Topic: foo_wlm (Read 176122 times) previous topic - next topic
foo_wlm
n0obie4life, the problem I have is that if a playlist stops automatically (i.e. the end of a playlist is reached) it will continue to display the last song's information in the PSM. If I manually stop or pause a song it will go away though. Otherwise it works great and I appreciate the work.
foo_wlm
Will fix . Thanks for reporting.
foo_wlm
This is probably a related problem, but I have noticed similar behavior when using stop after current.  Otherwise great plugin, I appreciate your efforts.
foo_wlm
Updated to 1.0.1. Fixes the above problems.
foo_wlm
Updated to 1.0.2.
Added Compatibility with WLM 2009 - if you're using 1.0.1, it'll currently display " - " on contact list, but in conversations it displays nicely.
Just a note: In WLM 2009, your custom message set in the plugin isn't shown in the contact list (still shown in other areas such as the convo box) to your contacts if they use WLM 2009 too...
It appears to me that they decided to fixate it to "<title> - <artist>" and there isn't any way around it. The dash will be permanently there even if you hate it alot.
edit: updated to 1.0.3. fixes a small bug from the above update.
foo_wlm
YES!!! THANKS!
foo_wlm
Reply #32
Thanks for the updates
foo_wlm
Thanks a lot! :-)
foo_wlm
Reply #34
Sorry if this is in the appropriate place, but, I have a problem with most MSN/WLM plug-ins where it only shows the Song Name, or shows both the Artist and Song Name, but only for a second before reverting back to whatever personal message was there before. Tried with msn, msnalt and wlm.
Any solutions?
foo_wlm
Reply #35
hi, i was wondering something. some of my tracks have an album tagged, some don't. is there any way for me to show something like
john doe - song 1
instead of
john doe - song 1 [?] ?
something like the plugin detecting that there's no album defined and then it just displays artist and song.
am i making myself clear? sorry for my english also ^^
thanks in advance everyone. hope someone can help.
foo_wlm
Reply #36
Any solutions?
I've never had this problem personally, try checking for scripts that may be overwriting your music personal message - such as ones by Messenger Plus.
Also, what version of WLM are you using?
foo_wlm
Reply #37
john doe - song 1
instead of
Try $if2(%album%,) ?
foo_wlm
Reply #38
[%album%]
foo_wlm
Reply #39
Any solutions?
I'm using WLM Build 8.5.1302.1018 with nothing on top of the install (I did use a mess.be tool to remove unnecessary junk though).
I have a feeling it's AMIP Wrapper causing this, but when I disable it, the problem still arises.
(I haven't had this problem before until only recently).
foo_wlm
Reply #40
john doe - song 1
instead of
i was using something like
%artist% '-' %title% '['$if2(%album%,)']?
it doesn't work, it displays artist - song []...or something like that
foo_wlm
Reply #41
Try this:
%artist% '-' %title% ['['%album%']']
Also, your code is missing the last '
Foobar2000 @ Onkyo SE-90PCI @ Sennheiser HD595 :)
foo_wlm
Reply #42
Any solutions?
Did you so happen to use the mess patch and enabled any of these two features?
Enable Winamp Support For Now Playing Feature
Enables the "What I'm Listening To" feature to work with Winamp.
Swap Now Playing Title And Artist
Reverses the title and artist of the "What I'm Listening To" feature to appear as Artist-Title.
I've installed the exact same version you have and it works nicely, without the mess patch...I'll try it later with the mess patch.
foo_wlm
Reply #43
Well, I decided to reinstall the latest mess patch with your 'suggested' fixes and it seems to have fixed it.
Thanks for the help, I'll get back to here if I have any more problems with the plugin.
foo_wlm
Reply #44
Try this:
thanks, i tried your code but now it just displays artist - title, nothing more. even if the mp3 has an album or not defined, i only see artist - title in msn. any thoughts?
thanks
foo_wlm
Reply #45
Try this:
thanks
Just tried and I'm receiving the same problem too, I'll see what I can do...
foo_wlm
Reply #46
Updated to 1.0.5. Should fix the problem above, I made some internal changes made in 1.0.4 which was flawed.
foo_wlm
Reply #47
indeed you fixed it, thanks a lot for your hard work ^^
also thanks to everyone who helped
foo_wlm
Reply #48
Awesome plugin! Just discovered it, after updating to 0.9.6.2 (finally ).
It should be added to Foobar2000:Components 0.9 on the wiki.
last.fm/user/antropocentrio
