Topic: Crashes unless booted in safe mode (Read 1448 times) previous topic - next topic
Foobar has been working fine for months and today when I clicked on it i get a "Foobar2000 has stopped working" error. Here are the error details from that window:
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   foobar2000.exe
  Application Version:   1.2.1.0
  Application Timestamp:   50f01419
  Fault Module Name:   KERNELBASE.dll
  Fault Module Version:   6.1.7601.17651
  Fault Module Timestamp:   4e211319
  Exception Code:   0eedfade
  Exception Offset:   0000b9bc
  OS Version:   6.1.7601.2.1.0.256.1
  Locale ID:   1033
  Additional Information 1:   d383
  Additional Information 2:   d38322db1fb530dab91d5490fe2c0303
  Additional Information 3:   08d9
  Additional Information 4:   08d924223fd0a32af2fd2f66fe98b11b
When i try to open again it gives me the option to start normally, safe mode, or troubleshoot. Both starting normally and troubleshooting result in the same error. I can boot in safe mode fine. Here is my component report:
Core (2013-01-11 13:31:06 UTC)
    foobar2000 core 1.2.1
foo_albumlist.dll
foo_audioscrobbler.dll
foo_burninate.dll
foo_cdda.dll
foo_converter.dll
foo_customdb.dll
foo_dop.dll
foo_dsp_eq.dll
foo_dsp_std.dll
foo_fileops.dll
foo_freedb2.dll
foo_input_std.dll (2013-01-11 17:31:32 UTC)
    Standard Input Array 1.0
foo_podcatcher.dll
foo_rgscan.dll
foo_softplaylists.dll
foo_ui_columns.dll
foo_ui_std.dll (2013-01-11 13:27:10 UTC)
    Default User Interface 0.9.5
foo_uie_dragpanel.dll
foo_uie_elplaylist.dll
foo_uie_esplaylist.dll
foo_uie_panel_splitter.dll
foo_uie_vis_channel_spectrum.dll
foo_uie_wsh_panel_mod.dll
foo_unpack.dll
Not too sure what could've caused a change. Foobar and components are up to date. I don't ever get a dialog to send an error report. OS is Windows 7 64
