Topic: oggenc -q problem (Read 3103 times) previous topic - next topic
oggenc -q problem
I can't get oggenc to encode with decimal values like '4.999' for example. Is this the correct way of doing it?:
oggenc -q 4.999 file.wav
OR
oggenc -q 4,999 file.wav
I'm runnung WinXP. I get different behouvior if i use point or comma. I have tried changing decimal symbol in 'Regional and Language Options' (this usually cause problems in software  because comma is default is my country). Oggenc will encode with quality 4 or 5 depending decimal symbol.
oggenc -q problem
I think what is happening here is that oggenc will encode with quality 5 if you use 4.999 but with quality 4.99 if you use 4.99.
If you use comma (which is not recognaised?) it uses just 4.
Juha Laaksonheimo
oggenc -q problem
For me (European) it works with comma but not a period.
If I use -q 4,5 Oggenc encodes at 4,5 and I get a nominal bitrate at 144 kbps
If I use -q 4.5 Oggenc encodes with quality 4 (IIRC) and a nominal bitrate at 128 kbps
oggenc -q problem
lol! so true. I read somewhere that i can take 6 decimals so i didn't expect it to round it of.
