Topic: foo_dsp_effect (Read 261763 times) previous topic - next topic
Re: foo_dsp_effect
Reply #550
FR for the IIR Filter effect on this component: The ability to set frequency value to fractional values, rename frequency value from "Frequency (db)" to "Frequency (Hz)", higher order filters (up to 40th order) and coefficient configurations (Butterworth, Bessel, Chebyshev type I and II, Elliptic, Critically-damped, and Linkwitz-Riley crossover filters) for all filter types (including low and high shelving and peaking filters), and channel configuration to EQ specific channels (including Mid and Side channels)
Of course, I'd like to see high-order low-shelf filter for bass boosting at 69Hz or 75Hz and below with similar sound to fb2k's built-in EQ but minimum-phase (to avoid pre-ring) for Butterworth case, and type I Chebyshev low-shelf filter with passband ripple of 6dB or more for sounding like WMP's 10 band EQ when boosting first two bands (31.5Hz and 63Hz respectively)
Re: foo_dsp_effect
Reply #551
Have the DSP Effect plugins been updated or released out of beta yet?
Re: foo_dsp_effect
Reply #552
I never really felt the need. For me it fills my needs so far of what I wanted to accomplish with the component, which I do want to rewrite for use in my own personal tech, which would mean rewriting the entire thing to use SSE/NEON. So it seemed to me kinda pointless just to bump a version number.
Why do you ask? :)
Re: foo_dsp_effect
Reply #553
Since the last update was still a beta release, I wondered if the component still had bugs or was abandoned altogether.
Re: foo_dsp_effect
Reply #554
So I didn't feel the need to push a version number for the sake of it, just so people can see "line go up".
Re: foo_dsp_effect
Reply #555
Does anybody have a issue with updating EffectDSP? I'm using portable fb 2.1.3 and every time I try to install newest version of EffectDSP 0.50 final it shows in components list 0.50 beta 7... and I'm able to update it over and over - restart after restart version stays same  :o
Re: foo_dsp_effect
Reply #556
I can confirm this behaviour.
Re: foo_dsp_effect
Reply #557
Try now. Double and triple checked. Now recompiled to make sure, timestamp on files should be April Fools Day.
Re: foo_dsp_effect
Reply #558
It works now 😁 thank you
Re: foo_dsp_effect
Reply #559
Thank you
