Topic: HOW TO: synchronise your last.fm playback stats with foobar (Read 390385 times) previous topic - next topic
Reply #1175
i'm no longer providing or supporting my scripts so i'd like to request that this thread is locked. the last few posts contain enough information for people to fix their own scripts should they wish.
Reply #1176
marc2003, others might want to pick up where you left off. I don't think closing this thread is necessary or helpful. If you insist we will remove any code posted here by you, since from my understanding you still own said code. Using the code snippets without permission from marc2003 may or may not be illegal depending on your country's laws.
Though I still hope that the recent issues here on HA can be alleviated somehow.
Reply #1177
marc please dont let 1 guy ruin it for everyone. youre the greatest thing that happened to foobar since musicmusic. your support is invalueable
Reply #1178
I second that.
Reply #1179
I have to agree Marc. Your support around here is second to none, you're in almost every thread helping out to an amazing degree. I hope you reconsider.
Reply #1180
i'd like to cite this from a thread in 2009. at the time tedgo was one of the most helpful forum members.
http://www.hydrogenaud.io/forums/index.php...st&p=666702
tedgo, this skin recommends components that are problematic, which is against the rules. Here is the troubleshooter entry for DarkOne. Please fix this and verify your future skin versions using the Online Troubleshooter.
as problematic, although there are no problems with their settings made in DarkOne or they're updated to the latest version, its not possible to change DarkOne without destroying it completely (especially caused by PSS the configuration is based on).
So i decided to stop supporting DarkOne here on HA and request you to close this topic.
Closed at author's request.
since this script also relies on known problematic components (foo_customdb), it should also be closed.
thanks.
Reply #1181
Too bad that you close the project, most users do not want this.
last.fm | bulletproof2k
Reply #1182
Fine.
