Topic: foo_playlist_organizer (aka foo_plorg) (Read 249055 times) previous topic - next topic
Reply #250
Thanks for the great plugin !
I'd like to report a weird behavior : when I put 2 instances of Playlist Organizer's UI, the second uses a different tree (the flat, default one).
A picture is worth a thousand words :
Is that normal ?
Reply #251
Nemo,
I'm having some trouble with plorg/facets (See this post). Speaking with Frank he told me that foo_plorg is the component that's crashing, he'd forward you the info so that you can take a look into the issue. Have you had the chance to look into it? I find both components, facets and foo_plorg quite good ones, so I wouldn't like to have to give up on one.
I have the crash reports that I've sent as requested by Frank, so if you need them just let me know.
Regards,
Alberto
Reply #252
I use Vista with Foobar 1.1.9, tried to install foo-plorg, latest version, but get this message:
"Failed to load DLL: foo_plorg.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000."
i also did install
Microsoft Visual C++ 2010 Redistributable Package (x64), but i still get the same error.
Reply #253
Is there a reason you installed the 64 bit version. Maybe that is the problem
Reply #254
I've received the crash reports from Frank and it will be fixed.
Just be patient because I have limited spare time at the moment.
Reply #255
that makes sense.
tried with x86 and it's now working.
thanks.
Reply #256
Thanks, Nemo. Didn't mean to bother. Just let me know if there's any way in which I can collaborate.
Regards,
Alberto
Reply #257
Is that normal ?
NEMO7538, you didnt tell me if this behaviour is considered normal, or a bug. As for me, I'd love to have the trees syncronized in the several instances of the playlist organizer UI element.
Reply #258
It is a feature! Why would you open two instances with exactly the same treeview?
Reply #259
Because actually in my case, the higher pane is much taller than the lower. It's the place where, through tabs, I browse my library and my playlists. Now sometimes, I want to see both my library (in a tall pane) and my playlists. To this puprpose, I re-added a Playlist Organizer instance in the lower pane. That's why.
If it's a feature, then I hereby make a feature request of beaing to sync 2 instances of PLO.
Reply #260
Are you too lazy to do the same work a second time?
Reply #261
Thanks for this component, I have come to use it as my only playlist tool, since it integrates seamlessly into my whole layout and has all features I could wish for.
One question about the looks: Is it somehow possible to exchange the icon indicator for folders (the little black triangle)? I have looked around but couldn't find a hint. If not, it is no big deal really; I'm just using a very dark layout and wanted to exchange those bits for something more visible. (I'm using CUI on latest foobar).
Reply #262
Is there any way to add the vertical padding between items and changing the font size?
Reply #263
I'm having the same problem as Jac74, except I don't use foo_facets. I'm not sure what causes it, but after a while, the graphical elements of my HUD remain stuck, as if the program crashes, but I can still change songs and press buttons and whatnot, even though the interface won't update according to my changes. Perhaps this is the fault of another plugin, though. Below is a list of my currently installed plugins. Anyone spot known crashware?
Core (2011-09-14 09:11:28 UTC)
foobar2000 core 1.1.8
foo_albumlist.dll (2011-09-14 09:09:52 UTC)
Album List 4.5
foo_audioscrobbler.dll (2010-06-04 13:27:04 UTC)
Audioscrobbler 1.4.7
foo_cdda.dll (2011-09-14 09:09:40 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2011-09-14 09:09:32 UTC)
Converter 1.5
foo_customdb.dll (2010-03-04 17:10:54 UTC)
Custom Database 0.1.0_beta1
foo_dop.dll (2011-06-12 21:17:16 UTC)
iPod manager 0.6.9.6
foo_dsp_std.dll (2011-09-14 09:10:12 UTC)
Standard DSP Array 1.0
foo_freedb2.dll (2011-09-14 09:08:22 UTC)
freedb Tagger 0.6.4
foo_input_std.dll (2011-09-20 17:21:14 UTC)
Standard Input Array 1.0
foo_lnk.dll (2011-11-01 21:02:54 UTC)
Shell Link Resolver 1.3.1
foo_playcount.dll (2011-11-01 21:02:54 UTC)
Playback Statistics 3.0.2
foo_plorg.dll (2011-05-05 23:03:00 UTC)
Playlist Organizer 2.4
foo_rating.dll (2007-02-28 06:52:46 UTC)
Foo_Rating BETA 2.1
foo_rgscan.dll (2011-09-14 09:09:32 UTC)
ReplayGain Scanner 2.1.2
foo_softplaylists.dll (2011-02-05 08:04:50 UTC)
Soft Playlists 2011-02-05
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
Columns UI 0.3.8.8
foo_ui_panels.dll
foo_ui_std.dll (2011-09-14 09:09:46 UTC)
Default User Interface 0.9.5
foo_uie_lyrics3.dll (2011-11-29 19:53:37 UTC)
Lyric Show Panel 3 0.2
foo_uie_panel_splitter.dll (2009-12-10 04:16:12 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_quicksearch.dll (2007-05-18 19:31:10 UTC)
Quick Search Toolbar 2.8l
foo_uie_wsh_panel_mod.dll (2011-08-06 04:54:54 UTC)
WSH Panel Mod 1.4.4
foo_unpack.dll (2011-09-14 09:09:06 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_wave_seekbar.dll (2011-11-01 21:02:54 UTC)
Waveform seekbar 0.2.14
foo_winamp_spam.dll (2010-08-08 01:32:58 UTC)
Winamp API Emulator 0.98
Thanks. <3
Reply #265
Can you make it so that when you click on the root folder it displays all the songs within the playlists of that folder?
Thanks,
tmac
Reply #266
How should that be possible at all? The playlistorg component is a playlistswitcher: you can organize your playlists inside a tree structure and switch between them. What you wishes is kind of paradox: you have a folder but wishes it to be a playlist. To say it in other words: your folder also had to be a real playlist visible in other playlist switchers - but then it is a playlist and not a folder.
Nevertheless, your desired feature although not possible as playlist switcher is realizable as library viewer: you could try the playlist tree mod component of fbuser.
Reply #267
Honestly, have a little imagination. My desired function is present in itunes, so I figured it might be possible with foobar.
I have no coding experience. So I'm dead in the water trying to do this myself, which is why I versed my request on the discussion board.
Reply #268
Any chance of option for custom indentation? It uses too much space.
Reply #269
is there anyway to make the current playlist that is playing bold instead of having a rectangle around it?
Reply #270
Any progress regarding to plorg/facets compability fix yet? I'm really liking both of the plugins, just too bad they won't work together too well.
Reply #271
Can you provide more information? Thanks
Reply #272
Hello Nemo,
I have the same problem as laite in post #79.
QUOTE (NEMO7538 @ May 22 2010, 20:06)
Do you have any message in the console?
Actually, it seems so. When starting foobar there is this:
Playlist Organizer: Error (Playlist [0-] unfound or name does not match) reading configuration
Playlist Organizer: Unmatched number of playlists while reading configuration
Playlist Organizer: Unfound tree configuration, trying to retrieve from last known configuration
Playlist Organizer: Reinitializing Treeview
Today I took some time to redo my foobar layout from the scratch and I discovered when this failure occurs.
I have a albumlist panel in my layout. When activating the filter to be able to quickly search in the albumlist I get the mentioned failure when starting foobar the next time. Unchecking the filter and restarting foobar solves the problem again.
Do you have any idea what is causing this behaviour?
I can provide a simple configuration for analysis if required.
Thanks and cheers!
Reply #273
Oh, sorry. I thought it would be the same issue than mentioned by Jac74 and Frank, but perhaps it's a bit different after I read those comments again, although could be still related to that.
At any rate, the crash occurs in a following way. I'm playing music and then using facets to search and filter artists/albums/tracks. When I'm trying to add files to the playlist ("Send to selection playlist" or "Send to current playlist"), foobar immediately hangs after double-clicking/middle-clicking selection - current track keeps playing to the end but foobar is completely unresponsible to any action. So this occurs when a track is currently playing or paused; if there is no track playing, selection will be added to the playlist normally.
I didn't know which component was causing the crash at first, so I uninstalled all components until eventually finding out it was happening when both the playlist organizer and facets were installed.
For some reason couldn't replicate the problem when I tried a portable installation with both of the components installed and my basic interface being installed. However, I didn't however my full music library (which is quite big) to portable installation monitoring, only couple of folders, in case it would have any effect.
Reply #274
Thanks .... I'll have a look and hopefully provide a fix, but please be patient. I don't have much spare time atm.
