Topic: My turntable - what do you guys think? (Read 17441 times) previous topic - next topic
It seems to have a DIN-connector for tape drives (the o_o one), which then has in- and output
on one connection (5 pin connector -> 2 in, 2 out, 1 ground). Electrically worse then RCA-jacks
(higher impedance if I recall correctly), but should work if connected to a standard line-in on
your receiver.
Here is description from the german wiki: http://de.wikipedia.org/wiki/DIN-Stecker
The "stereo stecker" is the one you'll need to adapt to...
Ok, thanks for all the information guys.
My friend has the cable ready...I'll do experiment this week...and I will be very carefull...
Ok it doesn't work.
I have the cables and connected them to my amp and all I heard was a loud noise.
I guess I won't enjoy the sound of vinyl anytime soon.
Thanks for all you help guys.
