Making a list of all WV files with a deviant compression
Reply #2 – 2009-12-17 16:35:09
I'm not very good with DOS batch scripts. The lack of piping text output and the lack of any native text stream processor makes it very hard to achieve what I'm planning to do: foobar2000 does not support showing the exact encoding profile in Wavpack files. All it shows will be "Wavpack fast", "Wavpack normal"(?) and "Wavpack high". But I want to transcode all Wavpack files to a certain compression level and the problem is that some of my files have already been compressed with those settings but many haven't. The only tool I know that can show me the actual compression settings is wvunpack.exe. Now if I were using a Linux machine, it be a piece of cake for me to write a shell script that gives me a list of all WV files that do not match my preferred compression. (I need to get a list although I could transcode them right away using the script, but since I have a quad core I'd rather have a multi-threading capable launcher do that, like foobar2000). So how would I get it done in Windows? I guess it would be very easy with Powershell, although lerning how to use the PS isn't that easy... A simplified version of my script:@echo off :::::::::::::::::::: :: DEPENDENCIES: :: - flac :: - mac :: - wavpack :: - wvunpack :::::::::::::::::::: :: SETTINGS set PACKER.CMD=wavpack -hhx6 %%in%% %%out%% set PACKER.FILE_EXTENSION=wv :::::::::::::::::::: :: START :get_temp_file_name set TMP_FILE=%TMP%\c%RANDOM%.tmp IF EXIST "%TMP_FILE%" goto get_temp_file_name for /r %%a in (*.*) DO echo "%%a">>"%TMP_FILE%" for /f "delims=" %%a in (%TMP_FILE%) DO call :convert %%a del "%TMP_FILE%" :convert ::there's an issue with files containing '&' character. That's why I add and remove the quotes set fst="%~nx1" call :DeQuote fst set name="%~n1" call :DeQuote name echo "%fst%" set Delete=1 :: convert to wav if /i [%~x1] == [.wav] ( set Delete=0 goto compress ) if /i [%~x1] == [.ape] ( mac "%fst%" "%name%.wav" -d if [.%PACKER.FILE_EXTENSION%] == [%~x1] rename "%~dpnx1" "_%~nx1" goto compress ) if /i [%~x1] == [.flac] ( flac -d "%fst%" "%name%.wav" if [.%PACKER.FILE_EXTENSION%] == [%~x1] rename "%~dpnx1" "_%~nx1" goto compress ) if /i [%~x1] == [.shn] ( shorten -x "%fst%" "%name%.wav" if [.%PACKER.FILE_EXTENSION%] == [%~x1] rename "%~dpnx1" "_%~nx1" goto compress ) if /i [%~x1] == [.wv] ( ::--------------- ADD CHECKING FOR SETTINGS AFTER THIS LINE --------------------- wvunpack "%fst%" "%name%.wav" if [.%PACKER.FILE_EXTENSION%] == [%~x1] rename "%~dpnx1" "_%~nx1" goto compress ) ::not a convertable file goto :eof :: compress one file :compress set in="%name%.wav" set out="%~dpn1.%PACKER.FILE_EXTENSION%" cmd /c %PACKER.CMD% ::cleanup if %Delete% == 1 ( del "%name%.wav" ) goto :EOF :: DeQuote :DeQuote SET DeQuote.Variable=%1 CALL Set DeQuote.Contents=%%%DeQuote.Variable%%% CALL Set DeQuote.Contents=%DeQuote.Contents:&=__AND__% Echo.%DeQuote.Contents%|FindStr/brv ""^">NUL:&&Goto :EOF Echo.%DeQuote.Contents%|FindStr/erv ""^">NUL:&&Goto :EOF Set DeQuote.Contents=####%DeQuote.Contents%#### Set DeQuote.Contents=%DeQuote.Contents:####"=% Set DeQuote.Contents=%DeQuote.Contents:"####=% Set %DeQuote.Variable%=%DeQuote.Contents:__AND__=^&% Set DeQuote.Variable= Set DeQuote.Contents= Goto :EOF 1. You need to enter checking for wavpack version in the marked place. I suggest parsing wvunpack output with grep. I don't knot what did you mean with lack of piping, but wvunpack parameters | grep grep_parameters should work. 2. Unicode file names cause problems 3. It's not thoroughly debugged 4. Just BTW, if you're into space reduction, recently I saved .5 gig just by recompressing artwork.
