Topic: foobar2000 v1.1.6 beta (Read 76401 times) previous topic - next topic
Reply #125
Now that the ReplayGain scanner now uses libebur128, I am having slowdowns when ReplayGain scanning a track that has large areas of silence.
It slows down to ~2x.
Is anyone else experience this?
Yup, still having the issue with beta4.
Kinda annoying when your machine kompletely shuts down without any BSOD or any other kind of error
Reply #126
edit: but there's a new problem introduced in beta 4, I think.
Was the handling of the %genre% tag in MP4 files changed? My genre tags written in Mp3tag can't be read by foobar2000.
It seems like some genre tags are not written to the files when converting to M4A too. Works fine on a clean install of 1.1.5.
fb2k is writing to the cgen atom, but I get two genres (both cgen) if I write a genre using fb2k and I already have cgen written originally by mp3tag prior.
Surf's Up!
"Columnated Ruins Domino"
Reply #127
Sounds like foobar2000 is just writing a new cgen atom, rather than reading and modifying the original one from Mp3tag. IIRC, "Genre" is one of the tags that supports multiple entries.
I don't know why foobar2000 wouldn't be reading the atom that already exists, however. That's a question for the programmer(s).
Reply #128
It only reads the genre it writes and not the original. If I delete the fb2k written tag, it will no longer read the original tag written by mp3tag.
Surf's Up!
Reply #129
ITU-R BS.1770-2 available.
75% overlapping and -10 dB relative gate ...
I guess the R128 should soon be modified in the same way.
Great! Time to change the relative gate accordingly. The block overlap already is at 75%.
I should be releasing 0.4 in the next few days. Now there is only one scanner executable with different input plugins instead of one exe for each input library. The scanner automatically chooses the best input plugin for each file. This should make it easier to tag/scan different audio formats at the same time.
I've also implemented a hidden option "--tag-tp" for true peak tagging and fixed the ReplayGain loudness for mono files.
Are we getting these changes in next beta?
Reply #130
Beta 5 out. No ReplayGain scanner changes yet unfortunately.
  • To prevent problems with converting tags between different ID3v2 revisions, foobar2000 will no longer convert ID3v2 tags between 2.3 and 2.4 unless explicitly requested by the user.
  • ID3v2 revision is now reported in the "tagtype" field.
  • MP4 genre now works properly.
Reply #131
Did we have to reload any tags after Beta1 as pointed out in the Wiki or was once enough to update?
Reply #132
I had to do a reload to get the tagtype to update from ID3v2 to ID3v2.3.
Surf's Up!
Reply #133
Any changes done to tag reading, require fb2k to re-read the actual files' tags.
Usually what is displayed in the Media Library or in .fpl playlists are cached results. So yes, you have to refresh the cache.
elevatorladylevitateme
Reply #134
Nope, it stills uses ID3 genre numbers. Certain genres such as Thrash Metal, Heavy Metal and Synth Pop want appear on MP3tag and iTunes.
Reply #135
Could there be some some problem with drag&drop in beta 5 at least?
I can't d&d in playlist view, but can in playlist manager, and can't think of something I am doing wrong
edit: please ignore this for a while, until I figure how to reproduce
edit2: I don't really get what's wrong as I'm too tired (never the less posting in forum) but here is picture when I try to drop file from explorer:
Reply #136
Are the ID3v2.3 tags that fb2k 1.1.6 writes, in Unicode (UTF-16 or UTF-8) or ISO-8859-1 ?
Reply #137
AFAIK they are in UTF-16 unless original is in latin-1
Reply #138
Are you dragging to an autoplaylist?
Reply #139
It wasn't autoplaylist (I don't have empty autoplaylist), but regular temp playlist from which I deleted tracks as I finished working on them. Then trying d&d I noticed this weird behaviour
Right now, after I restarted my PC, can't seem to reproduce again
Bin it in twilight zone
Reply #140
Where you dragging from a window spawned with elevated privileges (i.e., Administrator mode) when foobar2000 was not or vice versa? UAC doesn't support this.
Reply #141
Unfortunately 1.1.6 stable didn't get these changes.
We'll include the updated R128 library as soon as possible. Next foobar2000 beta versions will be available soon enough.
