Topic: How do you save a set of xvid settings? (Read 3919 times) previous topic - next topic
HI all,
after making a bunch of changes to the xvid encoder config,
I'd like to save these settings so that after further changes
I can restore the settings I saved.
Is it possible ?
I see the registry key [HKEY_CURRENT_USER\Software\GNU\XviD] -
it looks like the settings are in there, but when I export the key and merge it in later,
none of the changes I made earlier (in the encoder config dialog) are there.
HI all,
Is it possible ?
Actually this key does work.  Just ensure you don't have any instances of the xvid open,
and the settings will available next time you open the xvid encoder config.
