Topic: Why is portable performance slower than standard installation? (Read 9201 times) previous topic - next topic
this thread seems very specific about the additional foo_uie_albumlist component that you can download to use with columns UI. if you're having the same problem, nothing is going to happen because development was abandoned years ago. you can always remove the panel and use main album list from the Library menu. obviously this will appear as a floating window rather than embedded in your layout.
if your problem is not related to this panel/columns, you should start your own thread.
