Topic: Convert command destination script - remove smart quotes (Read 1032 times) previous topic - next topic
Can anyone suggest a way to remove smart quotes (and replace them with dumb quotes) in track titles?
For example, change:
I’ve Got a Feeling
to
I've Got a Feeling
I'd like the change to happen when I use the "Convert" command. My current destination script for the Convert command is:
%album artist%/[$cut(%date%,4) - ]%album%/%discnumber%.%tracknumber% - %title%
How can I modify %title% to replace smart quotes with dumb quotes?
What if I want to do the reverse? Change dumb quotes to smart? This is probably harder...
$replace(%title%,’,'')
$replace(a,b,c)
Replaces all occurrences of string b in string a with string c.
Can also be used with an arbitrary number of arguments. Note that $replace(a,b1,c1,b2,c2) is generally not the same as $replace($replace(a,b1,c1),b2,c2).
Example: $replace(ab,a,b,b,c) → "bc", $replace($replace(ab,a,b),b,c) → "cc"
note: The value of C in my example ['](apostrophe / single quote / dumb quote) is purposely doubled.
' (single quotation mark)
Inserts specified text bypassing syntax processing; allows special characters such as %,$,[,] to be inserted. In order to insert a quotation mark character, use '' (two single quotation marks).
