Topic: WSH Panel Mod script discussion/help (Read 1420913 times) previous topic - next topic
Reply #4175
@Spanky Monkey, my button scripts only support normal and hover states which is ok for your SAC button but you won't be able to add buttons with down states unless you hack it.
extract this zip into your foobar profile folder.
https://dl.dropboxusercontent.com/u/22801321/wsh2015.zip <<there are a few other basic scripts inside for album art, seekbar, volume, playback buttons and rating.
then place this script inside a panel. modify the folder path if you need to.
// ==PREPROCESSOR==
// @name "SAC Button"
// @author "marc2003"
// @import "%fb2k_profile_path%wsh_marc2003\js\lodash.min.js"
// @import "%fb2k_profile_path%wsh_marc2003\js\helpers.js"
// @import "%fb2k_profile_path%wsh_marc2003\js\panel.js"
// ==/PREPROCESSOR==
folders.images = fb.ProfilePath + "buttons_gfx\\";
var panel = new _.panel("SAC Button", ["custom_background"]);
var buttons = new _.buttons();
buttons.update = function () {
if (fb.StopAfterCurrent)
//if the hover image is the same as the normal, you can just leave it out
this.buttons.sac = new _.button(0, 0, 36, 36, {normal : "SACon_n_36.png"}, function () { fb.StopAfterCurrent = !fb.StopAfterCurrent; }, "Disable Stop After Current");
else
this.buttons.sac = new _.button(0, 0, 36, 36, {normal : "SACoff_n_36.png", hover : "SACoff_h_36.png"}, function () { fb.StopAfterCurrent = !fb.StopAfterCurrent; }, "Enable Stop After Current");
window.RepaintRect(this.buttons.sac.x, this.buttons.sac.y, this.buttons.sac.w, this.buttons.sac.h);
function on_playlist_stop_after_current_changed() {
buttons.update();
function on_size() {
panel.size();
buttons.update();
function on_paint(gr) {
panel.paint(gr);
buttons.paint(gr);
buttons.move(x, y);
function on_mouse_leave() {
buttons.leave();
buttons.lbtn_up(x, y);
function on_mouse_rbtn_up(x, y) {
return panel.rbtn_up(x, y);
@incifinci, use [codebox ] tags instead of [code ]
as for your script error, just delete this as it's not even used.
var info = g_focus_metadb.GetFileInfo();
and you might as well use foo_textdisplay (DUI) for displaying file tags or item details (CUI - it's built in)
@samithaj,
looking at the code on line 1166 might be a start. you should know better by now....
does my unmodified script also crash? if so, tough... i can't do anything to troubleshoot as i don't have my own computer. if it's your mods, then you fix it...
you can always put the code inside try/catch like this
try {
//some dodgy code
} catch(e) {
//something went wrong but at least the script didn't crash
Reply #4176
Thanks ever so much for looking into this.  I apologise for the dropbox link.  Dropbox used be more solid, but lately it's been temperamental, and the ad doesn't instil much confidence for the person clicking the link.  I used that hosting because it allows for 30 days until expiry, I should take a look for something better that doesn't require singing up.
That script works fine as it's own panel.  I initially had an error come up regarding line 36 in the helper.js (all the activeX stuff), which I just commented out to make it behave.
I can see that it would be nightmarish to try and integrate the two scripts together into just one panel (one can't just treat it like German nouns and ram them together to make a new word "Hand" + "Schuh" = "Handschuh" otherwise known as a glove to English speakers).
Actually, because of the inability to get the 'down' state to work, it's very similar, albeit a better way to do it, than when I mashed a little of Delphi's script in and just used the hover graphic for the button.  So the graphic for the on/off state is being made in window.repaint() - which is probably incorrect to do, whilst the hover outer border is being drawn by buttons.js script.  However, your script gives a nice tool tip as well, which couldn't be done the way I was ham-fistedly going at it.
This'll do just fine and I can modify the script to facilitate indicators of other things (playback mode etc).
Thanks again Marc, that's helpful stuff and I can take a good look at the other scripts knocking around in there too.
All the best.
Reply #4177
Actually i looked at 1166 line(I didn't make changes to common8.js file)
It's on
panel.rbtn_up
this.is_stream = function() {
        //support m-TAGS (foo_tags.dll)
        var path = tf("$if2(%__@%,%path%)", this.metadb);   // 1166 line
        switch(true) {
            case path.indexOf("http") == 0:
            case path.indexOf("mms") == 0:
                return true;
            default:
                return false;
I don't think p.rbtn_up even get called(In my knowledge, since this is part of a huge code i don't understand ). I got this error by just changing the tracks
But your unmodified script doesn't crash.
I guess i have have to clean up my own mess
I'll try with putting try catch blocks
thanks marc!
BTW
your new scripts are working well ,Thank you for this marc!!!
except for the ones in extras folder, i think couple of js files are missing
Nice work including lodash.min.js , I guess this improves efficiency
edit: putting try catch blocks  to all p.rbtn_up stopped the crashing
Reply #4178
i should have mentioned you need to disable safe mode (file>preferences>tools>wsh panel mod)
edit: readme inside zip file has now been updated.
Reply #4179
Now, I'm using WSH Panel Mod to toggle one of my panels.
When the toggle is 'on', the panel width=349
and
when the toggle is 'off'', the panel width =1.
var COLOR_BTNFACE = 15;
var toggle = window.GetProperty("toggle", false);
var ww = 0, wh = 0;
var g_syscolor = 0;
function get_colors() {
    g_syscolor = utils.GetSysColor(COLOR_BTNFACE);
get_colors();
// START
    ww = window.Width;
    wh = window.Height;
    if(toggle) {
        window.MinWidth = 349;
        window.MaxWidth = 349;
    } else {
        window.MinWidth = 1;
        window.MaxWidth = 1;
    window.MinHeight = 4;
    window.MaxHeight = 4;
    gr.FillSolidRect(0, 0, ww, wh, g_syscolor);
    toggle = !toggle;
    window.SetProperty("toggle", toggle);
    if(toggle) {
    } else {
function on_colors_changed() {
    get_colors();
    window.Repaint();
function on_notify_data(name, info) {
    switch(name) {
        case "center_pane":
            toggle = !toggle;
            if(toggle) {
            } else {
            break;
    return true;
From this code, I can't reduce the panel size to "0".
It looks like that "window.MinWidth = 0" doesn't work.
Is there any method to make the panel disappear completely when the toggle is 'off"?
Reply #4180
yup, just tried that myself. there's nothing you can do about that. if using columns UI, you can show/hide panels with panel stack splitter.
Reply #4181
Hello, marc2003. I've just tried to send you a private message, but it seems you disabled them.
So, I've started customizing my foobar2k and it seems that most of the WSH scripts were made by you. Unfortunately, all the links are already dead. I would appreciate it, if you could share your scripts. Especially Playcount Sync and Bio/Art viewer.
Reply #4182
sorry but i'm no longer sharing any scripts that access online services. there might be some old versions lurking around as part of people's themes on deviantart.
Reply #4183
i'm know i'm going to regret this (  ) but i've put most of my scripts back online here: https://github.com/19379/wsh_marc2003
pay special attention to the readme, especially this last part...
I'm not taking feature requests and I'm not restoring any scripts or features missing from previous packages. Genuine bugs can be reported here:
https://github.com/19379/wsh_marc2003/issues
most notably, playcount sync and thumbs are missing because they were the biggest headaches... and people who already have working scripts don't really need this. it's more for people who missed out before.
edit: i forgot to include a required font inside the zip so it has been updated.
Reply #4184
Wisdom
Reply #4185
^how is your JSbrowser coming along? i did see your preview on DA but it seems you've been on holiday or something?
Reply #4186
Yay! Thank you so much!
Also I've managed to get Playcount script from one of the fb2k themes. I've changed the API key and the secret and it works just fine. Autolove feature is great.
But if you don't mind could you help me with one little thing? Is it possible to unlove a track when I change its rating from 5 to 1-4? Pretty please. And I will never ask you about playcount sync again. :3
P.S. I have common8.js version.
Reply #4187
Ok, I added additional IF statements in two places:
if (this.time_elapsed == 3 && this.auto_love && tfe(this.auto_love_tf) == 0 && this.old_userloved == 1) {
            p.console("Automatically unloving this track....");
            this.love_track();
and
if (this.auto_love && tfe(this.auto_love_tf) == 0 && this.old_userloved == 1 && this.auto_love_count == 1) {
            this.auto_love_count = 0;
            this.love_track();
So, the tracks are loved/unloved based on rating and console doesn't show any errors. I've also recreated customdb_sqlite.db to check if the records are deleted when I unlove the tracks - everything is fine. Now I'm happy. :)
But please, let me know if there are any errors.
Reply #4188
i don't think the 2nd snippet will run because you're checking that this.auto_love_count == 1 but its value is 0 when a new track begins. i think i put it in to prevent multiple requests by people messing with their ratings but now you're using your own last.fm API KEY, you can just remove it.
if (this.auto_love && tfe(this.auto_love_tf) == 0 && this.old_userloved == 1) {
            this.love_track();
Reply #4189
Thank you! Yes, it seems without this.auto_love_count the code runs 2 times in a row. I mean with this.auto_love_count console shows this on love/unlove a song:
Last.fm Playcount Sync: Automatically loving this track....
Last.fm Playcount Sync: Attempting to love "Naval" by "Yann Tiersen"
Last.fm Playcount Sync: Contacting Last.fm....
Last.fm Playcount Sync: Track loved successfully.
Last.fm Playcount Sync: Automatically unloving this track....
Last.fm Playcount Sync: Attempting to unlove "Naval" by "Yann Tiersen"
Last.fm Playcount Sync: Track unloved successfully.
[/size]
But with your code (without this.auto_love_count) it shows this:
[/size]
Although I don't quite understand why we need it. ¯\_(ツ)_/¯
Reply #4190
i guess that's the real reason i kept track of the number of attempts. it'll need restoring...
    this.playback_edited = function() {
        if (!this.auto_love || this.auto_love_count == 1)
            return;
        this.auto_love_count = 1;
        if (tfe(this.auto_love_tf) == 1 && this.old_userloved == 0) {
            p.console("Automatically loving this track....");
            this.love_track();
        } else if (tfe(this.auto_love_tf) == 0 && this.old_userloved == 1) {
            this.love_track();
i didn't even test what i posted previously because i don't have this feature in my own scripts.
Reply #4191
Auto unloving doesn't work with this code. I think you've also made other changes in common8.js. But whatever, I'll just stick with 2 snippets I've posted above, because everything works fine with them.
Thank you for your awesome scripts!
Reply #4192
it should have worked but... whatever. the whole point of that last change was to prevent it running more than once to prevent the double server requests. this also means you can't rate something to 5 (and have the love action trigger) and then unrate it immediately expecting the unlove action to work because it won't. that shouldn't be an issue under normal usage but might not be desirable when testing.
Reply #4193
i've noticed that last.fm are edging closer to making their beta site go live which will break my last.fm bio script. if they were to flip the switch right now and my script checked a file that was more than a day old, the good data would be wiped which isn't too clever. this version disables checking for updates when existing data already exists.
https://github.com/19379/wsh_marc2003/releases
just extracting the wsh_marc2003 folder while foobar is closed should be good enough.
Reply #4195
marc2003, so, playcount sync will stop working too? That's a shame. I haven't had enough time to enjoy it. ~_~
Btw, I've captured the video where I'm testing different code snippets: https://my.mixtape.moe/binfgr.webm
Maybe someone modified common8.js before me and that's why your snippets don't work as expected. Or maybe I've placed them in a wrong part of the code, lol.
EDIT: Forgot to remove the second instance of this.auto_love_count in the first video. Here is a video of double loving/unloving: https://my.mixtape.moe/mtuowd.webm
Reply #4196
no, playcount sync will continue to work. it's just the bio script that will stop. i could probably make it work with the beta right now but i'm not doing anything until it goes final.
for people who have old copies of my thumbs script kicking around, that will also stop working when the new site goes live.
Reply #4197
Ok, cool. Too bad that Thumbs will stop working. I use it in combination with Biography script. Actually, every other theme contains this script, because foo_uie_biography doesn't show more than 1 image, and the biography text is truncated to 300 characters.
Any chance you will bring it back? For example, without your own API key and via the super-secret password protected link. :]
Reply #4198
just posting to say last.fm are currently in the process of breaking their API...hopefully just temporarily
artist top tags / artist top tracks (api key is fine on other feeds)
{"error":{"code":10,"message":"Invalid API key - You must be granted a valid key by last.fm"}}
artist top albums
{"error":{"code":3,"message":"Invalid Method - No method with that name in this package"}}
i'm also seeing playcount discrepancies between library.gettracks (used by playcount sync import) and track.getinfo (used when updating playcounts during playback).
Reply #4199
Last.fm Bio: Should now handle the switch to the new Last.fm website when it goes live.
User Recommendations: Fix overlapping text on narrow panels.
