Again, can't setup it for user-separated config
After importing of script text, wsh panel don't show any icon, only "set api key" "set lastfm username", etc. in the context menu
Library import commands are unavailable
here is info from console:
WSH Panel Mod (Playcount Sync by marc2003): Parsing file "C:\Users\Администратор\AppData\Roaming\foobar2000\\marc2003\common.js"
WSH Panel Mod (Playcount Sync by marc2003): Parsing file "C:\Users\Администратор\AppData\Roaming\foobar2000\\marc2003\tooltip_buttons.js"
WSH Panel Mod (Playcount Sync by marc2003): initialized in 35 ms
WSH Panel Mod (Playcount Sync by marc2003): initialized in 3 ms
marc2003 and playcount sync folders are placed into foobar2000 profile folder
add:
The same problem even with portable foobar2000:
WSH Panel Mod (Playcount Sync by marc2003): Parsing file "E:\Program Files\foobar2000\\marc2003\common.js"
WSH Panel Mod (Playcount Sync by marc2003): Parsing file "E:\Program Files\foobar2000\\marc2003\tooltip_buttons.js"
WSH Panel Mod (Playcount Sync by marc2003): initialized in 4 ms
What's wrong?
