Topic: How do I change the foobar icon? (Read 8421 times) previous topic - next topic
Hi all,
I'm a frequent and otherwise pleased user of foobar but I would very much like to change the foobar icon everywhere in Windows and in foobar. Is this possible and might one of you direct me to a link where it's described how to do it?
Thanks for any input you may have ...
Jesper
On the taskbar or within a explorer window (...\Program Files(86)\Foobar2000\) search for and right-click foobar2000.exe and choose properties -> centre bottom "change icon". The notification area icon options are in foobar2000's preferences -> display -> default user interface -> system notification area:"use a custom icon from file" OR if you use Columns UI: preferences -> display -> columns ui -> notification area tab -> "use custom icon".
You can only change a shortcut's icon, not directly on an .exe-file.
When rightclicking the icon I've got pinned on my taskbar I can. Other solution if that really doesn't work is making a shortcut and changing that icon and placing the shortcut on the taskbar instead of pinning/dragging the exe itself.
Icons on the taskbar are shortcuts, of course it works to change those.
They're located here: %appdata%\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar
As long as you don't distribute the modified EXE with anyone else . . . try using the tool "Resource Hacker".
Hi all,
& thanks for your feedback & suggestions. I'm a bit occupied with other things these days but will look into your suggestions in the days to come when there's more room for it.
Thanks again
Jesper
