Topic: Repeated, seemingly random crashes when closing foobar (Read 2225 times) previous topic - next topic
Like the title says, when I close foobar (either while a song is playing or it's not), foobar crashes. I see something about MSVCR80.dll_unloaded, and searching hasn't brought up much information. Here's the info:
Problem signature:
  Problem Event Name:   BEX
  Application Name:   foobar2000.exe
  Application Version:   1.1.9.0
  Application Timestamp:   4eb3f1e7
  Fault Module Name:   MSVCR80.dll_unloaded
  Fault Module Version:   0.0.0.0
  Fault Module Timestamp:   4dcddbf3
  Exception Offset:   73138ced
  Exception Code:   c0000005
  Exception Data:   00000008
  OS Version:   6.1.7601.2.1.0.256.48
  Locale ID:   4105
  Additional Information 1:   3f75
  Additional Information 2:   3f75bb4e531e9431ce48e18d64698afb
  Additional Information 3:   3f75
  Additional Information 4:   3f75bb4e531e9431ce48e18d64698afb
I have tried removing all third-party components, and the crash does not occur. When I re-add components one-by-one and try closing foobar, the crash occurs again, but it's with a different component each time.
My best guess is that I'm missing some kind of Windows dependency. I have MS Visual C++ runtimes installed, so I'm not sure what it is. A fresh install of foobar doesn't fix the problem. I am using the latest version, on Window 7 64-bit.
Any help would be appreciated, thank you!
Components installed:
Core (2011-11-04 14:08:40 UTC)
    foobar2000 core 1.1.9
foo_ac3.dll (2011-11-10 00:29:34 UTC)
    AC3 decoder 0.9.5
foo_albumlist.dll (2011-11-04 14:07:12 UTC)
    Album List 4.5
foo_audioscrobbler.dll (2011-11-10 00:29:34 UTC)
    Audioscrobbler 1.4.7
foo_autoupdate.dll (2011-11-10 00:29:34 UTC)
    Automatic Updater 1
foo_burninate.dll (2011-11-10 00:29:34 UTC)
    Audio CD Writer 3.0.3
foo_cdda.dll (2011-11-04 14:07:04 UTC)
    CD Audio Decoder 3.0
foo_chacon.dll (2011-11-10 00:29:34 UTC)
    Chacon 3
foo_channel_mixer.dll (2011-11-10 00:29:34 UTC)
    Channel Mixer 0.9.6.7
foo_converter.dll (2011-11-04 14:06:48 UTC)
    Converter 1.5
foo_discogs.dll (2011-11-10 00:29:34 UTC)
    Discogs Tagger 1.30
foo_dop.dll (2011-11-10 00:29:34 UTC)
    iPod manager 0.6.9.7
foo_dsp_crossfeed.dll (2011-11-10 00:29:34 UTC)
    Crossfeed 1.01
foo_dsp_effect.dll (2011-11-10 00:29:34 UTC)
    Effect DSP 0.9.2
foo_dsp_resampler.dll (2011-11-10 00:29:34 UTC)
    SoX Resampler 0.7.0
foo_dsp_std.dll (2011-11-04 14:07:12 UTC)
    Standard DSP Array 1.0
foo_dsp_xgeq.dll (2011-11-10 00:29:34 UTC)
    Graphic Equalizer 0.2.1
foo_facets.dll (2011-11-10 00:29:34 UTC)
    Facets 1.0
foo_fileops.dll (2011-11-04 14:06:12 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2011-11-04 14:06:12 UTC)
    freedb Tagger 0.6.4
foo_input_alac.dll (2011-11-10 00:29:34 UTC)
    ALAC Decoder 1.0.7
foo_input_ds.dll (2011-11-10 00:29:34 UTC)
    DirectShow input 0.1
foo_input_dsdiff.dll (2011-11-10 00:29:34 UTC)
    DSDIFF Decoder 1.4
foo_input_dtshd.dll (2011-11-10 00:29:34 UTC)
    DTS-HD Decoder 0.1.3
foo_input_dvda.dll (2011-11-10 00:29:34 UTC)
    DVD-Audio Decoder and Watermark Detector 0.4.8
foo_input_ht.dll (2011-11-10 00:29:34 UTC)
    Highly Theoretical 2.0.7
foo_input_monkey.dll (2011-11-10 00:29:34 UTC)
    Monkey's Audio Decoder 2.1.5
foo_input_reverse.dll (2011-11-10 00:29:34 UTC)
    Reverse Playback 0.1.4 (SSE)
foo_input_sacd.dll (2011-11-10 00:29:34 UTC)
    Super Audio CD Decoder 0.4.0
foo_input_std.dll (2011-11-04 14:06:56 UTC)
    Standard Input Array 1.0
foo_input_tak.dll (2011-11-10 00:29:34 UTC)
    TAK Decoder 0.4.4
foo_input_tta.dll (2011-11-10 00:29:34 UTC)
    TTA Audio Decoder 3.1
foo_jesus.dll (2011-11-10 00:29:34 UTC)
    Autosave & Autobackup 10
foo_masstag.dll (2011-11-10 00:29:34 UTC)
    Masstagger 1.8.4
foo_masstag_addons.dll (2011-11-10 00:29:34 UTC)
    Masstagger Addons 0.3.4 (SSE)
foo_out_asio.dll (2011-11-10 00:29:34 UTC)
    ASIO support 1.2.7
foo_out_ks.dll (2011-11-10 00:29:34 UTC)
    Kernel Streaming Output 1.2.2
foo_out_wasapi.dll (2011-11-10 00:29:34 UTC)
    WASAPI output support 2.1
foo_playcount.dll (2011-11-10 00:29:34 UTC)
    Playback Statistics 3.0.2
foo_random.dll (2011-11-10 00:29:34 UTC)
    Randomized Playlist Entry 1.2.3
foo_rgscan.dll (2011-11-04 14:06:54 UTC)
    ReplayGain Scanner 2.1.2
foo_simplaylist.dll (2011-11-10 00:29:34 UTC)
    SimPlaylist 1.0
foo_simplaylist_manager.dll (2011-11-10 00:29:34 UTC)
    SimPlaylist Manager 1.0
foo_skip.dll (2011-11-10 00:29:34 UTC)
    Skip Track 1.7.4
foo_texttools.dll (2011-11-10 00:29:34 UTC)
    Text Tools 1.0.5
foo_ui_columns.dll (2011-11-10 00:29:34 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2011-11-04 14:07:18 UTC)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2011-11-10 00:29:34 UTC)
    Album list panel 0.3.5
foo_uie_panel_splitter.dll (2011-11-10 00:29:34 UTC)
    Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_peakmeter.dll (2011-11-10 00:29:34 UTC)
    Peakmeter Panel 0.0.4.2 beta
foo_uie_playlists_dropdown.dll (2011-11-10 00:29:34 UTC)
    Playlists Dropdown 0.7.6
foo_uie_tabs.dll (2011-11-10 00:29:34 UTC)
    Tabbed Panel Modified 0.2.7
foo_uie_typefind.dll (2011-11-10 00:29:34 UTC)
    Typefind 0.2 beta 2
foo_unpack.dll (2011-11-04 14:06:26 UTC)
    ZIP/GZIP/RAR Reader 1.6
foo_verifier.dll (2011-11-10 00:29:34 UTC)
    File Integrity Verifier 1.1
Edit: Sometimes that first crash is followed by this crash:
Problem signature:
  Fault Module Name: CoreFoundation.dll_unloaded
  Fault Module Timestamp: 4e7196ac
  Exception Offset: 73015573
  Locale ID: 4105
  Additional Information 1: d41d
  Additional Information 2: d41d8cd98f00b204e9800998ecf8427e
  Additional Information 3: 84f9
  Additional Information 4: 84f97c671ab662756ce589a428f93168
I'm still getting crashes like this from time to time, even with fresh installs of foobar. Can anyone provide some help?
Dependency Walker (depends.exe)
Dependency Walker is a free "object code analyzer" program developed by Steve Miller for Microsoft Windows platforms
used to list the imported and exported functions of a portable executable file.
It scans any 32-bit or 64-bit Windows module (exe, dll, ocx, sys, etc.) and builds a hierarchical tree diagram of all
dependent modules. For each module found, it lists all the functions that are exported by that module, and which of
those functions are actually being called by other modules. Another view displays the minimum set of required files,
along with detailed information about each file including a full path to the file, base address, version numbers,
machine type, debug information, and more.
Dependency Walker is also very useful for troubleshooting system errors related to loading and executing modules.
Dependency Walker detects many common application problems such as missing modules, invalid modules, import/export
mismatches, circular dependency errors, mismatched machine types of modules, and module initialization failures.
Dependency Walker was included in Microsoft Visual Studio until Visual Studio 2005 (Version 8.0) and Windows XP SP2
support tools. It only shows the load-time dependencies; it is not possible to know every run-time dependency without
disassembling or executing the program.
Basic Features:
• Runs on Windows 95, 98, Me, NT, 2000, XP, 2003, Vista and 7
• List all dependent modules (portable executables)
• Supports 64-bit and Windows CE executables
• Detects if the module is programmed in C or C++
• Detects modules not listed in the import address table
• Color coding of the list to help highlight problems (broken dependencies are highlighted in red)
• Traces dependencies recursively, and lists dependencies of all modules in a tree view
External Links:
Homepage [dependencywalker.com]
Wikipedia article [wikipedia.org]
Help, How to use [geekswithblogs.net]
Help, How to use [mozilla.org]
Help, How to use [imacros.net]
Thanks very much... this seems like an interesting program. I'll look into it and see what I discover!
