Topic: Please rate my foobar double abx blind test? (Read 5689 times) previous topic - next topic
foo_abx 1.3.4 report
foobar2000 v1.1.11
2012/07/27 00:58:16
File A: C:\Documents and Settings\RueK\Mis documentos\Mi música\D#4\TRACK (451).flac
File B: C:\Documents and Settings\RueK\Mis documentos\TRACK (451).mp3
00:58:16 : Test started.
00:59:17 : 01/01  50.0%
00:59:58 : 01/02  75.0%
01:01:00 : 01/03  87.5%
01:01:36 : 01/04  93.8%
01:04:11 : 02/05  81.3%
01:05:02 : 03/06  65.6%
01:06:11 : 04/07  50.0%
01:06:49 : 05/08  36.3%
01:07:19 : 06/09  25.4%
01:07:48 : 06/10  37.7%
01:08:15 : 06/11  50.0%
01:09:02 : 07/12  38.7%
01:09:26 : 07/13  50.0%
01:09:37 : 08/14  39.5%
01:09:58 : 08/15  50.0%
01:10:53 : 09/16  40.2%
01:11:16 : 10/17  31.5%
01:11:33 : 11/18  24.0%
01:11:59 : 12/19  18.0%
01:12:33 : 13/20  13.2%
01:13:00 : 14/21  9.5%
01:13:18 : 15/22  6.7%
01:13:38 : 16/23  4.7%
01:13:57 : 16/24  7.6%
01:14:31 : 17/25  5.4%
01:15:34 : 18/26  3.8%
01:16:09 : 18/27  6.1%
01:16:24 : 18/28  9.2%
01:16:54 : 19/29  6.8%
01:18:13 : 20/30  4.9%
01:18:44 : 20/31  7.5%
01:19:04 : 20/32  10.8%
01:19:55 : 21/33  8.1%
01:20:07 : 22/34  6.1%
01:20:59 : 22/35  8.8%
01:26:27 : 22/36  12.1%
01:26:54 : 22/37  16.2%
01:27:08 : 23/38  12.8%
01:33:56 : 24/39  10.0%
01:34:14 : 24/40  13.4%
01:35:01 : 24/41  17.4%
01:35:06 : Trial reset.                <--- after this i was just playing as i gave up so dont take the rest seriously.
01:35:34 : 00/01  100.0%
01:35:41 : Trial reset.
01:36:07 : 00/01  100.0%
01:36:33 : 00/02  100.0%
01:36:50 : 00/03  100.0%
01:36:55 : Trial reset.
01:36:56 : Trial reset.
01:37:21 : 01/01  50.0%
01:37:26 : Trial reset.
01:37:32 : 00/01  100.0%
01:37:33 : Trial reset.
01:37:35 : 01/01  50.0%
01:37:37 : Trial reset.
01:37:39 : 00/01  100.0%
01:37:40 : Trial reset.
01:37:41 : 00/01  100.0%
01:37:42 : Trial reset.
01:37:43 : 00/01  100.0%
01:37:44 : Trial reset.
01:37:45 : 01/01  50.0%
01:37:46 : Trial reset.
01:37:47 : 00/01  100.0%
01:37:48 : Trial reset.
01:37:50 : Trial reset.
01:37:52 : Trial reset.
01:37:55 : Trial reset.
01:37:56 : 00/01  100.0%
01:38:01 : Test finished.
Total: 27/54 (55.4%)
it was pretty hard, i was using my 30$ 2.1 speakers, it was a normal pop song, well encoded 320 kbps using the maximum possible settings cbr and the lossless file (which had a 22.1 khz cutoff)
So i know the total result i messed up thanks to me playing with the abx extension of foobar i didnt know the results could be saved after pressing the exit button but what do you think of my hearing? this was my first test of this kind.
You've demonstrated that you probably can't hear any differences between that FLAC and its mp3.
For fun, try a really low quality mp3, and see what happens.
really low quality like? 32 kbps? 128? i will try then thanks for your feedback.
Something like VBR v9, yes. Just to know what extreme compression sounds like — it might even sound better than you first thought, and it will prevent you from hearing artifacts in high quality mp3s where none exist, since you become familiar with how actual artifacts sound, instead of imagined ones.
Well, you did reach <5% at 18/26, but there was a lot of oscillation between correct and incorrect guesses before that, so that p-value alone may not be very indicative of much of a genuine effect; someone better versed in the relevant statistics can elaborate on this.
But yes, everything after that is rubbish! So why bother including it?
Because a set of 100%'s looks to the uninitiated like a list of straight As. Obviously super-good, right?
