Topic: noisy buzz at speakers (Read 3717 times) previous topic - next topic
Hey everyone!
I tried to google the subject but it won't help.
Well, i'm trying to find a solution to get ride of this noisy buzz sound when my pc is switched off having the stabilizer on.
Besides, when I plug my sound isolating in-earphones on the onboard sound card "OUT" it keeps the noise, which varies according to the CPU usage!!!
Thanks for any help!
I'm having a hard time understanding your post:
A) What do you mean with stabilizer, you mean AC line stabilizer?
B) Do you say that you only hear the buzz, following this exact path:
PC being on, Stabilizer being on. Switch off pc,  swith on pc, listen. Does it happen already at the point of switching the pc off?
C) It is strange that you say that the noise varies with the CPU usage. Usually it does so with mouse/Hard drive usage, but not CPU usage. Anyway, is this noise really the same than the former?
From what i could guess from the post: You could have a grounding problem.  This happens when different electronics are connected to a power socket but the phase isn't the same.  The usual solution is connect a cable from the ground of one, to the ground of the other. Since i don't have ground line in my power sockets, i ground from a screw of my PC to a ground connector of my integrated amp. (This is especially important with a turntable, as most vinyl enthusiasts would know).
I can't give a better answer with your information.
Ok you tell us it varies according CPU usage but then in the line above you tell us that it happens when the computer is off. Can you understand why someone might find it a bit hard to understand exactly what you're asking.
Ok let me assume it's two seperate problems. One that occurs when the computer is off and which seems to be some kind of interference that your powered speakers are picking up. Then another problem where your sound card produces noise related to CPU useage, but unrelated to the other noise problem of your powered speakers (since you hear this problem even with earphones).
Let's address the second issue first. Unfortunately what you describe is indeed a common problem with some cheap (especially onboard) "soundcards". Could you test the following and tell me to what extent it helps. Could you turn the actual volume knob on the speakers down to a minimum and then go through all of your software mixer settings and volume controls (presumeabley in Windows) and turn them all to 100% maximum. Make sure you do everything, the main volume slider, the wave volume slider in the windows mixer as well as any volume sliders in your player software. Now adjust the volume on your speakers to get the desired listening volume and let me know how much this improves the situation.
I don't understand clearly your post, but I had some cpu noises while my laptop was plugged.
You can read here the solutions some HA members gave me.
Hope it can be useful.
Use another sound card.
Most of onboard sound cards have noise problem with HDD.
