Topic: [Not My Release] EsPlaylist (Read 340531 times) previous topic - next topic
Reply #100
This component is looking really nice!
Only request I have: Ability to select the behavior of the doubleclick action when browsing the library, like in the standard Album List component.
Cheers!
Reply #101
Cannot figure whats wrong...
There is a screen, how Esplaylist view albums (many dublicates with one song; when sending on elplaylist grouping in elplaylist also broken, until I apply sort on playlist):
There is a group settings I use (on first Group settings view is a %artist% setting):
All files in album located in one folder. Any ideas?
Reply #102
Has anybody a clue how "artwork:icon" in the grouping options is supposed to work?!
What icon is used there?!
I am looking for a way to assign a single picture for groupings like %rating%...
+1
I also don't understand how it works. I have stored my music like this :
Album Artist / Album (e.g. "C:\Kapustin, Nikolai (1937-)\Jazz Pieces for Piano\...")
I put a folder.jpg in each directory, one for the album artist, and another for each albums. But when I choose the grouping peset "album artist / album"), I can only see the cover of the albums but never the artist art stored in the first folder as folder.jpg too.
Any idea ?
Reply #103
Maybe it depend on how you have stored tags in your music. Make sure that you have an unique "album artist" field for each album ?
Reply #104
Empty_45
In group settings I not use %album artist%.
So, I am put %album artist% tag, but nothing changes happend :-(
Reply #105
Empty_45
And why do you don't replace your grouping %artist% by %album artist% then ?
Reply #106
Empty_45
Problem not in artist grouping, but in album grouping. Albums is dublicates, I am using simple %album% setting, and some albums viewed properly, some not. I havent idea where to digg from.
[EDIT] I deleted esplaylist configuration, and run foobar. Choose setting A-Z/Album artis/album, and all works correctly now. Sorry for troubling
Reply #107
EsPlaylist v0.0.8.2 beta (2010/04/03) released.
Changelog:
  • divided font & colour setting into Items and Group Titles in ColumnsUI case.
  • made background colours of selected/playing item semi-transparent in pseudo-transparent case.
  • changed priority order of loading albumart.
Download EsPlaylist v0.0.8.2 beta
Reply #108
1. It would be nice to find "View Style" in Keyboard Shortcuts . Is this possible?
2. There is a little to much space here in "Layered View", why?
Reply #109
EsPlaylist v0.0.8.3 beta (2010/04/04) released.
Changelog:
  • fixed the bottom borders of semi-transparent rectangles were shifted by 1px.(v0.0.8.3)
  • revert priority order of loading albumart.(v0.0.8.3)
Download EsPlaylist v0.0.8.3 beta
Reply #110
bug report: the EsPlaylist panel disappears in DUI when using the "playlist layout" option under "view>layout>quick setup". be careful otherwise you lose your EsPlaylist config. lucky i had a backup of my .fth
Reply #111
iam sorry to sound dumb but i have no idea how to get this working! is i compatible with default ui? if so then how do i configure it to work?
Reply #112
Any idea ?
I found how it works. You must stored a artist.jpg in at least THE FIRST album of each album artist. For exemple, if you have 3 albums of group Metallica, and the artist.jpg stored in the second folder, nothing will appear in the group.
I obtain this :
I would like to know if it is possible now to do like that :
1. I select the album artist (img 1)
2. I see the albums corresponding (img 2), and only his own albums thx to option "display only focused groups"
3. When I choose an album, can I have only in the playlist the albums that were listed below ? (img3) Because here, I have all my library ! that's quite a shame...
Reply #113
Right click>view style>always display only focused group. Or if you don't want to do that, make sure the lowest grouping level is set to display only the focused group.
Reply #114
Thx for your answer but the problem is the same:
I use the preset "Album Artist / Album", and the first level (album artist) with the option "diplay only focused group" checked.
So I wanted my library to view like that : Album Artist > Albums > Playlist view
It works fine in the album view, I effectively have the albums corresponding to the album artist BUT in the playlist view, I have all the library, as no filters were applied (otherwise, with the option "always display only focused group", I have only one album in the playlist view while I wanted to see all the albums of the album artist that I have choosen precedently...)
I don't know if I'm clear, my english is quite poor...
Reply #116
EsPlaylist v0.0.8.5 beta (2010/04/07) released.
Changelog:
  • added rating column.(I hope someone will provide more nice star for EsPlaylist)
Download EsPlaylist v0.0.8.5 beta
Reply #118
I can't figure out whether EsPlaylist cause this problem.
I can reproduce it only when "Playlist Tab" contains EsPlaylist.
* When you use Playlist Layout of QuickSetup, EsPlaylist will be replaced with default playlist view.
Maybe the default playlist view will appear if you resize the window.
* When you push "Cancel",
Maybe EsPlaylist will appear if you resize the window.
I guess that Playlist Tab forget to resize the panels.
(I reported to Peter.)
*Edit: fixed typo
Reply #121
Bug:
Unless I'm mistaken, there's currently no way to disable a "Library Selection" playlist from appearing whenever using the ESplaylist as a media library viewer.... Even when the option "None" is used for selection change.
Reply #122
do you have any idea if the phenomenon of only one playlist for all media library viewers (EsPlaylist, Facets, Album List) is caused by EsPlaylist or by foobar itself (or maybe by facets)?!
I guess this issue(using Facet Playlist instead of Library Viewer Selection Playlist) is not a bug of EsPlaylist.
EsPlaylist only notify the foobar2000 core of the selected tracks ,
and doesn't decide which playlist should be used about "Library Viewer Selection Playlist".
(note: EsPlaylist always notify in case of Browse Library mode.)
I don't know this issue is a bug of the foobar2000 core.
Bug:
Maybe not bug.
it seems that you should disable "Preferences->Media Library->Library Viewer Selection Playlist->Enabled"
* Fixed typo
Reply #124
EsPlaylist v0.0.9.0 beta (2010/04/11) released.
Changelog:
  • added two special columns.
  • added drawing border around albumart.
  • added double click action on a track in Browe Library action.
Download EsPlaylist v0.0.9.0 beta
