Topic: foo_softplaylists (Read 254041 times) previous topic - next topic
foo_softplaylists
Reply #125
Sorry for off top. Is there software to generate XSPF playlists from Last.fm?
http://www.playgrub.com/
i already talked about this in a few posts before, it's a bookmarklet that can create XSPF playlists from websites, it works with last.fm and some other sites:
Apple.com iTunes Charts
Musicbraniz Releases
BBC Radio Programmes
Songkick Setlists
The Y! Radish
FIQL Playlists
Grooveshark Playlist Export
foo_softplaylists
Reply #126
would it be possible of adding the "love track" context menu for the selected elements on the playlist? that way I can love all the tracks that I have with 5 stars on my library, not doing that 1 by 1
foo_softplaylists
Reply #128
if you use columns UI/or DUI with dockable panels, you could use WSH panel mod to automatically trigger this component to automatically love 5 star rated tracks when playback begins. if you want help with this, give me a shout.
foo_softplaylists
Reply #129
a problem to report. if there is no network connection, attempting to love a track causes foobar to crash. using the other options does nothing but create an empty playlist so no problems there. see if you can re-produce by temporarily disabling your network adapter.
foo_softplaylists
Reply #130
Wow what a great add-on !!
The Love features means i can finally get rid of the LastFM client
But its a real pity i cant use the Love-feature with my remote, although WinLIRC is capable of using some elements of your component, such as 'Load XSPF Playlist' and 'Friends'... they show up in the list of WinLIRC, but other like 'Love Track' don't .. how come?
foo_softplaylists
Reply #131
you can! Just add a global shortcut for love track and associate that keyboard shortcut with a button of your remote.
foo_softplaylists
Reply #132
Thanks but, which add-on will let me associate a keyboard shortcut? Afaik, Foo_Lirc can only be associated with Foobars' standard menu commands
foo_softplaylists
Reply #133
You dont need an addon for that. just go into the preferences->keyboard shortcuts.
Then just trigger that keyboard shortcut from winlirc, or as i do eventghost
foo_softplaylists
Reply #134
Eh, how do i do that? Its only possible to execute menu-commands from within Foo_LIRC
Appreciate the help though
foo_softplaylists
Reply #135
Awesome plug! Thank you so very much!
foo_softplaylists
Reply #136
Now you dont get it. From foobar just associate the keyboard shortcut to loving the current playing track. There is no lirc in that.
Then associate that keyboard shortcut from within winlirc. I dont see the need of foo_LIRC there.
From what i have seen on the net you can associate a button with a keyboard shortcut from within your winlirc config.
Have you ever take a look at eventghost? It s pretty amazing!
foo_softplaylists
Reply #137
I can't "love" tracks in RTL characters ( eg. Hebrew )
foo_softplaylists
Reply #138
I will add some extra error checking to prevent this.
foo_softplaylists
Reply #139
Johan, I see there is space in preferences for some XSPF settings: for example enable/disable writing of:
  - album
  - tracknumber
  - length
when creating playlist
Maybe even option for creating playlist from context menu (on selected tracks)?
foo_softplaylists
Reply #140
I have been looking for a component with type of functionlity for a while now - thanks.
The last piece of functionality I am looking for is for it to be able to continually add music to an existing playlist, instead of it generating a once-off new playlist.
Ie, after a song has finished playing, lookup a further set of matching tracks and add them to the end of the current playlist (keeping track of duplicates so songs don't start repeating).
Does this make sense?
It is a feature I use all the time in Linux music players (Exaile/Listen)
foo_softplaylists
Reply #141
  - album
  - tracknumber
  - length
These are only written when they exist.
Only when a perfect match can be found, they are actually used when loading a playlist.
So is it still useful to have that option?
Can indeed also be handy.
foo_softplaylists
Reply #142
OK, it was example with i.e. FLAC playlist and other OGG playlist (converted from FLACs) and problem of finding which FLACs weren't converted. So saving OGG XSPF and loading should match FLACs (as your matching code matches alphabetically) and then with the help of foo_utils unconverted FLACs should emerged.
It was example at the time and I wrote that, but it's not big deal manually deleting lines in such cases, or removing OGGs from library and then finding the matches as in example
While thinking of another examples it occurred to me if it would be possible an option for returning more then one results: i.e. artist / track match in FLAC format than in OGG format if it exist or from the original release and if found in some compilation etc?
foo_softplaylists
Reply #143
New version:
Soft Playlists 2009-12-30
-Added: Last.fm Top Tags Top Tracks
-Added: Last.fm Custom Tags Top Tracks
-Added: ability to prefix generated Last.fm playlists
-Fixed: crash when loving a track without an internet connection
foo_softplaylists
Reply #144
Thanks for the new version. Loving tracks with RTL characters works now.
Also I love new top tags / custom tags feature!
foo_softplaylists
Reply #145
New version:
Soft Playlists 2009-12-30.2
-Added: Last.fm User, Friends and Neighbours Recent Tracks
-Added: Last.fm Top Tracks, Loved Tracks and Recent Tracks of a custom Last.fm user list
foo_softplaylists
Reply #146
Thanks for new version!
About the top tags.. Would it be possible to fetch ie. all Rock artists, albums and songs with rock tag instead of just "top tracks"?
Disregard the constabulary.
foo_softplaylists
Reply #148
As far a I know, in a way that is not too taxing for the Last.fm servers, sadly no.
That's pity..i was just wondering..probably it would took hours to generate playlists with the large music library :/
foo_softplaylists
Reply #149
An option could be to do a full library check with a certain amount of requests per second and write the last.fm tags to the music files.
Or do a full library check write all the information to an XSPF playlist and reuse that playlist to tag files.
Personally I would like to use an custom database plugin to save these tags. Is there still a stable plugin to do this?
