Topic: columns ui. cant get it set up, vert splitters are horizontal? (Read 3700 times) previous topic - next topic
wul, maybe its just me...
i cant get this ui to do anything i want.  when i add a vertical splitter, it looks like a horz splitter to me.  i see nothing that i can drag vertically to give me a side by side thing.
what im looking for is two big blocks side by side.  the left one would have multiple panels like album list over file info  over spec anylzer and the right side would all be playlist tabs.  i just cant figure out how to get these splitters set up.
also, are the vis from the default ui not available? (peak meter, spec anylizer)
and, i think the main reason i'm using CUI is that it has an activate playing song command.  does the default not have that?
thanks
right click on splitter in CUI layout settings and select change splitter type
yeah, i do that, but only the title apears to change.  i've had better luck adding stuff from the preferences.
i found the 'activate playing song' in the default ui: you need to bind a key to it, and its under [main]>view>show now playing
Or, double click the status bar.
terry
