Nevertheless i've made those two toolbars to replace foobar's standard ones :
Volume :
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_font = gdi.Font("Tahoma", 12, 0);
var g_drag = 0;
var ww = 100;
var hofset = 5;
var wh = 12;
function on_paint(gr){
var vofset = (window.Height-wh)/2;
var grad = Math.pow((100+fb.Volume)/100,2);
var i = 0;
while (i < ww+1) {
var col = (grad<=0) ? RGB(168,168,168) : (i<=grad*ww) ? RGB(32+128*i/ww,164*(1-i/ww),32*(1-i/ww)) : RGB(168,168,168);
gr.FillSolidRect(hofset+1+i,vofset,4,wh, col);
i = i +5;
gr.DrawRect(hofset,vofset, i, wh, 1.0, RGB(192,192,192));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
function on_mouse_lbtn_up(x,y){
on_mouse_move(x,y);
g_drag = 0;
function on_mouse_move(x,y){
if(g_drag){
var v = (x-hofset)/ww;
v = (v<0) ? 0 : (v<1) ? v : 1;
v = 100 * (Math.pow(v,1/2) - 1);
fb.Volume = v;
function on_mouse_wheel(delta){
if(delta>0)
fb.VolumeUp();
else
fb.VolumeDown();
function on_volume_change(val){
window.Repaint();
function on_playback_time(time){
window.Repaint();
//EOF
Seekbar:
var g_drag = 0;
var ww = 270;
var hofset = 10;
var wh = 12;
var length = fb.PlaybackLength;
var grad = 0;
if (length > 0) {
grad = fb.PlaybackTime/fb.PlaybackLength;}
var i = 0;
while (i < ww+1) {
var col = (grad<=0) ? RGB(168,168,168) : (i<=grad*ww) ? RGB(0,32+48*(1-i/ww),96+64*(1-i/ww)) : RGB(128+48*(1-i/ww),128+48*(1-i/ww),128+48*(1-i/ww));
i = i +5;
g_drag = 1;
on_mouse_move(x,y);
g_drag = 0;
if(g_drag){
fb.PlaybackTime = fb.PlaybackLength * v;
if(delta>0)
fb.PlaybackTime = fb.PlaybackTime + delta;
else
function on_playback_new_track(info){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
window.Repaint();
