Topic: Problem with EAC and IDE drives (Read 14503 times) previous topic - next topic
Well, to add - I have Windows 7 with all the patches, Gigabyte P35-DS3L set to AHCI mode, and today I installed Plextor PX-716A. I had before all SATA drives, including DVD burner, SATA controller set to AHCI. And then, EAC test, stuttering of mouse, CPU went to 50% (dual core). Checked IDE mode - set to UDMA4. dBPowerAmp working flawlessly. So I changed read command to MMC1 as suggested, and it works. Thank you all.
The IDE controller on that Mobo is the JMicron 368. The problem is that the default driver that Microsoft has for this controller is bad. To fix the the problem simply update the driver from the JMicron site:
ftp://driver.jmicron.com.tw/jmb36x/XP_Vista_Win7/
Get the latest version: JMB36X_WinDrv_R1.17.55_WHQL.zip
Install. Reboot. And the stuttering will be gone.
