Topic: WavPack 4.60 Released (Read 33421 times) previous topic - next topic
allowed creation of APEv2 tags > 1 MB (which we can't read)
If I want to add several pictures: which maximal file size limit I should bear in mind now?
The total size of the pictures added together should be less than 1 MB.
If there's only one picture added then it can be almost 1 MB (keep in mind that any text tags and the header overhead is included in the 1 MB).
Thanks for updating the filename specs!
C:\test>wvunpack -cc *.wv
 WVUNPACK  Hybrid Lossless Audio Decompressor  Win32 Version 4.60.1
 Copyright © 1998 - 2009 Conifer Software.  All Rights Reserved.
cue_sheet1.wv:
extracted tag "cuesheet" to file cue_sheet1.cue
restored cue_sheet1.wav in 29.63 secs (lossless, 92.75%)
cue_sheet2.wv:
extracted tag "cuesheet" to file cue_sheet2.cue
restored cue_sheet2.wav in 26.61 secs (lossless, 92.75%)
cue_sheet3.wv:
extracted tag "cuesheet" to file cue_sheet3.cue
restored cue_sheet3.wav in 27.27 secs (lossless, 92.75%)
 **** 3 files successfully processed ****
C:\test>del *.wav *.cue
C:\test>wvunpack -cc @list
cue_sheet1.wv:
restored cue_sheet1.wav in 28.33 secs (lossless, 92.75%)
cue_sheet2.wv:
restored cue_sheet2.wav in 26.44 secs (lossless, 92.75%)
cue_sheet3.wv:
restored cue_sheet3.wav in 28.16 secs (lossless, 92.75%)
C:\test>wvunpack -xx "cuesheet=%a.cue" *.wv
cue_sheet1.wv:
restored cue_sheet1.wav in 43.03 secs (lossless, 92.75%)
cue_sheet2.wv:
restored cue_sheet2.wav in 46.69 secs (lossless, 92.75%)
cue_sheet3.wv:
restored cue_sheet3.wav in 24.64 secs (lossless, 92.75%)
C:\test>wvunpack -xx "cuesheet=%a.cue" @list
cue_sheet1.wv:
restored cue_sheet1.wav in 42.44 secs (lossless, 92.75%)
cue_sheet2.wv:
restored cue_sheet2.wav in 27.48 secs (lossless, 92.75%)
cue_sheet3.wv:
restored cue_sheet3.wav in 25.72 secs (lossless, 92.75%)
C:\test>dir /b
cue_sheet1.cue
cue_sheet1.wav
cue_sheet1.wv
cue_sheet1.wvc
cue_sheet2.cue
cue_sheet2.wav
cue_sheet2.wv
cue_sheet2.wvc
cue_sheet3.cue
cue_sheet3.wav
cue_sheet3.wv
cue_sheet3.wvc
list
wvunpack.exe
C:\test>
Nice work, always appreciated many thanks.
Is the single executable (WAVPACK + WVUNPACK + WVGAIN rolled into one convenient .exe) still in your plans and could 2010 be a possible year for delivery?
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
Just out of curiosity: Why would you want that?
David mentioned that was in his plans, albeit with low priority, a while a go, no biggie as far as I'm concerned, but it's been mentioned to me as a relevant inconvenience in comparison to FLAC, APE and TAK, personally I kinda like the old school PKZIP approach.
I made static linux binaries with MMX enabled:
rapidshare.com/files/321399541/wavpack-4.60.1-static.tar.bz2
Use them at your own risk.
