Topic: Help with shntool ! (Read 11437 times) previous topic - next topic
Help with shntool !
To work as expected in Nautilus, the following code needed to be inserted:
This will prevent Nautilus to do its operations from $HOME as it usually does.
What remains unclear to me is that if Dolphin supports those kind of scripts or some magic...
The script needs to be executable and inside .gnome2/nautilus-scripts
#!/usr/bin/env bash
            # Go to file's directory if it's a file, for Nautilus
            if [ ! -d "$destination" ]; then
                destination="`dirname "$destination"`"
            fi
FILE=`basename $1`
FILENOEXT=`basename $1 .flac`
sox -S -V $destination/$FILE -c 2 stereo.wav
shntool split -l 5:00 stereo.wav
shntool cue split-track*.wav >> $FILENOEXT.cue
rm split-track*.wav
rm stereo.wav
sed -i "s#joined.wav#$FILE#" $FILENOEXT.cue
Help with shntool !
dutch109:
how do I properly do a for loop here, getting $i from "TRACK" statement, but putting the TITLE and PERFORMER idented and after INDEXes statements?
for i in $FILENOEXT.cue do
sed -i "s/^\([ \t]*\)\(INDEX 01.*\)$/\1\2\n\1TITLE Part $i\n\1PERFORMER Conferencist/" $FILENOEXT.cue
done
Help with shntool !
konsole --title="Create CUESHEET" -e $SHELL -c "cd %d; mscd %f"
I found out that this statement will work in KDE/Dolphin when Opening the file with the associated script.
Now the issue is, file name with spaces... aren't being processed. Any tips would help!
Help with shntool !
A much better worked out version of the script:
#!/usr/bin/env bash
if [[ $1 = */* ]]; then cd "${1%/*}" || exit; fi
file=${1##*/}
base=${file%.*}
sox -S -V "$file" -c 2 stereo.wav
echo "REM DATE 2011";
echo "REM GENRE Rock";
echo "REM COMMENT CD-R";
echo "PERFORMER \"Band\"";
echo "TITLE \"Album\"";
shntool cue split-track*.wav | sed "s#joined.wav#$file#";
} > "$base.cue"
rm split-track*.wav
rm stereo.wav
Update: Found out a way to work with Nautilus launching on terminal, the custom command should be:
gnome-terminal --title="Creating Cuesheet for CD..." --hide-menubar -x mscd %f
