Topic: CPU hit 100% at the beginning of the track (Read 3585 times) previous topic - next topic
foobar hits 100% of CPU load while moving to the next track for 3 to 7 seconds every time. Then it comes down to normal(5~10%).
APE, FLAC, WV, ogg... regardless of file type.
Is it normal?
Please let me know if I can prevent this.
Foobar 0.9.5.5
No DSP
Post list of all loaded components.
List of the Components:
Core (2008-08-04 07:16:48)
    foobar2000 core 0.9.5.5
foo_abx.dll (2008-05-25 00:23:50)
    ABX Comparator 1.3.3
foo_albumlist.dll (2008-08-04 07:04:30)
    Album List 4.3
foo_bitcompare.dll (2006-08-04 21:56:50)
    Binary Comparator 1.1
foo_bubble_coverflow.dll (2008-09-14 16:20:19)
    Cover Flow 0.19
foo_burninate.dll (2006-08-04 21:56:44)
    Audio CD Writer 2.0.1
foo_cdda.dll (2008-06-26 02:18:24)
    CD Audio Decoder 2.1.3
foo_converter.dll (2008-08-04 07:04:34)
    Converter 1.1.2
foo_dbsearch.dll (2007-01-25 21:58:48)
    Database Search 1.4
foo_dbsearch_api_demo.dll (2007-01-22 13:01:38)
    Database Search Toolbar Demo 1.0
foo_discogs.dll (2008-11-08 11:30:06)
    Discogs Tagger 1.14
foo_dockable_panels.dll (2007-03-28 09:19:02)
    Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dsp_delta.dll (2006-03-21 18:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_src9.dll (2006-06-05 20:48:38)
    Resampler (Secret Rabbit Code) 1.03
foo_dsp_std.dll (2008-08-04 07:10:54)
    Standard DSP Array 1.0
foo_facets.dll (2008-01-07 15:33:13)
    Facets 2008-01-04
foo_fileops.dll (2008-06-08 04:14:56)
    File Operations 2.1
foo_freedb2.dll (2008-06-08 04:15:10)
    freedb Tagger 0.6
foo_history.dll (2006-03-31 11:50:34)
    History 0.2
foo_input_alac.dll (2008-06-04 20:29:06)
    ALAC Decoder 1.0.1
foo_input_monkey.dll (2008-05-31 22:39:34)
    Monkey's Audio Decoder 2.1.3
foo_input_std.dll (2008-08-04 07:04:56)
    Standard Input Array 1.0
foo_input_tak.dll (2008-04-08 12:16:06)
    TAK Decoder 0.4.2
foo_masstag.dll (2008-11-02 22:01:02)
    Masstagger 1.7
foo_navigator.dll (2008-09-07 15:25:23)
    Navigator 0.63
foo_out_asio.dll (2008-02-09 14:52:42)
    ASIO support 1.2.6
foo_out_ks.dll (2006-08-04 21:54:58)
    Kernel Streaming Output 1.2.2
foo_playback_custom.dll (2008-11-13 10:09:14)
    Playback Statistics Custom 1.4.3
foo_playcount.dll (2008-10-29 13:26:22)
    Playback Statistics 2.1.6
foo_playlist_manager.dll (2007-01-22 13:05:12)
    Playlist Manager 1.0.2
foo_playlist_tree.dll (2008-02-18 08:30:36)
    Playlist Tree Panel 3.0.5 [Feb 18 2008 - 08:29:56]
foo_pqview.dll (2007-01-22 13:02:24)
foo_quicktag.dll (2007-10-16 17:46:18)
    Quick Tagger 1.0
foo_rgscan.dll (2008-06-12 03:30:18)
    ReplayGain Scanner 2.0.8
foo_run.dll (2008-01-17 20:32:42)
    Run services 0.3.4
foo_texttools.dll (2008-06-19 20:53:52)
    Text Tools 1.0.1
foo_ui_columns.dll (2008-09-07 09:31:33)
    Columns UI 0.3.4.1
foo_ui_std.dll (2008-08-04 21:09:14)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 00:22:24)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2006-11-22 21:57:39)
    Album list panel 0.2.1
foo_uie_graphical_browser.dll (2008-09-14 16:16:57)
    Graphical Browser rev009
foo_uie_queuemanager.dll (2006-12-17 03:21:36)
    Queue manager panel 0.2.3
foo_uie_tabs.dll (2006-10-17 22:54:32)
    Tabbed panel modified 0.2.5
foo_uie_trackinfo_mod.dll (2007-01-05 13:36:20)
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_vis_channel_spectrum.dll (2008-05-18 03:02:12)
    Channel Spectrum panel 0.17.2
foo_unpack.dll (2008-08-04 07:04:20)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
many of them are not in use.
should I unload them to relieve CPU loads?
Perhaps. Updating to the latest version and trying it only with components you really need would be a good idea.
