Topic: foo_flv (Read 35827 times) previous topic - next topic
foo_flv
Allows you to play Flash Video (.FLV) files on foobar2000.
This currently supports PCM, MP3, and AAC audio codecs.
Download: Flash Video Decoder 0.9.1 (foo_flv.dll)
[a href='index.php?showtopic=86913']All versions and changelog[/a]
foo_flv
Thanks, I'll try this soon.
foo_flv
Thank you! It's something I've wished for for some time now. Works fine on my setup.
foo_flv
Works good. Thank you.
Could you add support for writing ID3 tags into flv files?
At this point its only possible to view them with foobar.
(flv could contain tags)
foo_flv
Why would FLV files even support tags? They're not a general use format. Stop downloading your music from YouTube, damnit.
foo_flv
Theres no reason to be aggressive.
It is just a question.
foo_flv
There are tracks we can find ONLY on Youtube. I understand it. But I haven't even thought of ID3 tags in a VIDEO file, lol (prove me wrong)
foo_flv
You are right.
Most of my favorite mashups are only on youtube.
Even some literal video versions make more sense on youtube so they are only puplished there.
foo_flv
Yes, the current version can parse and display metadata contained in FLV files, but cannot write.
A future version, if any, might support tag writing.
foo_flv
Some of the internet stream provide flv format, I tested several radio stations, some can work, but most of them can't.
There is sample:
http://api.cztv.com/channels/1601/128.flv/live
rtmp://fm935_2564078
Waiting for the next version that can support those format,THX!
foo_flv
That sounds like it would require implementing streaming support.
Also, what work is needed for AAC profile detection? Don't the packet decoder services provide that information for free?
foo_flv
There is sample:
I found the first sample had a mime type of "video/flv" (I couldn’t open the second one). I made this type acceptable. Previous versions only accepted "video/x-flv", which is the correct mime type for FLV. In addition, fixed minor bugs related to handling streaming files. The sample above works now, but some streaming files still don’t work due to other reasons.
Download: Flash Video Decoder 0.9.2 (foo_flv.dll)
In the current version, I call the packet_decoder::analyze_first_frame method (and then packet_decoder::reset_after_seek) against AAC decoders. Without this, provided information such as profile name and sample rate could be incorrect, especially with HE-AAC v1/v2 profiles as far as I’ve tested.
Previous versions couldn't use the packet_decoder and file_info classes in the right way, just because of my lack of skills in component development.
foo_flv
Ah, good.
foo_flv
Thank you very much, it do works.
foo_flv
Very cool!
I use rtmpgw.exe for rtmp
Thank you very much
foo_flv
In GOTRADIO, all the stream is rtmp protocol, I think these stations are flv format, would you please work it out?
The address link: http://www.gotradio.com
foo_flv
This is limitation for people where living in the suburbs of Tokyo.
radiko
I use rtmpgw.exe with foo_run
rtmpgw --rtmp "rtmpe://radiko.smartstream.ne.jp:1935" --playpath "simul-stream" --swfUrl "http://radiko.jp/player/swf/player_2.0.1.00.swf" --pageUrl "http://radiko.jp/player/player.html#TBS live=1" --flashVer "LNX 10,0,45,2" --live --device 127.0.0.1 --sport 8091
This code copy to Notepad and change extension *.pls
[playlist]
File1=http://127.0.0.1:8091/?a=TBS%2f_defInst_
Title1=TBSラジオ
URL=http://radiko.jp/timetable/
Length1=-1
File2=http://127.0.0.1:8091/?a=QRR%2f_defInst_
Title2=文化放送
Length2=-1
File3=http://127.0.0.1:8091/?a=LFR%2f_defInst_
Title3=ニッポン放送
Length3=-1
File4=http://127.0.0.1:8091/?a=NSB%2f_defInst_
Title4=ラジオNIKKEI
Length4=-1
File5=http://127.0.0.1:8091/?a=INT%2f_defInst_
Title5=InterFM
Length5=-1
File6=http://127.0.0.1:8091/?a=FMT%2f_defInst_
Title6=TOKYO FM
Length6=-1
File7=http://127.0.0.1:8091/?a=FMJ%2f_defInst_
Title7=J-WAVE
Length7=-1
NumberOfEntries=7
Version=2
Like this
foo_flv
I’ve been able to get some streaming FLVs to play properly by unchecking the box labeled “Enable dynamic track titles” in File > Preferences > Networking.
An example (via http://u12b.sky.fm/ )
RTMP hasn’t worked on my setup yet.
foo_flv
Implemented tag writing and ReplayGain support.
Download: [a href='index.php?act=findpost&pid=748118']Flash Video Decoder 0.9.3 (foo_flv.dll)[/a]
foo_flv
Big <3
foo_flv
Tag editing improvements and speed optimizations.
Download: [a href='index.php?act=findpost&pid=749305']Flash Video Decoder 0.9.4 (foo_flv.dll)[/a]
foo_flv
Download: [a href='index.php?act=findpost&pid=756522']Flash Video Decoder 0.9.5 (foo_flv.dll)[/a]
foo_flv
Can this plugin play sound directly from video on youtube by entering path in ''add location''?
if i enter this: http://www.youtube.com/watch?v=lDK9QqIzhwk. I want to hear sound in foobar from that video..
I tried everything but it does not work. It can only play FLV files on hard disk,
so can you add this possibility.
It would be great that someone make a plugin which allows us to have search option from youtube in foobar, playlist from youtube, and ability only for play sound for each selected video. Should look the same as last.fm radio plugin.
Anyone interested for this?
I think If someone makes this, foobar would be universal player.
We already have all possible plugins, this is the only one missing...
foo_flv
Download: [a href='index.php?act=findpost&pid=818695']Flash Video Decoder 0.9.6 (foo_flv.dll)[/a]
Added support for foobar2000 v1.2. The previous versions of foo_flv can not decode AAC audio with foobar2000 v1.2. (It seems the AAC packet decoder of foobar2000 v1.2 requires an ADTS header followed by each AAC packet)
