Topic: Song organizing (Read 3453 times) previous topic - next topic
Song organizing
I would like to organize songs in a playlists and see which songs were played already. Is it possible?
Song organizing
Thanks a lot! Now searching how can I add such an information to the column?
Song organizing
Doesn't explain much for a newbie  Searching wiki...
Song organizing
on the playlist, right click on a column header and select columns>more.. from there you can create a new custom column and enter the title formatting (such as %play_count%).
lastly go back and right click the column header again to enable the new column you've created. you can drag/drop to position it.
Song organizing
Doesn't work - "0" displayed all the time
Song organizing
Works just fine.
Have you played a track for at least 1 minute so it registers as played?
Song organizing
it only starts counting plays from when you installed the component that shakey_snake linked to above. and i believe there are conditions for how much of the song has to be played before it registers. if you open file>preferences>components and double click the entry for the component, it may show you there.... (i don't have that component installed so i can't be sure)
edit: oops, too slow.
Song organizing
It works after one minute. Thanks!
Problem solved.
Song organizing
I will play music again during New Year's Eve. Now I'd like make it better. Organize songs like this play lists:
1. slow,
2. fast,
3. 70-80s,
4. ballroom dancing.
So for example play two random fast and one random slow and again two random fast and one slow. Songs played more than 1 minute are no longer played only when manually started.
Song organizing
Any tutorial how to use it?
