Topic: foo_midi crashes sometimes (Read 1890 times) previous topic - next topic
Sometimes foobar2000 crashes after midi file played to the end. I believed it was because I was switching between BASSMIDI and VSTi modes all the time, but last time it just crashed after playing single midi file few times and I did not touch any options. I've got some crash reports and involved midi files zipped, maybe that can help to shoot the bug: foo_midi_crash.zip
What SoundFonts are you using?
Usually, I use SFLIST with these two soundfonts inside:
Fluid R3 GM.sf2
Fluid R3 GS+SFX Portion.sf2
They are taken from Ubuntu packages fluid-soundfont-gm and fluid-soundfont-gs. But I think it crashed with other soundfonts too.
I can't reproduce the issue with those MIDI files, but the crashes appear to occur irrelevant to which MIDI file is being played. I'll forward the crash dumps to Ian, but I don't know if he'll be able to do anything with only mini dumps.
Is there anything else I can do when it crashes again?
Sending you a PM with further instructions.
