Topic: 32-bit capable DACs (Read 51627 times) previous topic - next topic
32-bit capable DACs
It ist even worse in the case microphones are involved, because the output signal of a average microphone without amplifier is only around -40 dBm, but the noise level is at around -130 dBm. Therefore 90 dB S/N is the best you can get in this case.
Amplifers produce additional noise. You simply can't lower the level of noise by using amplifiers.
Ouch You have just messed up dBm and dB again.
The noise level in a good silent studio is around (well, it's already pretty ideally)  -120 dB, not -120 dBm. Because -120dBm is much less than -120dB (-120 dBm = -150dB -> it's too low for real-life noise).
32-bit capable DACs
I'm not talking about the level auf acoustic noise in the studio or atmosphere, Igor. I'm talking about the noise level in electrical parts, wires, circuits.
The difference between -130 dBm and -40 dBm is 90 dB, because the in the calculation of a difference of levels the reference level of 1 mW will be discarded.
So the limitation of S/N is in the electrical domain, not in the possible difference in air pressure.
You can shift the level of loudness, yes, but in the electrical domain S/N will stay the same.
32-bit capable DACs
Yes,S/N will remain the same.  It's true.
But there is no ADC with  such low noise -130 dBm (-160dB). -130 dB maybe. -130 dBm - science fiction.
32-bit capable DACs
For real audio resolution, the number to look for is the THD+N.
Can You defend this statement with some additional information?
Then why include Dynamic Range into specification? Just go for THD+N, right?
The final product is the music. Whatever is not music should be cosidered as altering the original signal. Therefore, for real resolution, you need to look at THD+N numbers. S/N is just the "N" part of that sum. Unless you really like the specific distortions... case for many tube-lovers.
Anyway I am saying that  the physically limit of the human hearing is around 21-22 dB. Even the thermal noise of the air molecules in a 25C room is at that level. There is absolutelly no point for more than 24 bit (at 96kHz) reproduction of audio signals destined to be heard by humans.
DR, as is defined, is kind of a marketing tool. Is the SNR measured at -60dB of the full scale and at the value obtained, add 60dB. Well, that tells how good is the system at low level reproduction, but the distortions are really creeping up at higher levels, close to 0dB. Is was a desperate attmpt to hide the glitching distortion in early multibit DAC's. Not usefull today when all the DAC's have a zero-detection circuit that mutes the output when "zero" PCM code is detected.
32-bit capable DACs
Yes, there is no ADC with this low noise level and the consequence is there is no point designing or producing ADC oder DAC that uses more than 24 Bit of (integer) sample depth.
Are there ADC or DAC using 32 bit floating-point for conversation or internal format?
I agree with you.
32-bit capable DACs
As for ADC reality:
In my E-MU 1820m I have one of the best ADC around, same like in ProTools professional mastering gear: AK5394A. That is capable of "only" THD+N=-110dB... True 18 bits.
Higher level than that there is the DAD-AX24 with THD+N at -115dB (true 19bits) for 10 times the price.
From my findings, many of the old recordings are at a very poor quality comparativelly, derived from the original master analog tapes. Even if they are sold in DVD-A, SACD or digital 24/96 formats, they are actually below the capabilities of 16 bit and with max bandwidth limited often at 17- 18kHz...
Newer recordings have bandwidth brickwalled at 20kHz and are compressed in such a manner that the true dynamic is only at 12-13 bit resolution level (at best).
32-bit capable DACs
I'm quite surprised by some people's reactions, it has been stated here that both ASIO and WASAPI provide no advantage whatsoever over DS therefore being as pointless as 32bit output so, why not ditch these plugins altogether? the same could possibly said about FLAC, APE or any other lossless codec that provides no audible advantage over well encoded 192Kbps, and so on and so forth.
Because that difference is sometimes audible, and always measurable. Whereas 24-bits vs more than 24-bits is, AFAIK, completely and utterly undetectable anywhere in the analogue audio world.
David.
32-bit capable DACs
Reply #32
That's useful! "-120dB" means "one million times smaller than" - so "the noise level in a good silent studio is around one millions times smaller than..." what?!
FWIW I don't know of any studios that are sound proofed down to 0dB SPL across the audible range (around 20dB SPL is a common target, rarely reached across the board) - but even if they exist, you'd better hope that the musicians don't ruin it by breathing.
David.
32-bit capable DACs
I wonder if the “32 bit DAC” has anything to do with dynamic range.
ESS Sabre is advertised as a 32 bit “DAC” simply because they do some DSP (probably ASRC to reduce jitter) and they do so in 32 bit float hence the 32 bit.
Audio editors often allows you to store the project in float.
You don’t want a quantization error each time you save your work.
Can imagine it is convenient to feed this straight into a DAC
In the computer world 24 is a weird number.
8/16/32/64/128 are the common word length.
Might be convenient to keep your audio in 32 or 64 when processing.
TheWellTemperedComputer.com
32-bit capable DACs
Reply #34
Your reaction is to expect. But if You look into the context of this particular discussion and I've mentioned that those are ideal (pretty unrealistic) numbers.
And yes, those SPL numbers are available even on wiki for easy reading. I was perfectly aware of them. Thank You.
The message was the other.
32-bit capable DACs
Reply #35
32 bit float has only a 23 bit mantissa, so I tend to think most stuff using floating point uses doubles.
Anyway, DACs take integer precision, not fp, so whatever you are working with is irrelevant.  Its going to be cast to whatever packed integer format the DAC specifies.  Its not like your software even knows that though, the driver keeps the DAC and your programs quite separate.
32-bit capable DACs
Reply #36
No audible advantage. (Disregard broken software or hardware.) But they exist exactly to provide their other advantages, such as low latency, exclusive access, etc. This has been gone over many times.
Even if the above were not misunderstood, this would not follow from it. Lossless archiving has objective advantages completely separate from any discussion of perceptual transparency: archival and future-proofing are the main ones I can offer now, but that’s not all.
32-bit capable DACs
Reply #37
No need to totally disregard, either, as this is one of the other valid reasons for using these outputs. I found WASAPI output in a Windows VirtualBox to be more reliable than DS.
32-bit capable DACs
Reply #38
And I experienced the same in my wine+foobar2000 endeavours.
32-bit capable DACs
Reply #39
But I needed a DAC that could accurately play back a recording of a mouse farting during a space shuttle launch!
32-bit capable DACs
Reply #40
Oh, I thought you were telling someone they weren't using "dB" correctly, before giving an example that was incorrect by a factor of one million.
32-bit capable DACs
Reply #41
But from precisely how many yards are you recording the mouse fart? It changes everything!
32-bit capable DACs
Reply #43
Breathing can be part of recorded program.  So your treament of it like some unwanted noise is wrong.
Overplayed.
Show me where my statement was by a factor of one million time wrong.
I think You can apply now your criticism  to your  very own post.
32-bit capable DACs
Reply #44
BTW, got any idea what the output of the finest microphone in the world would be like under those circumstances?
Not pretty!
32-bit capable DACs
Reply #45
Take a DAC with -130 dB noise referenced some higher level than 0 dBm, add a properly designed resistive divider with maybe an op amp buffer, and viola, -130 dBm noise levels.
I believe that there are now commercial DACs with -130 dB FS noise - ESS Sabre DACs.
There are several other DACs that come close Probably very little but money keeps you from connecting a bunch of them in parallel in such away that the noise drops -3 dB every time you double the number of DACs connected in parallel.
32-bit capable DACs
Reply #46
No, it is a good spec, but yes it is incomplete if you want to know what is going on in all relevant conditions. That's why spec sheets have more than one number on them!
Which is a good thing to know, no?
Agreed, so we have other specs to characterize them. We expect to see more than one number!
No, it was an effective attempt to expose low level glitching which was far more common before Delta-Sigma converters became the rule.
There is no such thing in general.  You need to study up on how modern converters work.
32-bit capable DACs
Reply #47
Quoting a real world sound level as "-120dB".
No units /  1M times wrong in the implied units - take your pick - a physics teacher would fail you either way.
Which isn't the kind of thing I'd usually be so uncharitable as to criticise - but you were laughing at naturfreak for a much smaller error.
I do agree we don't need too many bits. I can hear breathing perfectly well on 16-bit recordings.
David.
32-bit capable DACs
Reply #48
I've mention it with that reference level because if not it would just confuse more Naturefreak.  See discussion first.
A physics teacher would fail you teaching that different measurements can mean the same with different reference levels.
And I've already mention why I did it this way.
You pick a  wrong person here to teach about sound pressure  levels and unit of measurements.    Wrong person, wrong topic.
The idea was to make soft a correction. But I can see that smile icon was interpreted some aggressive way of laughing out.
32-bit capable DACs
Reply #49
Now you upset me...
Want examples? AK4683, page 1 "Zero Detect Function". PCM1794, page 1 "Zero Flag" (mute external or internal "soft mute"). CS4398, pags 21 explains the "Mute Control": "use of the Mute Control function can enable the system designer to achieve idle channel noise/signal-to-noise ratios which are only limited by the external mute circuit". All the sigma-delta DAC's will output HF garbage if not muted, as opposed to old-school AD1955 page 1 specifies that SNR is 120dB "not muted".
THD+N is the ONLY realistic number that tells the accuracy of audio output. SNR is just a part of that number.
