Topic: foo-tunes (Read 21023 times) previous topic - next topic
foo-tunes
Turns out the script needs be run using the 32 bit wscript.exe in Win 7 64 bit. I was able to resolve this by replacing the contents of sync.cmd with:
Thanks for bug report. Added an issue
https://github.com/kompot/foo-tunes/issues/8
Where does it fail now?
I can't say it's actually failing anymore but there seems to be many instances where particular files simply wont transfer to the iphone, even though they were all created at the same time with the same converter settings as files that did sync correctly. Album art doesn't seem to get copied in any case; I'm using 1000x1000 res folder.jpg's. Also, I have two ios devices that I sync music to, which is a pain in the ass using this solution.
I'm just going to keep on using ios 4 and foo_dop for the time being until this or some other component matures. While I'd love to switch to an andriod device, being able to sync playback stats between f2k and the ipod is a huge bonus that I don't think I can pass up.
foo-tunes
Does this work with 5.0.1?
EDIT: After looking at the files, not very interested if it's booting iTunes anyway and requires a separate folder for the music I want to sync.
foo-tunes
Thanks for developing this!
I just wanted to comment that I was a little confused when i started using this tool, and it did not copy any files
The reason is because the foo-tunes code checks for files that exist in subfolders of the musicNotTrackedPath, but originally i was just copying files to the musicNotTrackedPath
Here's a log file for it working once i added a 'sub' folder.
Hopefully some of the 'philosophical' differences between this and foo-dop can be worked out soon otherwise people are just going to go back to using itunes  !!!
foo-tunes
Hopefully some of the 'philosophical' differences between this and foo-dop can be worked out soon otherwise people are just going to go back to using itunes  :P !!!
(Un)fortunately I recently moved to MacBook and will not do any further updates to foo-tunes. But feel free to fork and modify code if you like. Now trying to get foobar2000 sync with iTunes on Mac - no luck still ;( TextTools component doesn't work very well with X11 on Mac when trying to copy too much text.
foo-tunes
Well, now that we have been forced to put up with the iOS 5 agony for some time now I'd say I have become more desperate to find a foobar-friendly method of music transfer to the iTunes database.    So I just want to say thanks to kompot for all the effort up to this point, and will try to leave the memory of foo_dop behind and look forward to new horizons... FB2K is just too good at music management, and the iPod is just too good of a player, and in-between is this bloated, presumptuous, arrogant, ignorant iTunes.  grrrrrrrrrrr
foo-tunes
Does anyone know how to get ipod scrobbles using this type of plugin? I'm trying to understand this FAQ http://www.last.fm/help/faq?category=105 but it's not clear to me how they use the term "sync"
For example under the section "Can I scrobble from an iPod that is manually managed?"
Manually managed iPods require you to manually transfer tracks to your iPod using iTunes. You can only scrobble manual iPods after the first time they are synced with iTunes.
Currently I don't get any scrobbles so I was wondering what I should do
foo-tunes
Reply #32
I get errors when running foo-tunes. Here is a log file:
DEBUG 2012-12-05 17:45:32     going to run command "c:\Program Files\foobar2000\foobar2000.exe" "/command:Rescan Folders"
DEBUG 2012-12-05 17:45:32    sources count 3
INFO  2012-12-05 17:45:32    iPod `iPod de Martin et Geneviève` found, free space 81%
DEBUG 2012-12-05 17:45:32    Playlists count 11
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Mémos vocaux
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Musique classique
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Morceaux récents
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Meilleur classement
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Les 25 plus écoutés
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Années 90
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Ajouts récents
DEBUG 2012-12-05 17:45:32    iPod playlist found 1 iPod de Martin et Geneviève
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Séries TV
DEBUG 2012-12-05 17:45:32    iPod playlist found 2 Films
DEBUG 2012-12-05 17:45:32    caching tracks from iPod library
DEBUG 2012-12-05 17:45:33    "c:\Program Files\foobar2000\foobar2000.exe" /runcmd-files="Copy: iTunesSync"  c:\temp\Anne-Marie\musique-Ipod\
DEBUG 2012-12-05 17:45:33    going to run command "c:\Program Files\foobar2000\foobar2000.exe" /runcmd-files="Copy: iTunesSync"  c:\temp\Anne-Marie\musique-Ipod\
DEBUG 2012-12-05 17:45:33    Still no info from foobar2000. Sleeping for 1 sec
DEBUG 2012-12-05 17:45:34    playback stats from foobar2000 = {"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\01-Marie-Hélène.m4a", "Rating": "?", "PlayedCount": "4", "PlayedDate": "2012-09-29 15:04:54", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\02-Qui saura jamais.m4a", "Rating": "?", "PlayedCount": "1", "PlayedDate": "2012-08-24 18:17:20", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\03-Aquarelle.m4a", "Rating": "?", "PlayedCount": "0", "PlayedDate": "N/A", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\04-Programme double.m4a", "Rating": "?", "PlayedCount": "5", "PlayedDate": "2012-03-03 19:44:55", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\05-L'embellie.m4a", "Rating": "?", "PlayedCount": "1", "PlayedDate": "2011-12-21 14:47:25", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\06-Drôle de pays.m4a", "Rating": "?", "PlayedCount": "0", "PlayedDate": "N/A", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\07-Le fleuve.m4a", "Rating": "?", "PlayedCount": "2", "PlayedDate": "2012-03-03 19:57:21", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\08-Country song.m4a", "Rating": "?", "PlayedCount": "1", "PlayedDate": "2011-07-31 09:28:56", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\09-Chanson de Pierrot.m4a", "Rating": "?", "PlayedCount": "1", "PlayedDate": "2011-12-21 14:43:41", "DateAdded": "2010-12-08 00:44:45"},
{"Location": "C:\\temp\\Anne-Marie\\musique-Ipod\\Sylvain Lelièvre\\Programme double\\10-Toi l'ami.m4a", "Rating": "?", "PlayedCount": "0", "PlayedDate": "N/A", "DateAdded": "2010-12-08 00:44:45"},
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\01-Marie-Hélène.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\02-Qui saura jamais.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\03-Aquarelle.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\04-Programme double.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\05-L'embellie.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\06-Drôle de pays.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\07-Le fleuve.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\08-Country song.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\09-Chanson de Pierrot.m4a
INFO  2012-12-05 17:45:34    adding C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\10-Toi l'ami.m4a
DEBUG 2012-12-05 17:45:34    "c:\Program Files\foobar2000\foobar2000.exe" /tag:"FORMAT:ALBUMSORTORDER:%album artist% %date% %album%";"FORMAT:ITUNESCOMPILATION:$if($stricmp($meta(album artist),various artists),1,)"; "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\01-Marie-Hélène.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\02-Qui saura jamais.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\03-Aquarelle.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\04-Programme double.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\05-L'embellie.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\06-Drôle de pays.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\07-Le fleuve.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\08-Country song.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\09-Chanson de Pierrot.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\10-Toi l'ami.m4a"
DEBUG 2012-12-05 17:45:34    going to run command "c:\Program Files\foobar2000\foobar2000.exe" /tag:"FORMAT:ALBUMSORTORDER:%album artist% %date% %album%";"FORMAT:ITUNESCOMPILATION:$if($stricmp($meta(album artist),various artists),1,)"; "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\01-Marie-Hélène.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\02-Qui saura jamais.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\03-Aquarelle.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\04-Programme double.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\05-L'embellie.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\06-Drôle de pays.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\07-Le fleuve.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\08-Country song.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\09-Chanson de Pierrot.m4a"  "C:\temp\Anne-Marie\musique-Ipod\Sylvain Lelièvre\Programme double\10-Toi l'ami.m4a"
DEBUG 2012-12-05 17:45:34    Not all files having tags applied; still 10 left. Sleeping for 1 sec
DEBUG 2012-12-05 17:45:35    Not all files having tags applied; still 5 left. Sleeping for 1 sec
DEBUG 2012-12-05 17:45:36    Not all files having tags applied; still 2 left. Sleeping for 1 sec
DEBUG 2012-12-05 17:45:37    Not all files having tags applied; still 1 left. Sleeping for 1 sec
DEBUG 2012-12-05 17:45:38    processing tags finished; left = 0
ERROR 2012-12-05 17:45:38    Error occured. Exiting. The playlist is not modifiable.
Any idea of what could be wrong?
foo-tunes
Forgot to give some details:
Windows 7, Ipod 5, iOS 6.01, last iTunes
Is the error "The playlist is not modifiable" a communication error with the Ipod?
