Wiki says so:
Gaps handling
Used when encoding in Tracks mode.
Gaps Appended + HTOA {radio button}
Recommended setting. Gaps appended to (added to end of) the previous track. Any HTOA (Hidden Track One Audio) located in the INDEX 00 (pregap) area of Track 01 will be preserved as an audio file with the track number 00 and title (HTOA).
Gaps Appended {radio button}
Gaps appended to (added to end of) the previous track. HTOA is discarded and replaced with a PREGAP (silence) command in the CUE file.
Gaps Prepended {radio button}
Gaps are prepended to (added to beginning of) the next track.
Gaps Left Out {radio button}
Gaps are left out (discarded and each replaced with a PREGAP (silence) command in the CUE file).
You are perfectly right. I thought that I should select for each cue file:
- Gaps Appended + HTOA: when there is a hidden track.
- Gaps Appended: when there isn't a hidden track.
I thought that if I selected the first option even if there is not a hidden track, then the effect would have been the same that selecting the second option. I wanted to ask confirmation of that. So I don't have to check the cue file every time looking for a hidden track.
Anyway, I would like to report a bug. Sometimes, when I select a folder with only flac tracks (no cue file or log) and I start the verification process, CUETools checks each of them correctly, and it produces the AccurateRip report.
On the other hand, with some albums, if I still select the folder containing only the flac tracks, CUETools only checks few of them randomly. Here is a CUETools report in this case:
.\01. [Gerald Fried] Prelude.flac: AR: disk not present in database, CTDB: disk not present in database.
.\13. [Gerald Fried] Main Title.flac: AR: disk not present in database, CTDB: disk not present in database.
But, if I create a m3u file and I select it with CUETools and start the verification, everything works:
[CUETools log; Date: 14/08/2014 15:46:17; Version: 2.1.5]
[CTDB TOCID: y7hPOlW.WEUd1D_Hi6zCGNGH7w4-] found.
Track | CTDB Status
1 | (1/1) Accurately ripped
2 | (1/1) Accurately ripped
3 | (1/1) Accurately ripped
4 | (1/1) Accurately ripped
5 | (1/1) Accurately ripped
6 | (1/1) Accurately ripped
7 | (1/1) Accurately ripped
8 | (1/1) Accurately ripped
9 | (1/1) Accurately ripped
10 | (1/1) Accurately ripped
11 | (1/1) Accurately ripped
12 | (1/1) Accurately ripped
13 | (1/1) Accurately ripped
14 | (1/1) Accurately ripped
15 | (1/1) Accurately ripped
16 | (1/1) Accurately ripped
17 | (1/1) Accurately ripped
18 | (1/1) Accurately ripped
19 | (1/1) Accurately ripped
20 | (1/1) Accurately ripped
21 | (1/1) Accurately ripped
22 | (1/1) Accurately ripped
23 | (1/1) Accurately ripped
24 | (1/1) Accurately ripped
[AccurateRip ID: 00437922-047d3144-6110fc18] found.
Track [ CRC | V2 ] Status
01 [dcaeb7af|2af75dc7] (0+0/1) No match
02 [0ef1368c|cd065368] (0+0/1) No match
03 [d13f7329|425e7e65] (0+0/1) No match
04 [484c9672|d9075fec] (0+0/1) No match
05 [a7972793|319bd802] (0+0/1) No match
06 [14f2e1ca|aa275d59] (0+0/1) No match
07 [4a49051b|bcfc00a7] (0+0/1) No match
08 [7a92986c|7def9945] (0+0/1) No match
09 [f4171e81|27a2be04] (0+0/1) No match
10 [6263b810|f1890282] (0+0/1) No match
11 [91c3c922|3664ad83] (0+0/1) No match
12 [71dbf64b|cbd29285] (0+0/1) No match
13 [914e0ff4|43833b27] (0+0/1) No match
14 [756bb849|89e7b250] (0+0/1) No match
15 [2642bfed|684891fc] (0+0/1) No match
16 [3f2cef29|b7662427] (0+0/1) No match
17 [948032cc|a87047ee] (0+0/1) No match
18 [ce633150|0428ecc7] (0+0/1) No match
19 [363082ab|156b7ea4] (0+0/1) No match
20 [5bed5692|d8096990] (0+0/1) No match
21 [f1a43c69|c4bc6af9] (0+0/1) No match
22 [00e20fd1|2172a6b5] (0+0/1) No match
23 [65945161|604be3f2] (0+0/1) No match
24 [f2cc5562|e690720d] (0+0/1) No match
Offsetted by -453:
01 [772c32a3] (0/1) No match (V2 was not tested)
02 [1994b52d] (0/1) No match (V2 was not tested)
03 [e38dc188] (0/1) No match (V2 was not tested)
04 [4d97608a] (0/1) No match (V2 was not tested)
05 [b314c0bf] (0/1) No match (V2 was not tested)
06 [6d3938c6] (0/1) No match (V2 was not tested)
07 [c4b41935] (0/1) No match (V2 was not tested)
08 [4fb59586] (0/1) No match (V2 was not tested)
09 [f3fa10a3] (0/1) No match (V2 was not tested)
10 [bb3638e6] (0/1) No match (V2 was not tested)
11 [c02195d7] (0/1) No match (V2 was not tested)
12 [97c58e6b] (0/1) No match (V2 was not tested)
13 [c76a22ee] (0/1) No match (V2 was not tested)
14 [a589a21d] (0/1) No match (V2 was not tested)
15 [34fad3ef] (0/1) No match (V2 was not tested)
16 [693dfe6b] (0/1) No match (V2 was not tested)
17 [e2f38bf0] (0/1) No match (V2 was not tested)
18 [5e097194] (0/1) No match (V2 was not tested)
19 [655d3f9b] (0/1) No match (V2 was not tested)
20 [af75300d] (0/1) No match (V2 was not tested)
21 [38970804] (0/1) No match (V2 was not tested)
22 [1491d810] (0/1) No match (V2 was not tested)
23 [254c254c] (0/1) No match (V2 was not tested)
24 [bc0b2200] (0/1) No match (V2 was not tested)
Track Peak [ CRC32 ] [W/O NULL]
-- 100,0 [FFDB895D] [A6AD92A1]
01 94,6 [8A534AA1] [0760DF2C]
02 67,8 [40CA3A1A] [84489CD5]
03 84,1 [E88B2DA8] [E38E7D78]
04 94,6 [8908DAAC] [C51BB221]
05 94,9 [72CBF60F] [F03DCA74]
06 95,4 [01C68573] [3579D1FB]
07 62,0 [55EE4CC4] [115F2AC2]
08 94,6 [CA605B00] [BE2E3D9F]
09 68,1 [42CDB836] [C6DAAF75]
10 79,2 [5886FAE7] [F1B3CB4D]
11 84,3 [0A77DEF4] [84FC31F0]
12 84,3 [57173E55] [47AEB22E]
13 94,6 [90698436] [4EFEF1C3]
14 94,6 [9CB7FD0F] [9D3E8095]
15 94,6 [8EA122FD] [5203BD08]
16 94,6 [E9C9491B] [6EC7D08D]
17 94,6 [F3E8DA13] [368E97FB]
18 93,1 [19D72492] [12844A4F]
19 59,1 [A4756A91] [A5863815]
20 94,6 [65A23E61] [43D5A898]
21 69,3 [D0332306] [039C8F82]
22 100,0 [1B0CB01C] [2115933B]
23 61,3 [69BB7539] [08994292]
24 61,3 [983C36AA] [CE11818E]
If there is a solution for this, so that it would be sufficient to select the folder containing the tracks for a simple verification, it would be greatly appreciated.
