Topic: Columns UI: Format/Bitrate Column (Read 9261 times) previous topic - next topic
Hey guys,
I'm using columns ui. And I was wondering if there was any way to get a format/bitrate column to appear? This is how my columns look like:
As you can see on the column that has artist, title, album, etc, there is not a column that will tell me the format and bitrate of each song. I know it tells you this in the status bar, but a column for it would be nice. And when I right-click on the columns themselves there's no option for a format or bitrate column.
I know under the Default User Interface you can get this to appear. But is there a way to get them to appear under ColumnsUI?
Thanks for any help.
Right click the columns bar, choose "Edit this column".
Now you see a list of columns and you are free to add new ones (and move them).
Read the Title Formatting Reference to get the desired variables which you'll fill in the Scripts > Display field of your column(s) (to fully understand it study the entries which are already there).
Thank you herojoker. I appreciate the response.
And yeah, I've tried this Edit This Column option before, but nothing would show up in the actual column. So I was obviously doing something wrong. Hopefully the Title Formatting Reference link that you gave me will help me out.
Thanks again.
EDIT: Ha! That certainly did it. I now have the bitrates being displayed by using the %bitrate% under Scripts, and samething with the format with the %codec%. How simple. I thought I was going to need a specific theme or something to get these to appear.
Thank you again for the help.
I am using something like this:
%codec%
$if($stricmp(%__encoding%,lossy),
// lossy codecs
$puts(BITRATE,%__bitrate%)
// change colors to show quality "visually"
$ifgreater($get(BITRATE),170,
$rgb(0,175,0),$ifgreater($get(BITRATE),130,$rgb(150,150,50),$rgb(175,75,50))) %__bitrate%kbit
// Add MP3 aditional info
$if(%__codec_profile%,$abbr(%__codec_profile%) /
$upper($abbr(%__MP3_STEREO_MODE%)))
//Lossless
$muldiv(%__bitrate%,1000,
$div($mul(%__samplerate%,%__bitspersample%,%__channels%),100))'%' compr.
Re: Columns UI: Format/Bitrate Column
%codec%
// lossy codecs
//Lossless
I know this is really old but thanks for posting this, I really like this script!
