Topic: Windows Media Player Plus! - Various enhancements for WMP (Read 325209 times) previous topic - next topic
Reply #150
Announcement: Windows Media Player Plus! 2.5 is now available for download. This update adds full Unicode support, 'Find in library' for Windows Media Player 12, support for Windows 8, and a whole bunch of bugfixes and improvements. Updating is highly recommended.
See the Version History page for a detailed list of what's new and what has been fixed.
Reply #151
Restoring last playlist used to work in 2.1 but not anymore in 2.5...
Can someone confirm this?
EDIT: Never mind! The playlist (.wpl) has to be there in C:\Users\_\Music\Playlists\ to get it working.
Reply #152
WMP Plus! currently can't restore a playlist if it's not in the media library. Perhaps that's what was going on here?
I might look into removing this limitation for one of the next versions.
Reply #153
Hello, I've been getting errors from WMP Plus 2.5, while on Windows XP Home Edition (32-bit, FYI). After downloading the old 2.1 version (by changing the url in my download manager), the errors have stopped, so I guess there must be some non-XP-friendly code in there (). Here are my problems:
1. When I open WMP, I get a dll error: "An unexpected error has occurred while loading Windows Media Player Plus! Please contact the author if the problem persists. Exception Exception in module WMPPlus.dll at 002b700. CryptAquireContext failed."
2. Party Shuffle list is ALWAYS empty.
3. When I try to search through my library, I get another error message, telling me to report the error to Microsoft (you all know the one ).
3.5 If I try to search for something with spaces, Windows Media Player closes without warning.
Things I tried before downgrading: reinstalling WMP, reinstalling WMP Plus, removing WMP Plus BEFORE reinstalling, and finally downgrading WITHOUT uninstalling (uninstalling first worked fine though).
Reply #154
Update:looks like I spoke too soon. 2.1 gives me the exact same problems EXECPT the dll error at the beginning. All the others are still there.
Reply #155
My main system still runs XP SP3 and use WMP Plus 2.5 without any problems here, so there must be something else going on. Do you also have SP3 installed? Are you also using WMP 11?
The first error is related to Party Shuffle so that immediately explains why the Party Shuffle playlist remains empty. I'm not quite sure yet what exactly the cause is though.
Regarding problem 3, I assume that you're using WMP's Search field at the top? Does it make a difference if you start typing immediately or if you click in the Search field first?
Reply #156
After installing 2.5 I can no longer choose the columns shown along the top bar in the open/edit screen of WMP. My computer is 64-bit running Windows 7.
Reply #157
Which columns are you referring to, and what exactly do you mean with open/edit screen?
What happens when you try to choose the columns? Do you get an error message?
Reply #158
I am using SP3, with all the lastest updates. Likewise for WMP 11, l. And yes, I am using the search field at the top. Whether it crashes immediately or not seems to depend on whether I search for something with spaces.
Also, I am having other problems with WMP. First off, I can't get my portable device to use MTP, which is unfortunate because this device was never able to effectively detect added/deleted/changed files Mass Storage Class mode. When I just now tried to fix this by reinstalling WMP, I got an error saying something like "Windows Media Player Install could not complete." I am wondering could these problems be related?
Reply #159
When you open an album, a screen appears which allows you to edit information listed in columns (as - Composer, Contributing Artist, Rating etc.). You can choose the columns shown from the Organise Layout panel, but album, artist and genre will now only  appear horizontally by the album art as total album entries. Previously you  could right click on a vacant part of the top bar to add these columns vertically so that they could be edited individually. Nothing happens if you right click now, not even an error message.
Reply #160
In the meantime, I've been able to reproduce the crash when searching for something with a space. The crash is a direct result of the error message at WMP startup, just like the empty Party Shuffle playlist. It happens because WMP Plus simply didn't initialize properly.
Does WMP also crash when you search for something without spaces? On my system, it only crashes when I type a space.
Now I just need to find out why the error message gets displayed in the first place. This can only be done with a special debug version of WMP Plus. Is it OK if I send you a download link to this version by PM? (this will be somewhere later this week)
These problems are unlikely to be related to WMP Plus. I suggest that you ask for help in the Windows 7 Media Forum, as that's the place for WMP support.
I still don't know what you mean with Organize Layout panel and top bar, but based on your description you might be looking for Details view but are in Expanded tile view instead. To switch, click the little arrow on the left of the Search field and select Details. By the way, this has nothing to do with WMP Plus.
If that's not it then I'm still confused. Please show what you mean by posting a screen shot (you can use Imgur for this).
Reply #161
Hi, thanks for this add-in, really handy for the tag editor, AND multi-disc sort.
Just a thought, if the disc number is 1 of 1 (and only 1), I don't think it's quite useful to display the disc number as part of the track number...
Also, without the plug-in, in Artist or Album view, I can press a letter and it will jump to the section starting with that letter.
With the plug-in, pressing a letter puts you automatically into search mode so I can't do that anymore.
Reply #162
Then the disc number tag itself is quite useless for that track. Why not just remove the disc number from the track?
You can disable 'Find as you type' in the plug-in's settings: Tools - Plug-in properties - Windows Media Player Plus! (press Ctrl+M if you don't see the Tools menu).
Reply #163
I have used a few different applications over the years to rip my CDs. It just seems that a lot of them have set the disc number. I would need to do a massive job of removing all these tags. It can be done. I just figured that usually, since the point of these enhancements is to simplify our lives, I would take it into account in the code.
Thanks again.
Reply #164
I'm reluctant to change the code just for edge cases like this. It will also make the feature harder to understand for users, which isn't a good thing (especially since there's no documentation).
You can remove all these tags in batch with the Mp3tag tool, by creating an action that replaces "1/1" in the DISCNUMBER tag by an empty string. More info here.
Reply #165
I recently installed Windows 8 and I installed Windows Media Player Plus!.  I'm not getting the tag editor when I right click on a song.  The plug in is active and other features of the plug in are working such as changing the title bar of WMP to show the song playing. Please Help.
This is most likely because the latest release of WMP Plus! doesn't really support Windows 8 yet. The soon-to-be-released WMP Plus! 2.5 will support Windows 8.
Hi Tim,
Your plug-in seems to be exactly what I need.  What I'm most interested in is the tag editor.  But I couldn't even try it out because I happen to have the same problem as grimmis188 has (even though I downloaded version 2.5).  I'm using WMP 12 on Windows 8 64 bit.
Reply #166
Please check if Windows Media Player Plus! is still loaded in WMP: it should be checked in the Tools - Plug-ins menu (press Ctrl+M if you don't see the Tools menu).
If the plug-in is loaded, make sure that the song that you're right-clicking is in WMP's library (this is required for Tag Editor Plus to appear).
Also, are you right-clicking in WMP's Library mode or Now Playing mode? What's the language of WMP on your system?
Reply #167
Hi Tim,
Problem fixed!  You're a KING.
Since I'm about to record quite a few records, I was testing different tag solutions for FLAC files among which was WMP PLUS.  So I did not put any file in my Library.  From the moment i did put one test file, everything worked fine.
So, from now on, WMP PLUS is no longer one among the solutions.  It is THE solution I adopt.
Super good work.  And thanks for your prompt reply.
Reply #168
Since I installed WMP plus (on Windows 7 Home, WMP version 12) I have regularly experienced a problem where WMP will play a few songs and then return a "Windows Media Player encountered a problem while playing the file" message and stop playing.  In the playlist, the songs that it claims to have failed to played will ave the little red circle with a cross in next to their name.
If I close WMP and restart it and try and play the exact same songs, it will do so - but will then fail again a few songs later in the same way.
Do you have any idea what could be causing this and how it could be fixed?
Reply #169
No, I've never heard of such a problem so I would like to do some further troubleshooting. Are you using the latest version of WMP Plus, 2.5?
What's the file type (or types) of the affected music files (MP3, WMA, WAV...)?
If you click on the little red circle next to a song and select Error details, what's the full text of the message that appears?
Do you still experience the problem if you disable WMP Plus by unchecking it in the Tools - Plug-ins menu? (press Ctrl+M if you don't see the Tools menu).
Reply #170
Thanks for the prompt reply.  To answer your questions:
1) yes, using version 2.5
2) its all types of files - not one particular type
3) Error details: full text is just "Windows Media Player encountered a problem while playing the file."
4) yes, it still happens if plugin is disabled
It tends to go rapidly through five files, decide each is unplayable, and then give up (I know this as five consecutive files have the red cross next to them in the playlist)
Reply #171
On the error details message, please click the Web help button. What's the URL of the web page that it takes you to?
Do you have any other plug-ins loaded in WMP? Does the problem go away if you uninstall WMP Plus again?
Reply #172
Web help takes me to http://windows.microsoft.com/en-gb/windows7/c00d11b1.  i'd tried following hte instructions, and the drivers don't need updating.
No other plugins installed, though I can't test the uninstalling thing as I can't find any way to uninstall it.  When I go into plugins, the button saying "remove2 for WMP Plus is greyed out
Reply #173
You can uninstall WMP Plus at Control Panel - Programs - View installed programs.
The problem with Web help is that you immediately get redirected to another URL that contains less info. So would it be possible to click Web help again, but this time with your Internet connection disabled? This will prevent the redirect from happening and allow you to retrieve the full URL with all error details. Thanks!
Reply #174
Sorry for the late reply here - not needed to use windows media player in the last few days.  I can now confirm the problem *does* go away if I uninstall WMP Plus.
I will now reinstall again and will report back on whether the problem comes back; and if it does, I'll post the error message
Thanks again for your help
david
