Topic: WSH Panel Mod script discussion/help (Read 1413637 times) previous topic - next topic
0 Members and 7 Guests are viewing this topic.
Reply #1476
Hi there,
I've written a script which displays a vertical volume bar with a tooltip showing the volume (based on "Simple Seekbar" by marc2003 and "Volbar with GdiDrawText" by T.P. Wang). The code is below if anyone is interested
// ==PREPROCESSOR==
// @name "Volume-bar with tooltip"
// @author "rawny"
// ==/PREPROCESSOR==
// Based somewhat on:
// -> "Volbar with GdiDrawText" by T.P Wang
// -> "Simple Seekbar" by marc2003
var a = 25;
var g_drag = 0;
var g_drag_seek = 0;
var g_tooltip = window.CreateTooltip();
var g_trackingMouse = false;
var old_x;
var old_y;
function RGB(r, g, b) {
    return (0xff000000 | (r << 16) | (g << 8) | (b));
function RGBA(r, g, b, a) {
    return ((a << 24) | (r << 16) | (g << 8) | (b));
function on_size() {
    ww = window.Width;
    wh = window.Height;
function on_paint(gr){
    var ww = window.Width;
    var wh = window.Height;
    var pos = 0;
    var volume = fb.Volume;
    if(g_drag){
        pos = wh * g_drag_seek;
    }else{
        pos = wh * Math.exp(fb.Volume/a);
    gr.FillGradRect(0, wh-pos, ww, wh, 90, RGB(0,0,255), RGB(70,90,200));
    gr.FillGradRect(0, 0, ww, wh-pos, 90, RGB(0,0,0), RGB(50,50,50));
    gr.DrawRect(0,0, ww-1, wh-1, 1.0, RGB(100,100,100));
function on_mouse_move(x,y){
    g_drag_seek = 1-y/wh;
    g_drag_seek = (g_drag_seek<Math.exp(-100/a)) ? Math.exp(-100/a) : (g_drag_seek<1) ? g_drag_seek : 1;
    if(x > ww){
        g_drag = 0;
    if(g_drag){
        window.Repaint();
    if(!g_trackingMouse){
        g_tooltip.Activate();
        g_tooltip.TrackActivate = true;
        g_trackingMouse = true;
    if(x != old_x || y != old_y){
        txt = Math.ceil(a*Math.log(g_drag_seek))+"dB ("+Math.ceil(g_drag_seek*100)+"%)";
        g_tooltip.Text = txt;
        g_tooltip.TrackPosition(x,y-20);
        old_x = x;
        old_y = y;
function on_mouse_leave(){
    g_tooltip.TrackActivate = false;
function on_mouse_lbtn_down(x,y){
    g_drag = 1;
function on_mouse_lbtn_up(x,y){
    if(!g_drag){
        return;
    g_drag = 0;
    var v = 1-y/wh;
    v = (v<Math.exp(-100/a)) ? Math.exp(-100/a) : (v<1) ? v : 1;
    fb.Volume = a*Math.log(v);
function on_mouse_wheel(delta){
    if(delta>0){
        fb.VolumeUp();
    }else{
        fb.VolumeDown();
function on_volume_change(val){
    window.Repaint();
Reply #1477
Also, does anyone know how to produce glowing text with GdiDrawText?
As in this sample (but with GdiDrawText):
// ==PREPROCESSOR==
// @name "Glow Text Sample"
// @author "T.P Wang"
var g_font = gdi.Font("Segoe UI", 22, 1);
var g_drag = false;
var g_textrender = gdi.CreateStyleTextRender();
var g_bkclr = RGB(0, 0, 0);
function on_paint(gr) {
    gr.SetTextRenderingHint(5);
    gr.SetSmoothingMode(4);
    gr.SetInterpolationMode(7);
    // Draw background first
    gr.FillSolidRect(0, 0, ww, wh, g_bkclr);
    g_textrender.GlowText(RGB(0, 0, 64), RGBA(255, 255, 0, 30), 12);
    // Clear previous shadow setting
    g_textrender.EnableShadow(true);
    g_textrender.ResetShadow();
    g_textrender.RenderStringRect(gr, "Glow Text Sample", g_font, 0, 0, ww, wh, 0x11005000);
My current poor-man's version is to draw multiple copies of the text in the glow colour underneath the actual text:
// ==PREPROCESSOR==
// @name "Poor-man's glowing Gdi text"
// @author "rawny"
var text = "foobar2000";
var textFont = gdi.Font("Tahoma", 50, 1);
var textX = 100;
var textY = 100;
var glowSpacing = 4;
var rightGlowTextX = textX+glowSpacing;
var rightGlowTextY = textY+glowSpacing;
var actualTextX = textX+(glowSpacing/2);
var actualTextY = textY+(glowSpacing/2);
var bgColour = RGB(0,0,0);
var glowColour = RGBA(0, 0, 255, 222);
var textColour = RGBA(255, 255, 255, 222);
    ww = window.Width;
    wh = window.Height;
    gr.FillSolidRect(0, 0, ww, wh, bgColour);
    gr.GdiDrawText(text, textFont, glowColour, textX, textY, ww, wh);
    gr.GdiDrawText(text, textFont, glowColour, textX, rightGlowTextY, ww, wh);
    gr.GdiDrawText(text, textFont, glowColour, rightGlowTextX, textY, ww, wh);
    gr.GdiDrawText(text, textFont, glowColour, rightGlowTextX, rightGlowTextY, ww, wh);
    gr.GdiDrawText(text, textFont, textColour, actualTextX, actualTextY, ww, wh);
I'm fairly happy with this effect, but I was wondering if there was a way to do it properly?
Reply #1478
WSH Playlist Viewer v2 beta 5 : http://pastebin.com/u/Br3tt
example of use in a CUI config (opacity set to 0 in Properties of the panel in order to see the background which is a PanelStack Splitter that display the artist image of the current track)
Reply #1479
Playlist Viewer Beta 5. I would like to have a 1 line group header. This is what I get -
Streaming Radio - Streaming | undefinedundefined
FLAC Files - Artist | undefinedundefined
Is this how it should be? Beautiful playlist. Thank you.
Reply #1480
nope, a small bug, sorry  will be fixed in next beta
Reply #1481
Playlist Viewer Beta 6. Group header bug fixed, thank you. In the Appearance settings I have turned off the light shadow border. But there is still a shadow border after last item in playlist. Is it possible to turn that off also? Thank you.
Reply #1482
no. but you can edit the script to fit your needs, just remove the lines of code that draw this shadow (near line 622)
            if (this.id == list.total - 1) {
                gr.FillSolidRect(this.x, this.y + this.h + 0, this.w - vscrollbar.w, 1, RGBA(0, 0, 0, 75));
                gr.FillSolidRect(this.x, this.y + this.h + 1, this.w - vscrollbar.w, 1, RGBA(0, 0, 0, 35));
                gr.FillSolidRect(this.x, this.y + this.h + 2, this.w - vscrollbar.w, 1, RGBA(0, 0, 0, 12))
Reply #1483
Thank you, that worked perfectly. Excellent playlist.
Reply #1484
Whenever I try to sort either by Album or Artist using Playlistviewer Beta 6 it keeps crashing, this is what's coming up in the console:
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 6 v0.0.6.20120423.2349 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Microsoft JScript runtime error:
Object doesn't support property or method 'SortByFormat'
File: <main>
Ln: 3482, Col: 3
<source text only available at compile time>
Reply #1489
Falstaff, i get an error at startup (with a filled autoplaylist selected):
Foobar2000 v1.1.11 + Windows Scripting Host Panel Modded v1.5.3.1 (Build: 19:48:41, Apr 20 2012)
W7x64
Console:
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 6 v0.0.6.20120423.2349 by Br3tt aka Falstaff >> [url=http://br3tt.deviantart.com):]http://br3tt.deviantart.com):[/url]
Object doesn't support this property or method
File: <main>
Ln: 541, Col: 4
something goin' wrong at:
if (typeof this.id == "undefined") {
if (this.metadb) {
541 this.group_key = tf_group_key.EvalWithMetadb(this.metadb);
But after that is seems to run ok.
Reply #1490
thanx Mod-Ular, it has already be reported to me (same bug), it should be fixed for the next beta
Reply #1491
WSH Playlist Viewer v2 beta 7 : http://pastebin.com/u/Br3tt
- bug on launch (for who's encountered it) fixed (i hope, tell me about it)
- queue info added for queued tracks + special "Queue content playlist" added to see the queued tracks as a special playlist (check settings menu from the toolbar)
Reply #1492
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> [url=http://br3tt.deviantart.com):]http://br3tt.deviantart.com):[/url] Microsoft JScript runtime error:
'list.item[...].id' is null or not an object
File: <main>
Ln: 1814, Col: 3
Still getting an error..  .
Reply #1494
File: <main>
Ln: 1814, Col: 3
yep, but not the same
could you gimme more info on how it happens ? (playlist content (large, small number of items), action you where doing, ... all that could help me because i can't reproduce this bug, thanx)
Reply #1495
Fallstaff,
In my case the script only fails at fb2k startup. (with a huge Media Library, not tested otherwise)
Medium sized Autoplaylists containing 75-125Gig and 5,000-7500 items.
Everything autosorted by %path_sort%
I see u added queueing functions. Maybe worthwhile to mention the related components i use?
foo_keep_queue: Keep Queue 0.3.5 (by Andreas "Qtax" Zetterlund, Prevents the playback queue from being removed when changing song manually or exiting)
foo_queuecontents: Queue Contents Editor 0.5.1 (by Sami Salonen)
Good luck bug-hunting
Reply #1496
@Mod-Ular
thanx for the reply, i've tried both (foo_queuecontents and foo_keep_queue) but i can't make it crashes ...
have you installed the last version of WSH panel mod at least? v1.5.3.1 ?
have you try to clear the panel Properties ?
Reply #1497
Yes, Windows Scripting Host Panel Modded v1.5.3.1 (Build: 19:48:41, Apr 20 2012)
I've reset the properties. (I only adjusted a few settings in the USER-fields.)
But i'm getting the same error at Foobar Startup as mentioned above.
In console i see the script initialising without problems:
WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): initialized in 10 ms
After console shows startup time (everything is loaded), it crashes:
Startup time : 0:37.911965
Error: WSH Panel Mod (WSH Playlist Viewer v2 beta 7 v0.0.7.20120424.2339 by Br3tt aka Falstaff >> http://br3tt.deviantart.com): Microsoft JScript runtime error:
File: <main> Ln: 1814, Col: 3 <source text only available at compile time>
Reply #1499
Fallstaff,  I cannot open that zip-archive. Downloaded it 3 times but it seems to be corrupted...
