Topic: Q: studies of how hair / earpiercings do (/don't) affect hearing? (Read 5572 times) previous topic - next topic
Links / sources, anyone? I'm curious, and a web search only led me to numerous discussions (typically uneducated ones) on whether the nerves could be damaged by a tragus piercing, and not anything on e.g. how big jewelry must be in order to be 'earplug'-alike distortion.
(And no, I won't be seen dead with a combover. Find another lab rat.)
Any deformation to the pinna can potentially cause an audible change to your HRTF. Try listening to a steady state, broad band noise (I just used my desk fan) and squish your pinna, the external ear, into various shapes. Hear the change to the frequency response? [Pink noise or inter-station FM radio hiss would be good sources too.]
Reflections off large, circular hard discs held close to the ear canal's opening could also be audible. Hair plays a small role in HRTF too.
I doubt any modification of  the outer ear, up to and including slicing it entirely off, would have any effect on the inner mechanisms, however the psychological trauma of this (or even simple ear piercing) may have a placebo effect. Also, I can also see how people hearing  a  change to their HRTF frequency response (due to pinna modification)  could misinterpret it as "I now have a hearing loss, probably due to some nerve damage".
If you want academic discussions in reputable peer-reviewed literature, Google Scholar's search functions will improve your search's signal to noise ratio immensely, so long as you adhere to scholarly terms and ideally spelling conventions (e.g. mostly United States English spellings are conventional in papers unless referring to Standards/Trademarks created in different variants of English, though Google is often helpful with 'did you mean' suggestions)
Thanks for the tip, although I am enough g33k to know. Hair's the problem (pun intended): much more scientific literature on those hair cells that are inside the ear
https://www.google.com/#hl=en&sugexp=le...350&bih=688
The second hit looks promising.
I once did a search and tried everything I could think of: "LP, record, vinyl, phonograph record, 33, 45, 78, album, record album, phono, record player, phono recording..."
Turns out I stumbled upon the paper I wanted by other means, but the pay dirt paper called them "commercial discs".
