Topic: WavPack DirectShow filter decoder (Read 10404 times) previous topic - next topic
RE: DirectShow_WavPack_Decoder-x64-MP
MultiProcessor?
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
Having trouble getting this to work.
Running W7x64.  Used file: DirectShow_WavPack_Decoder-x64-MP-r15.7z.
Ran: C:\Windows\System32\regsvr32 WavPackDSDecoder.ax
Got an error saying that the file or a dependency was missing.  Do I need to have something else also?
Probably your computer needs additionally the Microsoft Visual C++ 2010 Redistributable Package to be installed.
Edit: Maybe you also need the Visual C++ 2010 SP1 package. You can get both from Microsoft's Download Center.
Yeah.  That was it.  SW101 question: Why is this needed?  VS2010 can't compile to not need the runtime?  I don't remember needing this for any ax file I've used.  Though it could be I already had the dependency needed...
Pretty much no compiler compiles to not need a runtime (typically this is only done for things like compiling kernels), that would make a ton of compatibility issues.  VS2010 is pretty new to find in public releases, so it's not unlikely that you'd never needed it before.
