Topic: Random tracks won't play under ASIO (Read 1948 times) previous topic - next topic
For some reason, fb2k won't play several random files when I have the output set to ASIO. I press play then nothing happens. They play fine in other audio players, and when fb2k is set to regular output. I'm using the latest version, 0.9.6.9. The files to not appear to be corrupt in any way.
Audio card is an M-Audio Delta 1010LT.
are the tracks in question mono?
ASIO requires specific L/R and Front/Rear channel mappings, so a stray mono track will give you an error popup.
Configure your ASIO device channel map so that both left and right device channels are outputting Center, like so:
then test your troublesome tracks and see what happens.
EDIT: of course, if you have files with more than two channels, you should map your outputs accordingly too.
