Topic: Total Size selected files (Read 3943 times) previous topic - next topic
Do it is possible to know the total size of selected files?
Right mouse click on the selection -> Properties (Menu) -> Properties (Tab). Look for Duration in the section General
@ Forfit
If your user interface is Columns UI the third party plugin Playlists Dropdown is able to show the filesize but of the whole playlist.
For this try the code
$div(%filesize%,1048576).$num($div($mul($mod(%filesize%,1048576),100),1048576),2) MB
which results in 468.32 MB for example.
@ fbuser
total size in properties dialog is under "Location" (at least at CUI).
Robertina.
Reason for edit: correction in content
Ty, i not seen the second tab in the property
@ fbuser
Absolutely. I mixed size and duration. It's independent of the UI.
Selection properties ui-element for Dui or Item properties panel for Cui will display the info.
SHIFT and then RightMouseButton > Properties (Menu) will bring you directly to the Properties-Tab
What is the shift for?
Right click > Properties
or
Alt+Enter
terry
EDIT: AH, I see.
I'd rather say:  RightMouseButton, then Shift+Properties (Menu)
