Topic: WSH Panel Mod script discussion/help (Read 1413391 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #1600
Hey,
If possible I would like to be able to get the IFbMetadbHandle for the item that will become the playing item when playback is started.
Let's imagine that I have a playlist containing tracks A, B and C and that I also have cursor follows playback and playback follows cursor disabled. I currently have track A selected and I'm actually playing track B. Then I hit stop and, after the playback stops, I restart foobar. When I hit play, track B will be played again.
I wish to get the IFbMetadbHandle for track B on start-up. So before playback is started and regardless of whether another track, such as A, is selected - is this possible and how?
Cheers
Reply #1601
is there any way to get info from embedded cue in playlist?
Reply #1602
@Falstaff
Using WSH Playlist Viewer 2.0. I have the Group Header set to 3 lines so tracks, codec, genre line shows. If the stream is WMA V2 then the codec shows as ? (question mark). Codec shows up okay in the status bar (codec & codec profile). MP3 and AAC look okay.
Is this just my computer? Also is it possible to have that line as black text instead of grey?
Thank you.
Reply #1604
@Falstaff
These 3 radios streams do it
mms://streaming.sbsradio.se/03872_Studio_low
mms://81.173.117.102/ArrowAudio01
mms://81.173.117.102/ArrowAudio02
Thank you.
Reply #1605
Thanks, T.P. Wang.
I am wondering if there a way to change mp3 these tags by foobar?
ex. plman.SetPlaylistSelectionTag(target, val)
or XXX.SetProperty(name, val)
Is there anyone can help me?
Thank you!
Reply #1606
look at UpdateFileInfoSimple in interfaces.txt
Reply #1608
Is it can only be uses in one song at one time?
Can it be able to use in multi-song at one time?
Reply #1609
you could loop through an array of items something like this...
items = plman.GetPlaylistSelectedItems(plman.ActivePlaylist);
for (i = 0; i < items.count; i++) {
    items.item(i).UpdateFileInfoSimple("title", "test");
Reply #1610
I've updated my vertical volume bar script so that the tooltip showing the volume will update while the mouse-wheel is being scrolled on the bar. Code below
// ==PREPROCESSOR==
// @name "Volume-bar with tooltip"
// @author "rawny"
// ==/PREPROCESSOR==
// Based somewhat on:
// -> "Volbar with GdiDrawText" by T.P Wang
// -> "Simple Seekbar" by marc2003
var a = 25;
var g_drag = 0;
var g_drag_seek = 0;
var g_tooltip = window.CreateTooltip();
var g_trackingMouse = false;
var old_x;
var old_y;
function RGB(r, g, b) {
    return (0xff000000 | (r << 16) | (g << 8) | (b));
function RGBA(r, g, b, a) {
    return ((a << 24) | (r << 16) | (g << 8) | (b));
function on_size() {
    ww = window.Width;
    wh = window.Height;
function on_paint(gr){
    var ww = window.Width;
    var wh = window.Height;
    var pos = 0;
    var volume = fb.Volume;
    if(g_drag){
        pos = wh * g_drag_seek;
    }else{
        pos = wh * Math.exp(fb.Volume/a);
    gr.FillGradRect(0, wh-pos, ww, wh, 90, RGB(0,0,255), RGB(70,90,200));
    gr.FillGradRect(0, 0, ww, wh-pos, 90, RGB(0,0,0), RGB(50,50,50));
    gr.DrawRect(0,0, ww-1, wh-1, 1.0, RGB(100,100,100));
function on_mouse_move(x,y){
    // Set the cursor to the hand symbol:
    window.SetCursor(32649);
    g_drag_seek = 1-y/wh;
    g_drag_seek = (g_drag_seek<Math.exp(-100/a)) ? Math.exp(-100/a) : (g_drag_seek<1) ? g_drag_seek : 1;
    if(x > ww){
        g_drag = 0;
    if(g_drag){
        window.Repaint();
    if(!g_trackingMouse){
        g_tooltip.Activate();
        g_tooltip.TrackActivate = true;
        g_trackingMouse = true;
    if(x != old_x || y != old_y){
        txt = Math.ceil(a*Math.log(g_drag_seek))+"dB ("+Math.ceil(g_drag_seek*100)+"%)";
        g_tooltip.Text = txt;
        g_tooltip.TrackPosition(x+10,y-10);
        old_x = x;
        old_y = y;
function on_mouse_leave(){
    g_tooltip.TrackActivate = false;
function on_mouse_lbtn_down(x,y){
    g_drag = 1;
function on_mouse_lbtn_up(x,y){
    if(!g_drag){
        return;
    g_drag = 0;
    var v = 1-y/wh;
    v = (v<Math.exp(-100/a)) ? Math.exp(-100/a) : (v<1) ? v : 1;
    fb.Volume = a*Math.log(v);
function on_mouse_wheel(delta){
    if(delta>0){
        fb.VolumeUp();
    }else{
        fb.VolumeDown();
    g_tooltip.Text = Math.ceil(fb.Volume)+"db ("+Math.ceil((Math.exp(fb.Volume/a))*100)+"%)";
    var ttY = wh-(wh * Math.exp(fb.Volume/a));
    g_tooltip.TrackPosition(10, ttY-8);
function on_volume_change(val){
    window.Repaint();
Reply #1611
Thank you!
Can you tell me why GetPlaylistSelectedItems need to use count and item?
I have used following codes yesterday:
var items = plman.GetPlaylistSelectedItems(plman.ActivePlaylist);
    for (i=0; i<items.length; i++) {
        items[i].UpdateFileInfoSimple("title", "test");
But nothing happen.
Reply #1612
from the docs...
interface IFbMetadbHandleList
Properties:
    (readonly) uint Count;
    // [1.5.0 Preview 6]: Changed, now writable.
    (read, write) IFbMetadbHandle Item(idx);
Reply #1613
from the docs...
Properties:
Thank you, and sorry for stupid questions.
I never learn programming language from teachers or books.
I even can't understand whole files in docs very well.
So, I'm very appreciate your teaching.
When I have other questions can I ask you by PM?
Thank you!
Reply #1614
it's better to ask questions in this thread. other people can answer and also others can learn if they get stuck doing the same kind of thing.
Reply #1615
Given a reference to a track (e.g. the currently playing track), is there any way to get an IFbMetadbHandleList of the group that it resides in within EsPlaylist?
Edit: I guess my best alternative option is to fake it by having the script create an autoplaylist based on the same query that forms the group. Unless anyone can think of any better ideas?
Reply #1616
XD But my questions are very stupid, isn't it?
The new question is:
Can we change .txt or .lrc in WSH Panel Mod script?
I want to replace some words in .txt or .lrc files.
Reply #1617
@Falstaff
WSH Playlist Viewer  2.0.1
Thanks for the awful nice item for DUI very nicely in the "se7en", but in XP selected mouse line has completely white background (I have a dark theme and it is very contrasting).
what part of the code, you can assign a color to the selected row?
Reply #1618
@San_dr
you know there are options in my script? Just disable Themed style in settings! untick this menu item :
Reply #1619
@San_dr
Now re-unpacked wsh_playlist_viewer_v2_0_1_by_br3tt-d4se96u.zip and applied the "pure" script. But no change. This may not be related to the settings XP? In the "7" gray highlighted line (with a black background). And I want to ask - in the properties panel, the first item *USER.background.image.enabled - True
Do I understand that you can add your background picture? I can not do it. Desired image background.jpg 800x600 placed in Foobar2000\images...
Thanks for the prompt
Reply #1620
on your screenshot, "USe Themed Style" is ticked, so it's normal that you have a styled lined (white), so just untick it, and show me the result please, normally, no more white background line ==> ok?
Reply #1621
Reply #1622
i need to collect some statistics, so i need a kind of database. can i somehow connect with sql base or i can store data in text files without longer search time?
toSan_dr are you russian too?
Reply #1624
When I try and rename my playlist tabs or sort the playlist, WSH mod crashes. Using foobar 1.1.11 wsh panel mod 1.5.3.1 any help would be appreciated
