of headphone out on TV to the middle value and then I control volume trough amp's remote. I will try to experiment later to compare TV's headphone out loudness to other sources.
