Topic: False (?) alarm after multithreaded file conversion? (Read 1726 times) previous topic - next topic
I want to convert a large collection of lossless (flac, shn) files to mp3 VBR -V2 using the built in converter.
Upon completion of one conversion job, I get a popup containing the following (shortening folder paths with [...]):
22 out of 91 tracks converted with major problems.
Source: "D:\[...]\Band 1983-11-23 01.flac"
  An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]\Band 1983-11-23 01.mp3"
  Conversion failed: File is already in use
Source: ... (These 3 lines repeat for each track with 'major problems')
I've tested a few files to find whether there were any errors on these files:
1) Waveform comparison using Audacity: Merging inverted mp3-track + source file resulted in very low signal throughout, nothing strange found.
(However, mp3s seem to have a few 1/100ths of silence at the beginning & end of the tracks. Fyi the analysed source files are aligned to sector boundaries (CDDA).)
2) Full content comparison of 2 repeated conversion jobs of identical source files -> No differencies (using WinMerge).
The amount of errors is variable:
15 / 533
7/64
15/91
22/91
15/91
22/91
The last 2 conversions were made after changing Thread count & prio. Even though they have identical figures, the affected files are not (all) the same.
3) Listening.
System:
Win 7 Pro x64 (on non-raid SSD)
Intel i7-860 (Quadcore with 8 virtual cores / Hyper-Threading / no idea what they call it these days)
Source and destination are on the same non-raid HDD.
Used encoder: Lame 3.98r (supplied with Trader's Little Helper 2.7.0 (http://tlh.easytree.org/)
Converter Settings:
Output format: mp3 (Lame), V2
Destination:
Output folder: ask later
Output type: tracks into individual files
File name pattern: %directory%/%filename%
Processing: none
Other:
When finished:
* Copy other files: "*.html;*.doc;*.docx;*.rtf;*.pdf;*.gif;*.jpg;*.jpeg;*.png;*.psd;*.tif;*.tiff;*.txt;*.nfo;*.cue;*
.m3u
Advanced Foobar settings > Tools > Converter > Thread count was 0, resulting in 8 simultaneous conversions. Later changed to 4.
Advanced Foobar settings > Tools > Converter > Thread priority was 2, changed to 5 when changing thead count.
3 Screenshots (from my Dropbox):
Taskmgr screenie of CPU usage (including some idle seconds after completion).
Start of mp3 & source file (top: mp3; bottom: flac)
End of mp3 & source file (aligned start) (top: mp3; bottom: flac)
Here's what the console log says
CLI encoder: lame.exe
Destination file: D:\[...]Band1973-07-31 d1t02.mp3
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t02.mp3"
Working folder: D:\[...]
Destination file: D:\[...]Band1973-07-31 d1t03.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t03.mp3"
Destination file: D:\[...]Band1973-07-31 d1t01.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t01.mp3"
Destination file: D:\[...]Band1973-07-31 d1t04.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t04.mp3"
Encoder process still running, waiting...
Encoder process terminated cleanly.
Track converted successfully.
Destination file: D:\[...]Band1973-07-31 d1t05.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t05.mp3"
Destination file: D:\[...]Band1973-07-31 d1t06.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t06.mp3"
Destination file: D:\[...]Band1973-07-31 d1t07.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t07.mp3"
Destination file: D:\[...]Band1973-07-31 d1t08.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t08.mp3"
Destination file: D:\[...]Band1973-07-31 d1t09.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t09.mp3"
Destination file: D:\[...]Band1973-07-31 d1t10.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t10.mp3"
Destination file: D:\[...]Band1973-07-31 d1t11.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t11.mp3"
Destination file: D:\[...]Band1973-07-31 d1t12.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t12.mp3"
Destination file: D:\[...]Band1973-07-31 d1t13.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d1t13.mp3"
Destination file: D:\[...]Band1973-07-31 d2t01.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t01.mp3"
Destination file: D:\[...]Band1973-07-31 d2t02.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t02.mp3"
Destination file: D:\[...]Band1973-07-31 d2t03.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t03.mp3"
Destination file: D:\[...]Band1973-07-31 d2t04.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t04.mp3"
Destination file: D:\[...]Band1973-07-31 d2t05.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t05.mp3"
Destination file: D:\[...]Band1973-07-31 d2t06.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t06.mp3"
Destination file: D:\[...]Band1973-07-31 d2t07.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t07.mp3"
Destination file: D:\[...]Band1973-07-31 d2t08.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t08.mp3"
Destination file: D:\[...]Band1973-07-31 d2t09.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t09.mp3"
Destination file: D:\[...]Band1973-07-31 d2t10.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-07-31 d2t10.mp3"
Destination file: D:\[...]Band1973-08-01 d1t01.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t01.mp3"
Destination file: D:\[...]Band1973-08-01 d1t02.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t02.mp3"
Destination file: D:\[...]Band1973-08-01 d1t03.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t03.mp3"
Destination file: D:\[...]Band1973-08-01 d1t04.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t04.mp3"
Destination file: D:\[...]Band1973-08-01 d1t05.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t05.mp3"
Destination file: D:\[...]Band1973-08-01 d1t06.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t06.mp3"
Destination file: D:\[...]Band1973-08-01 d1t07.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t07.mp3"
Destination file: D:\[...]Band1973-08-01 d1t08.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t08.mp3"
Destination file: D:\[...]Band1973-08-01 d1t09.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t09.mp3"
Destination file: D:\[...]Band1973-08-01 d1t10.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t10.mp3"
Destination file: D:\[...]Band1973-08-01 d1t11.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d1t11.mp3"
Destination file: D:\[...]Band1973-08-01 d2t01.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t01.mp3"
Destination file: D:\[...]Band1973-08-01 d2t02.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t02.mp3"
Destination file: D:\[...]Band1973-08-01 d2t03.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t03.mp3"
Destination file: D:\[...]Band1973-08-01 d2t04.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t04.mp3"
Destination file: D:\[...]Band1973-08-01 d2t05.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t05.mp3"
Destination file: D:\[...]Band1973-08-01 d2t06.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t06.mp3"
Destination file: D:\[...]Band1973-08-01 d2t07.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t07.mp3"
Destination file: D:\[...]Band1973-08-01 d2t08.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t08.mp3"
Destination file: D:\[...]Band1973-08-01 d2t09.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t09.mp3"
Destination file: D:\[...]Band1973-08-01 d2t10.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t10.mp3"
Destination file: D:\[...]Band1973-08-01 d2t11.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band1973-08-01 d2t11.mp3"
Destination file: D:\[...]Band 1983-11-23 01.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 01.mp3"
Destination file: D:\[...]Band 1983-11-23 02.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 02.mp3"
Destination file: D:\[...]Band 1983-11-23 03.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 03.mp3"
Destination file: D:\[...]Band 1983-11-23 04.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 04.mp3"
Writing tags to encoded file failed: File is already in use
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 01.mp3"
Destination file: D:\[...]Band 1983-11-23 05.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 05.mp3"
Destination file: D:\[...]Band 1983-11-23 06.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 06.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 02.mp3"
Destination file: D:\[...]Band 1983-11-23 07.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 07.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 05.mp3"
Destination file: D:\[...]Band 1983-11-23 08.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 08.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 04.mp3"
Destination file: D:\[...]Band 1983-11-23 09.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 09.mp3"
Destination file: D:\[...]Band 1983-11-23 10.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 10.mp3"
Destination file: D:\[...]Band 1983-11-23 11.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 11.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 08.mp3"
Destination file: D:\[...]Band 1983-11-23 12.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 12.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 09.mp3"
Destination file: D:\[...]Band 1983-11-23 13.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 13.mp3"
Destination file: D:\[...]Band 1983-11-23 14.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 14.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 11.mp3"
Destination file: D:\[...]Band 1983-11-23 15.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 15.mp3"
Destination file: D:\[...]Band 1983-11-23 16.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 16.mp3"
Destination file: D:\[...]Band 1983-11-23 17.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 17.mp3"
Destination file: D:\[...]Band 1983-11-23 18.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 18.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 15.mp3"
Destination file: D:\[...]Band 1983-11-23 19.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 19.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 16.mp3"
Destination file: D:\[...]Band 1983-11-23 20.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 20.mp3"
Destination file: D:\[...]Band 1983-11-23 21.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-11-23 21.mp3"
Destination file: D:\[...]Band 1983-08-27 PII.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1983-08-27 PII.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 19.mp3"
Destination file: D:\[...]Band 1984-03-08 01.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 01.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 20.mp3"
Destination file: D:\[...]Band 1984-03-08 02.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 02.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1983-11-23 21.mp3"
Destination file: D:\[...]Band 1984-03-08 03.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 03.mp3"
Destination file: D:\[...]Band 1984-03-08 04.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 04.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 01.mp3"
Destination file: D:\[...]Band 1984-03-08 05.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 05.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 02.mp3"
Destination file: D:\[...]Band 1984-03-08 06.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 06.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 03.mp3"
Destination file: D:\[...]Band 1984-03-08 07.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 07.mp3"
Destination file: D:\[...]Band 1984-03-08 08.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 08.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 06.mp3"
Destination file: D:\[...]Band 1984-03-08 09.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 09.mp3"
Destination file: D:\[...]Band 1984-03-08 10.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 10.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 07.mp3"
Destination file: D:\[...]Band 1984-03-08 11.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 11.mp3"
Destination file: D:\[...]Band 1984-03-08 12.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 12.mp3"
Destination file: D:\[...]Band 1984-03-08 13.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 13.mp3"
Destination file: D:\[...]Band 1984-03-08 14.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 14.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 12.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 13.mp3"
Destination file: D:\[...]Band 1984-03-08 15.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 15.mp3"
Destination file: D:\[...]Band 1984-03-08 16.mp3
Command line: "C:\[...]TLH 2.7.0\CmdlineApps\lame.exe" -S --noreplaygain -V 2 - "Band 1984-03-08 16.mp3"
Copied to: D:\[...]Band1973-07-31+08-01.txt
Copied to: D:\[...]The Band Roosevelt 73.pdf
Copied to: D:\[...]xBand1973-07-31 d1 md5.txt
Copied to: D:\[...]xBand1973-07-31 d2 md5.txt
Copied to: D:\[...]xBand1973-08-01 d1 md5.txt
Copied to: D:\[...]xBand1973-08-01 d2 md5.txt
Copied to: D:\[...]The Band 1983-11-23.txt
Copied to: D:\[...]The Band 1984-03-08.txt
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 15.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 14.mp3"
An error occurred while finalizing the encoding process (File is already in use) : "D:\[...]Band 1984-03-08 16.mp3"
Total encoding time: 2:43.521, 133.23x realtime
Properties dialog refresh: 0:00.000069
Properties dialog display refresh: 0:00.005400
Shutting down...
It seems there is no real issue with the files since they're the same each time and they don't seem flawed (except for those gaps). I'd appreciate not getting false alarms all the time so that I can see when there's a real problem. Please let me know whether I can prevent this error from happening by changing some settings or if you need additional info to determine the source of this error.
Wheat_King
P.S.:
Yes, I did a few searches (here, google) to find info on this error - to no avail.
Yes, I did read the rules for the fb2k support forum.
If I have overseen something, please point it out.
Try to convert to a folder that is outside of fb2k media library.
Hi lvqcl,
thanks for your reply.
I haven't used the media library so far. It's empty, source and target are on another partition than the default library folders.
Wheat_King
