Topic: Comparing two Nero AAC settings (Read 25875 times) previous topic - next topic
Anybody willing to compare two versions of Nero AAC Encoder?
In the attachment are two samples (original and 2 encoded versions for each). These are famous bibilolo and emese samples.
Both are encoded using abr 224 kbps (there is slight bitrate deviation). Please ignore this deviation.
And please don't look at spectrum plots. Please, no posting of spectrum plots in this thread or any discussion about spectrum!
We are interested if any of you can hear any difference and which encoder version produces a sample that sounds closer to the original.
Not an ABX Result, but to me the second one seems to extend a lttle more to frequency extremes (deeper bass, more realistic trebble), but there is also a little bit of ringing sound?
WavPack 4.50.1 -hhx6 | LAME 3.98.2 -V 0
I have just tried the emese samples. In my opinion both encodes fail pretty badly. There is very loud sibilance rapidly altering with the track's rhythmic percussion. If I had not known the original I would have believed that it was a purposely applied special effect or additional electronic instrument. But compared to the original I must say this is one of the loudest artefacts I have ever heard.
I have focussed on the range 0:02-0:05. These are the results. Regarding above artifact 13 is no improvement over 12 or vice versa. Because this was so dominant I have not compared other "layers" of the track.
foo_abx 1.3.4 report
foobar2000 v0.9.6.8
2009/08/10 13:55:13
File A: Z:\rpp3po\Downloads\56_12_vs_56_13\emese.flac
File B: Z:\rpp3po\Downloads\56_12_vs_56_13\emese_56_12.mp4
13:55:13 : Test started.
13:56:52 : 01/01  50.0%
13:56:57 : 02/02  25.0%
13:57:06 : 03/03  12.5%
13:57:10 : 04/04  6.3%
13:57:19 : 05/05  3.1%
13:57:26 : 06/06  1.6%
13:57:42 : 07/07  0.8%
13:57:48 : 08/08  0.4%
13:57:54 : 09/09  0.2%
13:58:09 : 10/10  0.1%
13:58:11 : Test finished.
Total: 10/10 (0.1%)
foobar2000 v0.9.6.8
2009/08/10 13:51:10
File B: Z:\rpp3po\Downloads\56_12_vs_56_13\emese_56_13.mp4
13:51:10 : Test started.
13:53:28 : 01/01  50.0%
13:53:36 : 02/02  25.0%
13:53:42 : 03/03  12.5%
13:53:51 : 04/04  6.3%
13:54:02 : 05/05  3.1%
13:54:09 : 06/06  1.6%
13:54:16 : 07/07  0.8%
13:54:27 : 08/08  0.4%
13:54:36 : 09/09  0.2%
13:54:45 : 10/10  0.1%
13:54:48 : Test finished.
Total: 10/10 (0.1%)
These two samples were chosen because many people can hear difference from the originals.
What we are concerned in this test is whether there is any difference between these two encoded versions that one can hear.
I tried the emese samples as I already knew this one, I can ABX both versions against the original, but I cannot ABX one nero AAC versions against the other, for me both are not transparent & same.
Below are the logs against the original which shows that I can clearly ABX the artefact (noise in the back), but there is no log for 12 Vs. 13 as I gave up after ... say 30 listening trials because I couldn't decide without guessing. Edit: I only used second 0 to 3 for my test.
foobar2000 v0.9.6.8
2009/08/10 14:05:46
File A: C:\Documents and Settings\Sauvage\Bureau\56_12_vs_56_13\emese.flac
File B: C:\Documents and Settings\Sauvage\Bureau\56_12_vs_56_13\emese_56_12.mp4
14:05:46 : Test started.
14:06:08 : 01/01  50.0%
14:06:23 : 02/02  25.0%
14:06:49 : 03/03  12.5%
14:07:03 : 04/04  6.3%
14:07:14 : 05/05  3.1%
14:07:32 : 06/06  1.6%
14:07:43 : 07/07  0.8%
14:07:54 : 08/08  0.4%
14:07:58 : Test finished.
Total: 8/8 (0.4%)
foobar2000 v0.9.6.8
2009/08/10 14:09:28
File B: C:\Documents and Settings\Sauvage\Bureau\56_12_vs_56_13\emese_56_13.mp4
14:09:28 : Test started.
14:09:50 : 01/01  50.0%
14:10:02 : 02/02  25.0%
14:10:12 : 03/03  12.5%
14:10:26 : 04/04  6.3%
14:10:36 : 05/05  3.1%
14:10:50 : 06/06  1.6%
14:11:04 : 07/07  0.8%
14:11:30 : 08/08  0.4%
14:11:33 : Test finished.
Total: 8/8 (0.4%)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Codeboxed.[/size]
I also can't ABX both AAC encodes against each other, yet. Quicktime 7.6.2 also fails pretty badly at true VBR Q127. The sample is pretty though, is there anything able to handle it, yet?
For bibilolo, one should be able to hear some problems in background noise, when the volume is turned up.
At least they are clear to me at lower bitrates (~192kbps).
I have tried bibilolo. Much harder than emese, but I can hear additional background noise when I crank up the volume high enough. I have tried very hard until my ears rang, but I can't hear any difference between both AAC tracks.
As I am not trained on the bibilolo sample I tried with V1.3.3.0 at lower bitrates 0.40/0.55/0.60 aka 128/192/224Kbps VBR, I could instantly ABX 128 & 192 but failed at 224Kbps. I spot a noise at 02.9 second exactly, I didn't listen any further. I cannot ABX this noise on any of the two samples you provided. Maybe there is something ABXable on the rest of the sample, I dunno.
According to me you used a bitrate that is too high, the difference between the samples is almost un-abxable if there is any.
Comparing V1.3.3.0 -q 0.60 against 12 & 13 I suspect that 12 & 13 sound better, as I was almost able to ABX a slight something with official nero, the edge of transparency is very close IMHO. But the bitrate is not the same it's 168Kbps VBR against 240Kbps ABR, so I cannot tell if the suspected improvement is due to a better encoder or if it's simply due to a higher bitrate. I suspect it's due to higher bitrate simply. Anyway I cannot back up these suspitions with ABX logs.
Overall, for me, there is no difference between 12 & 13 on the small portion of the samples I tested (The 3 first seconds for both). I don't plan to test further.
Edit:
If someone as more info on the bibilolo sample plz post them, I am searching Artist/Album/Song, it's usefull to identify the kind of music that is hard to encode. Obviously it's some kind of ambience music but if possible I would like to know exactly in case I would use this sample in a later listening test, thks.
Can't hear any difference between _12 and _13 either. At least not with headphones. Might try again with loudspeakers tonight.
Chris
Thanks to all people that did the test.
If somebody else is willing to do the test, the fastest would be to just try to ABX two .mp4 files. If you don't hear any difference between them, just let us know and it will be a big help.
The original files are there to make it easier for you to find problematic parts and to compare .mp4s to the original if you can ABX two .mp4 versions.
I've tried sample 'emeses'. Source vs Encoded (v12 and v13) was easy to ABX. Encoded v12 vs Encoded v13 wasn't easy at all.
I was able to hear difference in training ff123's ABX mode (5 of 5 chances) between both versions v12 and v13 but the difference is so subtle that  when I tried in normal mode to do log file I was already desconcentrated but still was close 4/5 and second chance already worse 3/5.
Twice time I prefered version 12. Its artifacts are more soft and more pleasant  to ear. While artifacts of version 13 were physically more annoying.
Training ABX mode was succeed (5 of 5) . Not logged.
1st try (4 of 5):
ABC/HR Version 1.1 beta 2, 18 June 2004
Testname:
1R = C:\0\NERO Developres\emeses\emese_56_13.wav
2R = C:\0\NERO Developres\emeses\emese_56_12.wav
General Comments:
1R File: C:\0\NERO Developres\emeses\emese_56_13.wav
1R Rating: 4.5
1R Comment:
2R File: C:\0\NERO Developres\emeses\emese_56_12.wav
2R Rating: 4.7
2R Comment:
ABX Results:
C:\0\NERO Developres\emeses\emese_56_13.wav vs C:\0\NERO Developres\emeses\emese_56_12.wav
    4 out of 5, pval = 0.188
2nd try (3 of 5):
Testname:
General Comments:
1R Rating: 4.5
1R Comment:
2R Rating: 4.7
2R Comment:
ABX Results:
    3 out of 5, pval = 0.500
I hope my results somehow maybe usefull but if it's not feel free to ignore them.
I tried the emese sample, abx-ing against flac was not hard when focussing on 0:00.5-0:02.1 or 0:03.3-0:04.9. Within the first mentioned range the lossy samples sound with less detail, a bit smeared (if this is the appropriate term) while the second mentioned range was easier to ABX because the lossy samples have some kind of harmonic (higher frequency) distortion. Comparing both lossy files I can safely conclude I prefer 56_12 because it's sounds closer to the flac, the 56_13 contains more distortion, especially in the 0:03.3-0:04.9 range. I tested with headphones.
foobar2000 v0.9.6.9 beta 1
2009/08/13 19:20:26
File A: F:\Temp\muaddib\emese.flac
File B: F:\Temp\muaddib\emese_56_12.mp4
19:20:26 : Test started.
19:21:10 : 01/01  50.0%
19:21:21 : 02/02  25.0%
19:21:33 : 03/03  12.5%
19:21:45 : 04/04  6.3%
19:21:57 : 05/05  3.1%
19:22:14 : 06/06  1.6%
19:22:28 : 07/07  0.8%
19:22:43 : 08/08  0.4%
19:22:56 : 09/09  0.2%
19:23:11 : 10/10  0.1%
19:23:21 : 11/11  0.0%
19:23:26 : 12/12  0.0%
19:23:35 : 13/13  0.0%
19:23:46 : 14/14  0.0%
19:23:57 : 15/15  0.0%
19:24:13 : Test finished.
Total: 15/15 (0.0%)
2009/08/13 21:42:04
File B: F:\Temp\muaddib\emese_56_13.mp4
21:42:04 : Test started.
21:42:40 : 01/01  50.0%
21:42:48 : 02/02  25.0%
21:42:58 : 03/03  12.5%
21:43:05 : 04/04  6.3%
21:43:11 : 05/05  3.1%
21:43:17 : 06/06  1.6%
21:43:23 : 07/07  0.8%
21:43:28 : 08/08  0.4%
21:43:35 : 09/09  0.2%
21:43:42 : 10/10  0.1%
21:43:50 : 11/11  0.0%
21:43:59 : 12/12  0.0%
21:44:09 : 13/13  0.0%
21:44:18 : 14/14  0.0%
21:44:23 : 15/15  0.0%
21:44:32 : Test finished.
Total: 15/15 (0.0%)
2009/08/13 21:48:47
File A: F:\Temp\muaddib\emese_56_12.mp4
21:48:47 : Test started.
21:49:10 : 01/01  50.0%
21:50:16 : 02/02  25.0%
21:50:38 : 03/03  12.5%
21:50:53 : 03/04  31.3%
21:51:18 : 04/05  18.8%
21:51:35 : 05/06  10.9%
21:51:55 : 06/07  6.3%
21:52:07 : 07/08  3.5%
21:53:16 : 08/09  2.0%
21:53:26 : 09/10  1.1%
21:53:38 : 10/11  0.6%
21:53:45 : 10/12  1.9%
21:54:22 : 11/13  1.1%
21:54:36 : 12/14  0.6%
21:54:53 : 13/15  0.4%
21:54:55 : Test finished.
Total: 13/15 (0.4%)
ABX-ing 56_12 against 56_13 was tough although 13/15 in the first attempt suggests the opposite.
ABX-ing lossless bibilolo against lossy ones was easy with the tip given in other posts: crank up the volume and you can hear the background noise. Curiously (at least to me) the lossy samples have a lot less noise. I've noticed also a sound mainly on left side, right at the beginning of the track which I could also abx (tried just a few times) but the background noise was a lot easier to abx. I focussed on range 3.0-6.1 sec:
2009/08/13 22:30:55
File A: F:\Temp\muaddib\bibilolo.flac
File B: F:\Temp\muaddib\bibilolo_56_12.mp4
22:30:55 : Test started.
22:31:32 : 01/01  50.0%
22:31:36 : 02/02  25.0%
22:31:39 : 03/03  12.5%
22:31:43 : 04/04  6.3%
22:31:47 : 05/05  3.1%
22:31:53 : 06/06  1.6%
22:32:00 : 07/07  0.8%
22:32:07 : 08/08  0.4%
22:32:16 : 09/09  0.2%
22:32:25 : 10/10  0.1%
22:32:33 : 11/11  0.0%
22:32:43 : 12/12  0.0%
22:32:47 : 13/13  0.0%
22:32:56 : 14/14  0.0%
22:33:00 : 15/15  0.0%
22:33:02 : Test finished.
Total: 15/15 (0.0%)
2009/08/13 22:33:29
File B: F:\Temp\muaddib\bibilolo_56_13.mp4
22:33:29 : Test started.
22:34:07 : 01/01  50.0%
22:34:10 : 02/02  25.0%
22:34:15 : 03/03  12.5%
22:34:19 : 04/04  6.3%
22:34:23 : 05/05  3.1%
22:34:27 : 06/06  1.6%
22:34:30 : 07/07  0.8%
22:34:33 : 08/08  0.4%
22:34:38 : 09/09  0.2%
22:34:43 : 10/10  0.1%
22:34:49 : 11/11  0.0%
22:34:54 : 12/12  0.0%
22:34:57 : 13/13  0.0%
22:35:02 : 14/14  0.0%
22:35:11 : 15/15  0.0%
22:35:12 : Test finished.
Total: 15/15 (0.0%)
ABX-ing 56_12 against 56_13 based on background noise was too hard, I gave up after countless tries so I listened to a foreground sound in the same range and this leaded to:
2009/08/13 22:47:28
File A: F:\Temp\muaddib\bibilolo_56_12.mp4
22:47:28 : Test started.
22:48:16 : 01/01  50.0%
22:48:30 : 02/02  25.0%
22:48:44 : 02/03  50.0%
22:48:54 : 02/04  68.8%
22:49:01 : 03/05  50.0%
22:49:11 : 04/06  34.4%
22:49:24 : 05/07  22.7%
22:49:33 : 06/08  14.5%
22:49:53 : 07/09  9.0%
22:50:10 : 08/10  5.5%
22:50:42 : 09/11  3.3%
22:51:24 : 10/12  1.9%
22:51:35 : 10/13  4.6%
22:51:51 : 10/14  9.0%
22:52:06 : 11/15  5.9%
22:52:12 : Test finished.
Total: 11/15 (5.9%)
I'm sure I have found what to listen to (high frequency distortion) but my hearing seem to be fatigue, I hear tones with amplifier powered off  I will give the latter one another try later this week.
Thank you IgorC and Alexxander.
Please don't hurt your ears with too loud volume. I believe that your results so far are enough. It would be good to get more results from other people.
Well, not much results until now.
It will be usefull if some of AAC's users (maybe /mnt, kornchild ...) will participate here also.
@muaddib
If you want you can post more encoded samples. Maybe Alexxander and me can do some more test.
I've tried the emese sample, but i have to admit am not that great at ABXing it. Since its seems to be a ringing problem IMO. Which is a artifact i seem to be deaf to, but Nero AAC seems to a few ringing problems at 0.50 with my ears though.
56 12
foobar2000 v0.9.6.9
2009/08/25 02:10:02
File A: C:\Downloads\56_12_vs_56_13\emese.flac
File B: C:\Downloads\56_12_vs_56_13\emese_56_12.mp4
02:10:02 : Test started.
02:10:15 : 01/01  50.0%
02:10:23 : 02/02  25.0%
02:10:36 : 03/03  12.5%
02:10:51 : 04/04  6.3%
02:11:05 : 05/05  3.1%
02:11:21 : 06/06  1.6%
02:11:31 : 07/07  0.8%
02:11:54 : 08/08  0.4%
02:12:13 : 09/09  0.2%
02:12:17 : 10/10  0.1%
02:12:18 : Test finished.
Total: 10/10 (0.1%)
Metallic ringing like artifacts, i targeted on 0:02 - 0:06.
56 13
foobar2000 v0.9.6.9
2009/08/25 02:14:51
File B: C:\Downloads\56_12_vs_56_13\emese_56_13.mp4
02:14:51 : Test started.
02:15:02 : 01/01  50.0%
02:15:06 : 02/02  25.0%
02:15:10 : 03/03  12.5%
02:15:18 : 04/04  6.3%
02:15:24 : 04/05  18.8%
02:15:34 : 05/06  10.9%
02:15:39 : 06/07  6.3%
02:15:46 : 07/08  3.5%
02:15:53 : 08/09  2.0%
02:15:58 : 09/10  1.1%
02:16:02 : 10/11  0.6%
02:16:07 : 11/12  0.3%
02:16:12 : 12/13  0.2%
02:16:20 : 13/14  0.1%
02:16:34 : 14/15  0.0%
02:16:41 : Test finished.
Total: 14/15 (0.0%)
Same problem.
56 12 vs 56 13
foobar2000 v0.9.6.9
2009/08/25 02:16:59
File A: C:\Downloads\56_12_vs_56_13\emese_56_12.mp4
02:16:59 : Test started.
02:17:19 : 01/01  50.0%
02:17:28 : 02/02  25.0%
02:17:48 : 02/03  50.0%
02:18:03 : 02/04  68.8%
02:18:08 : 02/05  81.3%
02:18:14 : 03/06  65.6%
02:18:23 : 04/07  50.0%
02:18:35 : 05/08  36.3%
02:18:49 : 05/09  50.0%
02:18:58 : 06/10  37.7%
02:19:16 : 06/11  50.0%
02:19:20 : 06/12  61.3%
02:19:25 : 07/13  50.0%
02:19:31 : 08/14  39.5%
02:19:39 : 09/15  30.4%
02:20:11 : 09/16  40.2%
02:20:30 : 09/17  50.0%
02:20:33 : 09/18  59.3%
02:20:45 : Test finished.
Total: 9/18 (59.3%)
At first i thought file A had disortion at 0:03 and B sounded 'faster', but gave up at the end.
I will try the bibilolo sample at a later time, after i had some sleep.
I tried emese sample few times more but results and preferences are the same.
Very close but...
Testname:
1L = C:\0\NERO Developres\emeses\emese_56_12.wav
2R = C:\0\NERO Developres\emeses\emese_56_13.wav
General Comments:
1L File: C:\0\NERO Developres\emeses\emese_56_12.wav
1L Rating: 4.5
1L Comment:
2R File: C:\0\NERO Developres\emeses\emese_56_13.wav
2R Rating: 4.3
2R Comment:
ABX Results:
C:\0\NERO Developres\emeses\emese_56_12.wav vs C:\0\NERO Developres\emeses\emese_56_13.wav
@muaddib
There are not many samples that have artifacts at abr 224 kbps and it is expected that there are even less samples that could give noticeably different results when using two setting that are tested here.
So far the results were as expected.
It would be good if one or two more golden ears contribute.
Pet Shop Boys -  In the Night has problem spots with nearly all Lame 3.98 settings and is easy to ABX with Nero v1.3.3.0 q0.50. After some trying at q0.60 I'm not sure to be able to ABX consistently but if you want create encoded samples and I'll spend time ABX-ing.
Also Closer to God by NIN is very easy to ABX at q 0.60.
Anyway i tried the bibilolo sample:
56 12
foobar2000 v0.9.6.9
2009/08/25 10:58:30
File A: C:\Downloads\56_12_vs_56_13\bibilolo.flac
File B: C:\Downloads\56_12_vs_56_13\bibilolo_56_12.mp4
10:58:30 : Test started.
10:58:50 : 01/01  50.0%
10:59:05 : 02/02  25.0%
10:59:18 : 03/03  12.5%
10:59:31 : 04/04  6.3%
10:59:42 : 05/05  3.1%
10:59:57 : 06/06  1.6%
11:00:06 : 07/07  0.8%
11:00:36 : 08/08  0.4%
11:00:46 : 09/09  0.2%
11:00:53 : 10/10  0.1%
11:00:54 : Test finished.
Total: 10/10 (0.1%)
Metallic hiss around 0:08 - 0:10. Seems to share the same problem that a older version of Nero AAC had with silent parts on analog recordings.
56 13
foobar2000 v0.9.6.9
2009/08/25 11:10:03
File B: C:\Downloads\56_12_vs_56_13\bibilolo_56_13.mp4
11:10:03 : Test started.
11:10:19 : 01/01  50.0%
11:10:39 : 02/02  25.0%
11:10:56 : 03/03  12.5%
11:11:05 : 04/04  6.3%
11:11:20 : 05/05  3.1%
11:11:46 : 06/06  1.6%
11:12:07 : 07/07  0.8%
11:12:36 : 07/08  3.5%
11:12:42 : 07/09  9.0%
11:12:54 : 08/10  5.5%
11:12:59 : 09/11  3.3%
11:13:10 : 10/12  1.9%
11:13:27 : 11/13  1.1%
11:13:43 : 12/14  0.6%
11:14:00 : 13/15  0.4%
11:14:03 : Test finished.
Total: 13/15 (0.4%)
Same metallic hiss problem. This sample is really prone to hearing fatigue.
56 12 vs 56 13
foobar2000 v0.9.6.9
2009/08/25 11:16:34
File A: C:\Downloads\56_12_vs_56_13\bibilolo_56_12.mp4
11:16:34 : Test started.
11:16:54 : 00/01  100.0%
11:17:13 : 01/02  75.0%
11:17:30 : 01/03  87.5%
11:17:34 : 01/04  93.8%
11:17:40 : 02/05  81.3%
11:17:44 : 03/06  65.6%
11:18:05 : 04/07  50.0%
11:18:23 : 05/08  36.3%
11:18:32 : 05/09  50.0%
11:18:36 : 06/10  37.7%
11:18:52 : 07/11  27.4%
11:18:58 : 07/12  38.7%
11:19:03 : 08/13  29.1%
11:19:12 : 09/14  21.2%
11:19:15 : 10/15  15.1%
11:19:31 : Test finished.
Total: 10/15 (15.1%)
Am not really sure which one is better.
Here are two versions of the samples requested by Alexxander and /mnt.
Enjoy and thanks!
First I started to ABX 01___Pet_Shop_Boys___In_The_Night___cutted_12.mp4 against FLAC. I tried my known spots and couldn't distinguish any. Then for about 20 minutes I tried to find other spots with differences. Again I couldn't.
Then I went to ABX flac against 01___Pet_Shop_Boys___In_The_Night___cutted_13.mp4. One of my usual spots, this one between 9.9 and 10.9 secs, was ABX-able, more or less:
foobar2000 v0.9.6.9
2009/08/31 22:58:26
File A: F:\Temp\muaddib\01 - Pet Shop Boys - In The Night --cutted.flac
File B: F:\Temp\muaddib\01___Pet_Shop_Boys___In_The_Night___cutted_13.mp4
22:58:26 : Test started.
22:58:51 : 00/01  100.0%
22:59:37 : 01/02  75.0%
22:59:51 : 02/03  50.0%
23:00:02 : 03/04  31.3%
23:00:17 : 04/05  18.8%
23:00:38 : 05/06  10.9%
23:01:17 : 05/07  22.7%
23:01:25 : 06/08  14.5%
23:01:34 : 07/09  9.0%
23:01:49 : 07/10  17.2%
23:02:22 : 08/11  11.3%
23:02:38 : 09/12  7.3%
23:02:48 : 09/13  13.3%
23:02:55 : 10/14  9.0%
23:03:06 : 10/15  15.1%
23:03:20 : 11/16  10.5%
23:03:31 : 12/17  7.2%
23:03:45 : 13/18  4.8%
23:03:50 : 14/19  3.2%
23:03:59 : 15/20  2.1%
23:04:05 : Test finished.
Total: 15/20 (2.1%)
With patience I suppose I could do better.
Then I went back to cutted_12.mp4 and tried to ABX the same range around 10.0 secs. I found cutted_12.mp4 impossible to ABX.
I obtain very similar results.  It's kind a strange because I didn't really ABXed it by hearing but by feeling. It's weird. I would scored something like 4.999... ( being 5 is max. score) There wasn't any artifact but I felt like  encoded file had extremely slightly less amplitude on cowbell in right channel.
Sample 13 is abxed and I was already tired for sample 12. Will try later.
foobar2000 v0.9.6.9
2009/09/01 03:11:12
File A: C:\0\Nero Developer Samples\01___Pet_Shop_Boys___In_The_Night___cutted.flac
File B: C:\0\Nero Developer Samples\01___Pet_Shop_Boys___In_The_Night___cutted_13.mp4
03:11:12 : Test started.
03:12:15 : 01/01  50.0%
03:12:19 : 01/02  75.0%
03:12:23 : 02/03  50.0%
03:12:28 : 02/04  68.8%
03:12:31 : 03/05  50.0%
03:12:50 : 04/06  34.4%
03:12:55 : 05/07  22.7%
03:13:09 : 05/08  36.3%
03:13:15 : 05/09  50.0%
03:13:18 : 06/10  37.7%
03:13:22 : 07/11  27.4%
03:13:25 : 08/12  19.4%
03:13:29 : 09/13  13.3%
03:13:33 : 10/14  9.0%
03:13:37 : 11/15  5.9%
03:13:42 : 12/16  3.8%
03:13:46 : 12/17  7.2%
03:13:50 : 13/18  4.8%
03:14:15 : 14/19  3.2%
03:14:22 : 15/20  2.1%
03:15:10 : Test finished.
Total: 15/20 (2.1%)
Yes, no artifact but a very light kind of sweeping stereo, very hard to detect and only when concentrated at 200% and with headphones. Obviously this is not a problem, the original source sound could have been exactly this but we know it isn't because we have the flac.
