Topic: ReplayGain - peak too high? (Read 5004 times) previous topic - next topic
Hi!
I'm new to this forum, but i google'd around and didn't find an answer, so I thought, I'll post this here:
I tried to apply ReplayGain tags to all of my mp3s, but I found that some tracks are not supported because of a track peak that is way too high (foobar shows me values in the upper millions  ).
So I was wondering if there is a tool to fix this issue or do I need to re-rip this tracks?
Thanks in advance
Yantit
Most of the time (or always? can't remember anything else) it also says file corrupted. It can't be decoded properly so rerip them. You can check with the file integrity verifier (1st party-optional component) to make sure the file has decoding errors.
When I run the integrity checker over the file, it tells me that there's a suspiciously high peak, but that seems to be the only problem...
Try with "Utils > Rebuild MP3 Stream"
If that doesn't work you probably have very bad file, so consider re-ripping or finding file elsewhere
If that is not an option and you have some audio editor use something like "remove single click" (CEP/Audition) or try Deglitch (you must convert file to WAV)
But I think no file is worth doing that if there are more than 4-5 large peaks and it's usually waste of time
