Topic: List of AAC encoders (Read 52617 times) previous topic - next topic
Could you elaborate, please? Which bitrates do you mean by low/middle?
Thanks,
I give a try at 96/128 kbit/s for some samples and find that quality is not on par with Nero and Apple. But it is not the reason to discard right now this encoder. More detailed test is needed.
I believe that encoders from Microsoft and DivX still need lot of work and improvement in quality.
It would be good if someone could do a listening test on them.
Microsoft Expression Encoder 2 SP 1 and higher support H.264 and LC-AAC encoding. Don't know what encoder is behind that, though.
which is not free iirc...the only free way is to use the libraries from win7 but the AAC encoder is very limited (LC only - 128/160/192kbps as target bitrates).
I didn't say it's free. The only options are CBR 96 kbps to 192 kbps, 44.1 and 48 KHz, stereo and mono. The produced CBR files don't seem to be CBR though - more like ABR.
As for the libraries in Windows 7, I didn't find a way to use them yet. When I try to use the auto-encoding feature Windows 7 offers I only get MP3 files and in own programs I cannot seem to be able to access the library without initializing it with some special stuff I don't know.
First post here...Hi!. For 2.1 music PsyTel works very well at high bitrates. It was a favorite at one time and I'm not sure human ears have evolved much since. It has (severe) limitations for portable use but for the home or office workstation its as flawless a reproduction as I have found at/near the highest settings (bitrates>250) for any lossy encoder  One aspect of testing that I do is how robust an encode is when its result is further processed by EQ plugins and other enhancements that most of us have played with at one time or another. I have found PsyTel's 2 highest settings (Archive and Ultra) to be the most robust (meaning less instrument clipping, etc) of any encoder at any setting to user tweaking after the fact. I don't have a clue why, perhaps some here with more technical knowlege could chime in. Its worth trying and ABXing if you're bored. I don't use nor have tested Nero but I suspect its very similar.
potato
Sorry for the delay...it's available here.
Thank you for your time. What settings did you try with Divx AAC encoder?
I tried beta 1 http://labs.divx.com/node/11682 VBR mode -V 3 ~100 kbit/s and found that Divx has good quality actually.
IIRC MS AAC encoder is only available in Windows 7 and  Server 2008 R2.
Reply #34
A lot of those converters online just seem to be shells for ffmpeg, which uses FAAC.
Reply #37
I encoded several audio tracks with MainConcept DirectShow AAC Encoder (comes with MainConcept AAC Encoder Plug-in for Adobe Flash Media Live Encoder) using GraphEdit and MONOGRAM MP4 Mux and got results similar to DivX Plus HD AAC Encoder (CLI version downloaded from DivX site), bitrate was slightly higher (122 for MC compared to 119 for DivX). Filter version is 7.6.0.35746 2008/08/07 (7.6.0 is the SDK version, I think), latest MainConcept SDK is 8.2.0 (but I have some filters that states 8.5.0). Looking at the spectrogram, frequency cutoff are the same (looks typical, different from other encoders). Also, options that is showed in help of CLI encoder are the same options that DS filter have. Maybe DivX AAC Encoder CLI comes from a newer version of SDK? But definitely these two encoders are, more or less, the same.
Reply #38
Is DivX Plus still in beta 2 stage?
Reply #41
And I see MAGIX released v16 of their MP3 Deluxe so perhaps they have a new AAC encoder version?
Its maximum is still 256 kbps, though.
Reply #42
AVS Audio Converter 6.2 has some settings which I think are new. 256 kbps is still the highest bitrate, but they offer something called Quality 500 and various channel settings: mono, stereo, 3/0 — front, 3/1 — surround, 3/2 — surround, 3/2 + LFE 5.1 surround:
Someone said this was Liquid Audio AAC once.
Reply #44
with all the ABX'ing going on here, can I asume this* is a top 4? (meaning #1 is the best etc.)
Competitive AAC encoders:
1. Apple
2. Nero
3. Coding Technologies (now Dolby)
4. Fraunhofer. Sorenson Squeeze and Magix application(?). Have they the updated and full functionality version of Fraunhofer encoder?
I'm asking because I'm a Mac user. I chose Apple's AAC to rip my CDs (for iPod, iPhone etc.), but only 'cause I had no clue there were other AAC types at the time.
EDIT: Actually, I'm using what ever AAC is in XLD... and just assume it's Apple's?
cheers
Reply #45
At the moment Nero gives me the best results, but seeing DivX work on a decent codec is great for the development of AAC. And speaking of encoders, does anyone yet know which codec Sony is using in it's Media Go software? Is it the MainConcept codec?
That said.. things are going well for AAC en Mpeg-4..... the only things that still pisses me off are:
1. The PS3 only handling .3gp-AAC's fine
2. Apple for pushing it's .m4a-extention... Mpeg-4 should be .MP4!
The future is lossless!
Reply #46
Yes, it's Apple: QuickTime/CoreAudio AAC encoding
Reply #47
This is a common misconception.  The MP4 spec (MPEG-4 Part 14) only states that "[t]he preferred file extension is '.mp4'".  It does not require or even recommend that .mp4 be used.
Reply #48
thanks
btw., I know the rules, but my English lacks sometimes. I wasn't asking for the best sound, just wanted to know what's the "best" known version of AAC. I guess 'reference' or 'benchmark' is the word I was looking for
cheers
Reply #49
Sony Audio Studio 10 has Fraunhofer's AAC. Again the highest setting is 256 kbps.
