Topic: ALAC decoder and Hi-Res file (Read 6628 times) previous topic - next topic
I'm a FooBar 2000 user. Form few day I would like to play some files coded in M4A from a Mac (10.6.1 system with QT X). THis files are in high resolution 24 bit 96 Khz. I use an external fw device: AudoiFire 4.
If I play same file converted on flac (with sema resolution) or on wev all it's OK, when I try to use m4a format I've and error due corrupted file, but
if I play this files on Mac all it's OK.
I see that ALAC decoder plug-in works fine with 16bit/44.1 Khz but no with 24bit/96Khz.
Have you got any idea?
Regards.
The ALAC decoder components doesn't work with 24bit files.
The reference, an open source player, does support 24-bit files now, but like with 16-bit, only mono or stereo.
There is no ETA on when this will be supported.
What is ALAC Limit? 16bit 44.1Khz ? is it true?, so if I convert each with more 16/44.1K in Flac ... it it ok?
Regards.
"Reference" ? where is it? is it ASIO compatible?
Regards.
What is ALAC Limit?
Do you mean "foobar2000 ALAC decoder limit" ? At least it support 16/48 and 16/96 ALAC files.
I think he means reference decoder: http://craz.net/programs/itunes/alac.html
What is ALAC Limit?
http://craz.net/blog/2009/09/08/apple-loss...24-bit-support/
But on ALAC website... should be supported 24-bit... is it possibile to improve Foobar plug-in?
Regards.
I am having the same problem. The only way to play ALAC on a PC without using QuickTime (that I have found) is to use the Foobar 2000 plug-in.
It seems that Peter is the main developer and has made the ALAC plug-in. Now that the 24-bit version of the ALAC decoder is available at:
would it be possible for Peter to upgrade the plug-in? Please?
I am not a programmer and have no idea how to do this. Is there anyone else who can help?
any one know how to contact Peter... ALAC 24 bit should be an importat goal.
Regards.
http://www.hydrogenaudio.org/forums/index.php?showuser=84
Then click on "Send Message" link.
But, since ALAC decoder for foobar2000 is 2-3 times slower than ALAC decoder for e.g. Winamp... I don't think ALAC decoding is too important for him.
THX.
I try in any case... I'm music-lover / audiophile and I use a PC with a tunned Windows XP, FooBar and a Echo AufioFire 4 with good results.
Bye.
I'd like to second this request for 24/96 ALAC support. Much thanks.
[a href='index.php?showtopic=78168']ALAC decoder with 24-bit support, beta version[/a]
