Topic: Newbie questions: DAC, usb or not (Read 4105 times) previous topic - next topic
Hi all, I have a new PC which I'd like to use as a quality audio source for a "higher end" 2 channel hi fi system. The mobo is the Asus P5N7A with integrated sound card and an optical output. Initially I wanted to add a quality PCI sound card like the Onkyo Wavio se-150 or 200, then it occurred to me that an external usb dac like the Trend Audio 10.1 might be a better choice. Shopping around I found a good deal on a BERESFORD TC-7510 DAC, which has no usb input.
Would I get better audio (flac) from the Onkyo or from an external usb dac?
If I connected the TC-7510 to the optical output of my motherboard, would that bypass the onboard soundcard?
Does your stereo have digital optical in? If so then just use the optical out from your mobo.
no my amp does not have an optical input. thanks for the advice though
There's not much to go wrong with optical out so the integrated sound card's output should be just fine, especially since the BERESFORD reclocks the signal.
I can't say anything about the quality of the DAC in the BERESFORD vs. either of the others, but in general it is not that difficult to build an excellent DAC these days, and personally I would be more comfortable with external rather than internal, even though it is certainly possible to get excellent sound from an internal sound card.
The external DAC also has the advantage that you can place your computer some distance from the amplifier without any danger of loss of signal quality. Using optical also eliminates the problem of ground loops.
ok thanks, that explains it well.
