Topic: Automatically filter duplicates from playlists (Read 2003 times) previous topic - next topic
Is there any way for a playlist to automatically perform the "edit > remove duplicates" function? I created a separate playlist from my autoplaylist and if a I add a new album by band that was already on the new playlist, if I add the whole discography, I get duplicates (naturally). Can them be somehow whipped  automatically?
add a WSH panel mod panel to your layout and put this code in...
function on_playlist_items_added() {
    fb.RunMainMenuCommand("Edit/Remove duplicates");
i just realised the above only worked when dragging files onto the playlist. this should work properly...
    plman.SetActivePlaylistContext();
//this code draws the background the same colour as the foobar splitter so you can resize the panel to hide it better.
var ww = 0;
var wh = 0;
function on_size() {
    ww = window.Width;
    wh = window.Height;
function on_paint(gr) {
    gr.FillSolidRect(0, 0, ww, wh, utils.GetSysColor(15));
