Topic: Frequently Asked Questions (Read 1543455 times) previous topic - next topic
General Audio Compression
Hydrogenaudio.org's basic rules on listening tests
Subjective vs Objective opinions, post your favourite links / experiences
See also rule 8 of Hydrogenaudio.org's terms of service
What is an ABX blind test ?
Test samples
FF123's samples For Testing Audio Codecs
Flac decoder for encoded test samples
Programs for blind tests
Windows
WinABX
ABC/Hidden Reference Audio Comparison Tool
Foobar2000 (audio player with ABX option)
Linux
LinABX
Test results
Roberto's public listening tests page
Does encoding preserve surround info ?
:-( MP3 destroys Surround Sound encoding
Why not using graphs to compare codecs ?
LAME, CBR, VBR,.... I'm confused!
What's the difference between MP3gain and Replaygain ?
Difference between Mp3gain and Replaygain
MP3
Recommended Lame settings
http://www.hydrogenaudio.org/forums/index....showtopic=28124
Recommended Lame compiles
http://www.hydrogenaudio.org/forums/index....showtopic=28123
Presets vs. -V? Post-3.95 Development of the --alt-presets.
3.90.3 versus 3.96.1
so when to work on new presets?
-V n (in 3.95.1)
Lame development
so what to expect for lame 4?
LAME Versions and Alphas
Dibrom&JohnV -how you see the future of LAME? ...with further links inside.
Discussion about compatibility of hardware mp3 players
Fully MP3 compliant Hardware MP3-CD players
Why LAME 3.90.3?
WHY a particular LAME version
Normalisation : Mp3 Gain tutorial
How To Use Mp3 Gain ?, 3 guides - normalization - maximizing
Differences between Lame 3.90.2 and 3.92
Lame 3.90.2 vs 3.92, Audible differences with APS?
Differences between Lame 3.90.3 APS and 3.93.1 APS -Z
LAME 3.93.1 vs 3.90.3
What are the internal switches of Alt presets?
What does --alt-preset standard do that no custom command line can ?
Re: LAME + Dibrom's presets/switches + remarks
Can I hear the difference between an alt preset standard MP3 and the original ?
samples where aps or ape has a problem
Why is joint stereo better than pure stereo ?
Basic :
i need the help of you wonderful experts!, lame
Any listening test Stereo vs Joint stereo in mp3?
Advanced : a response to a growing rumor...
Expert : alt preset extreme -m s ??
To lower the bitrate of Alt Preset Standard with the -Y switch
how to get the lower bitrates?
Low bitrates : --alt-preset standard -Y versus --alt-preset medium
preset-standard -Y vs preset-medium, How big is the difference?
Why is ABR better than VBR below 160 kbps ?
Suggest ~160kbps VBR setting.
How to compare Lame with other codecs ?
Explaining Lame Presets
What's wrong with substracting wavs in order to see the amount of loss ?
Alternative/Supplement to listening test
What is the best MP3 decoder ?
mp3 decoder tests
MP3 quality and music genre
a classical music and mp3 issue?
What does % and * mean ?
Request information
How to encode and burn gapless MP3s ?
Question about compression @EAC
Does mp3->wav->mp3 conversion lose quality
mp3 to wav to mp3 to wav same?
Transcoding/Re-encoding 128kbps to higher bitrate
Re-encode mp3 128 to higher w/ winlame
Editing MP3s
non-distructive mp3 edit software
LAME and Dolby ProLogic
Lame and surround
EAC
Official EAC webpage : http://www.exactaudiocopy.de
Especially Technology and FAQ.
EAC FAQ
For all problems read first ! @EAC
English tutorial
Liekloo's Essential Ripping Guide
The coaster Factory (for EAC prebeta 11)
German tutorial (EAC+Lame)
EAC-audio
French tutorial
EAC, comment le configuer facilement ... @Hardware.fr
Italian tutorial
Exact Audio Copy Italiano
What is a gap and why detecting them is not necessary ?
Pre-gaps ripped in EAC?
Tutorial about gaps and CUE Sheets @EAC, by Mestrelion
Gap and CUE Sheet 101: A simple tutorial for Dummies like me
Editing cuesheets by Mestrelion
EAC CUE Sheets ASCII formats explained, because sometimes Notepad is all you have
Does the bitrate selected for MP3 encoding overrides the command line ?
Does EAC add aguments to --alt-preset standard
A very useful new tool for EAC is AccurateRip, please search the forums on this.
CDR Media
What are the best CDR ?
Short CDR summary : The summary of CD-R brands @Afterdawn
Long CDR/burner/speed summary : Media Compatability With CD-RW Drives - Which Media Is Best? @CDRLabs
Tests : CDR media tests, all types! @CDFreaks
48x and higher tests : 48x media tests, post your results here! @CDFreaks
How to recognize Tayo Yuden CDRs ?
how do you tell which media you have? @CDRLabs
Burning speed tests
High speed vs low speed burning @CDFreaks
Life expectancy of CDRs
R.I.P. - The thread for dead CD-Rs @Afterdawn
Higher dye type doesn't mean higher quality
Re: Audiophile concerns @EAC ML and answers
Why are audiophile not always trusted when they say that a copy doesn't sound as good as an original CD ?
Digital audio quality @CD Freaks
Secure mode ripping
Ripping scratched CDs
Repairing scrached cd:s
Whats The Best Way To Remove Scratches? ...or the dangers of the above.
Ripping Scratched CD's, Success story (label side scratches)
How to test C2 accuracy ?
Andre Wiethoff's DAEquality kit
Warning about C2 accuracy measurments
Toshiba SD-M 1612 C2 ...
Secure mode FAQ
EAC... how perfect? How does it work?
How to accurately detect C2, accurate stream, overread, etc
Which drives are caching audio data?
How to ACCURATELY detect C2 / Accurate stream / lead-in / lead-out, etc? @EAC
EAC secure mode superior to CDex Paranoid mode
Cdex Vs Eac : The Results !
Does CloneCD read "rawer" than EAC ?
Is audio extraction different than raw mode ? @CDFreaks
Is reading twice secure ?
Is C2 used to correct errors as well as detecting them ? @EAC
Discussion about secureness of C2 versus secureness of no C2
EAC C2 error correction, Use it or not?
Test and copy secure mode failure
Matching CRC for errored rips @EAC
Paranoid mode failure
Eac, Paranoid X Secure mode
Older discussions, possibly out-of-date infos
How does reading twice allows EAC to detect errors
Discussion reliability DAEquality test @EAC
Accuracy of C2 information
Is accurate C2 error reporting an Utopia? @EAC
Safety of C2, of caching, and of reading twice
Cache off @EAC
Offsets
Drive offsets databases
Spoon's Accuraterip page
Offsets are arbitrary
Re: offset detection @EAC ML
Mathematical war between Pio2001 and Matthias trying to figure out ofsets without external reference
How to figure out your offset @EAC
How to "read" your read offset with noisy CDs
How to find a reference offset Article by Pio2001
Arguments against offset correction
The use of offsets@EAC
the relativity of exactness
Why can't two drives read identical images - even when calibrated? @ EAC
Protected audio CDs
Campain for digital rights
Sound and Vision mag article about copy protections
c't-CD-Register, database of protected CDs in german language.
Reading protected audio CDs@ CD Freaks
SPDIF recording of protected audio CDs@EAC ML
Cactus Datashield 200 mastered errors Technical analysis
Excessive Copy Protection?, Mp3 related
Key2audio tested on 27 drives @Afterdawn
Various
About soundcard line input clipping
Recording line in with Soundforge, and Audiophile 24/96
Line in overload on soundcards, M-Audio etc unable to record properly ?
Can a PC with a digital output replace a CD player ?
Soundcard digital pathways?, If you skip the DAC are they 'perfect'?
Recording louder is not better
Rip Rowan. Over the limit @prorec.com
When will this madness stop?!?!? @MusicPlayer.com
What soundcard to buy ?
Want to buy a new soundcard..., ... should be around €100 / $115
How to rip HDCD, or >16bits CDs ?
How to rip 20-bit CD(and retain all 20bits)
Blind ABX tests about hifi components, cables, amount of distortion...
ABX Test Data
Is there a measurable difference between regular and audiophile line cables ?
RMAA analysis of audiophile cables distortion
Is jitter an issue in recent DACs ?
Anti-jitter RAM buffer in DACs, Which have one ?
Killer sample for resampling and clipping (and tweeters)
Test your soundcard for clipping, with this sample
How to insert track markers in a big wave
Burning Gapless CD's
My CD is not Gapless
CUE sheet + 1 wav file for part of CD
How to extract audio before track 1
Recording Gaps Before Track 1.
MPC : What's --xlevel good for?
--xlevel With Mpc?
Using replaygain to reduce bitrate
WaveGain vs. MP3Gain
I can't find any drive that doesn't cache
Questions on Asus drive and buffer/cache@EAC
High definition digital audio
Do CD sound good enough ?
Theoretical discussion : 44 KHz (CD) not enough !? (Nyquist etc.), plethora of distortion frequencies?
Listening test : 96 vs. 48 or 44.1 kHz sampling --> scientific test, perhaps here is the 1. listening test !
Another discussion : Sound, the human ear, and the digital world
Why was 44.1 kHz chosen ?
48, 44.1 khz, why no and/or not 40 khz, Only for 2 channel audio...........
SACD/DVDA
Help! Sacd Good Or Bad?, Does SACD ought to sound like crud?
96 kHz sampling rate
George, Watch this!!!....(96k) @George Massenburg, abstract in page 33
Vinyl
Vinyl versus CD samples from the same album
What songs has digital killed (CD vs LP samples)
Processing the CD sample so as it sounds like the vinyl sample
Compare for yourself: Vinyl vs. CD
Does digital recording keep the "vinyl" sound ?
Casual vinyl vs digital blind test
Vinyl noise samples, how much clicks on a good vinyl ?
Vinyl Care & Dust Removal, How to make vinyl sound good??
Cassette
Recording cassette tapes to PC
How to Clean up Cassette to Digital, Need Help
End of FAQ
Added :
...the only analysis we have proving that
-There are actually intentional errors
-They might not be all handled as well by modern CD ROM players as by hifi players because there are a few with contiguous samples.
-They prevent CRC comparisons between drives, like in accuraterip.
-They are repeatable and thus not detected with non-C2 secure modes, and not corrected by EAC once detected bu C2.
-They are not generated in special places "so as to be inaudible".
Lame development
Dibrom&JohnV -how you see the future of LAME? ...further links inside.
...should have been there earlier
...little-known info, that was just needed in the CD audio is not good enough thread
Removed :
Samsung, Pioneer and Teac vs Cactus datashield 200 audio protection@EAC
Not much useful info... the fact that protections are drive dependant is already stated in the CDFreaks link, and illustrated in the Key2audio tests.
I'd like to have you opinion about these two :
What are the parameters used by MPC for encoding ?
--verbose output of all --quality settings, A List For The Advanced User
Asked here : http://www.hydrogenaudio.org/forums/index....=ST&f=12&t=6802
Is it useful in the FAQ section ?
Lower bitrate presets
"alt-preset standard -Y" VS "preset medium"
Is it accurate ? Still on topic ? Useful ?
Added this first link (the second is the former "96 kHz is unuseful") :
Added this introduction to the MP3 section :
Recommended MP3 Encoder
for bitrates < 128kbps Fraunhofer ...
for bitrates > 128kbps Lame (read on)
...thanks to Tigre
Added
SatCP's Coaster Factory (no more updated)
Spoon's Accuraterip page (often updated)
thanks to Spoon
This EAC offset database by uli-76 should be added. All SatCP's entries AFAIK and many new ones (updated)
http://www.hilfe-stellung.de/eac/offset.htm
not a big deal, but there a little typo here
What does --alt-preset standard that no custom command line can do ?
should be:
"What does --alt-preset standard do that no custom command line can do ?
Re: LAME + Dibrom's presets/switches + remarks"
It was not a typo, it was a mistake in my speaking english  B)
TU2
should be:
And still not quite...
The last "do" is unnecessary.
No biggie
Major FAQ update    !
**********NEW************** :
Audio Compression
See also rule 8 of Hydrogenaudio.org's terms of service.
MP3
Secure mode
Repairing CDs scratched on the label side
Various
[span style='font-size:12pt;line-height:100%']Vinyl[/span]
[span style='font-size:12pt;line-height:100%']Cassette[/span]
Other digital audio links
Recommended bibliography
Interesting books
****************REPLACED**************
replaces
Does WinXp's mixer resample ?
My tests over kmixer effects, Seem to be none...
that is linked from inside the new one
Burning speed tests
replaces
Burning slower is not necessarily safer
CDR Burn Speed and Audio Quality @Afterdawn
**************MOVED****************
Moved
Cache off @EAC
to Older discussions section
****************RENAMED***************
Renaming
Why is not CloneCD advised for audio ?
to
